Question about Acer Computers & Internet
The mouse or arrow of my pc stops and i have to restart my pc again.
    Scholar:
  • 92 Answers
Confirm if your PC is frozen, or if the mouse has stopped working by pressing the WINDOWS key on your keyboard. If the mouse has frozen, pressing the windows key will bring up the start menu. If it does not open, then the Operating system is frozen. Try opening your DVD / CD-ROM device. When it opens, the PC is not frozen.
If the Operating system is frozen, then most likely you have a Hard Drive problem, extreme Hard Drive fragmentation or corrupt system files causing this.
Posted on Jun 01, 2010
Computer froze and can not move the mouse arrow. I did try to restart as well but arrow will not move
Does the keyboard work?
Try putting the mouse in another USB port, or even better try another mouse. You might need to let it "install" the mouse first, this can take a minute or so when you boot up, so all you need to do is turn the PC on with the new mouse plugged in and leave it for a while, then try to use it again.
If the keyboard isn't working either, then it sounds like the Operating System is a bit broken! contact me and i'll try to help you fix it.
Aug 30, 2011 | Computers & Internet
My hp 4520s probook's mouse pad got locked accidentally, and it's not unlocking by double tapping on the light button on the mouse pad. please help me with this asap.
First, try double tapping the light again. You may have just mis-tapped.
Next try restarting the laptop. Certain laptops re-enable the track pad on restart so long as a USB mouse isn't connected.
If that fails, navigate to the Mouse Settings on your PC and re-enable it there. If you have a USB mouse you can use that. If not, you can use the keyboard. Windows Key will launch the Start Menu, arrow keys can highlight options, Enter will click on them, Control+Tab and Control+Shift+Tab will switch tabs (in a window that has tabs).
In Windows XP and 7 (and probably Vista), Mouse Settings is located at Control Panel > Mouse > Settings.
Mar 21, 2011 | HEWLETT-PACKARD ProBook 4520s
Aspire 5100 mouse is frozen how to fix problem
Try restarting your computer by pushing the windows button on the bottom of the keyboard on the left side, generally next to the ALT button. use your arrow keys to move over to the shut down button, select restart and restart your computer. Or you can shut down and then push the power button to start up your computer. This should help reset your laptop and unfreeze your mouse.
If this does not work, go to the control panel, again using the windows button and the arrow keys. select mouse, then go thru the tabs on the window to make sure that your mouse pad is selected to control your mouse.
If you found this information helpful, please remember to leave positive feedback.
Thank You,
Brian
Jan 26, 2011 | Acer Aspire 5100 Notebook
Computer says its locked; change users, but my mouse is locked up too.Im using my desk top to contact you.
You can use the windows key to open the start menu, then use your arrow keys to hightight turn off your computer, hit the enter key, use your arrow keys to highlight restart and hit your enter key This will restart your computer and hopefully, unlock your mouse.
Let me know if this solution works for you. If all else fails, it is acceptable to push the power button until the computer turns off, then hit it again the turn the computer back on. This is not the normally acceptable procedure for shutting windows down, but in this case, it can be done without any negative repercussions.
Brian
Jan 02, 2011 | Computers & Internet
I am installing os windows xp sp2 19 minutes left power shut off 3 times , when power on windows start up to mouse arrow pop up, what shall I to continue installation acer laptop?
The computer will continue to reinstall windows. It will say restarting installation, simply continue. If it stops again make sure you are using a good copy of OS CD and not a pirated one. Do a full format before attempting to install one.
Nov 28, 2010 | Computers & Internet
Ater replace the mouse,mouse not working
Did you restart or reboot your system? if not restart your system and see whether it's working or not. Most of the time replacing a hardware we need to restart or re-boot the system.
If your mouse doesn't work than use Keyboard. Press Ctrl+Esc simultaneously than use the arrow key up>choose the control panel>press enter>use right arrow key to choose the mouse option there press enter key again after you have selected.>Using Tab key and arrow key for choosing the option for "setting" that you wanted to change. See whether the setting is correct or not. If not set your setting.
All the Best!
Oct 16, 2010 | Computers & Internet
My acer ASpire 2920z mouse pad freezes when I plug in the charger. I have to unplug the charger to use the mouse (Both plugged in and mouse pad) and this is inconviniences alot. What can I do?
Hi there, please hit FN+F7 key at a time for unlocking the key pad. After that, If its not working then follow the below instruction.
A)
1. Restart the PC and repeatedly hit F8 until you have a menu in front of you.
c1fdd55.jpg 2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and Enter.
If not working then try these step.
B)
Uninstall the mouse driver from the device manager.(Right click on My Computer then select manager. A window will open , there you will see device manager. Now select the mouse, then select the mouse device. uninstall from there.) Now restart the laptop. When you see all the icon is ready for work, then put your driver installer DVD & run the driver set up. When its finish, restart your laptop again. Your mouse will be ready for work again.
After these, if you again face the same problem then format the OS & install it again.Thanks & waiting for your feedback.
Feb 15, 2010 | Computers & Internet
Laptop touchpad is left-clicking when it is touched.
hi,
Please reduce the touchpad sensitivity. that shld take care of teh issue.
inu
Dec 09, 2008 | Gateway MT3705 Notebook
No mouse pointer
disconnect the mouse and reconnect it ....if restart the compuetr and keep tapping F8 and soon as it restarts ...........
select the safe mode wby using ur up and down arrow keys.....
then check if the mouse is moven if the mouse moves then the mouse is ok if not chage the mouse replace of mouse is required....if the mouse works on the safe mode go to control panel and set the mouse propities to default..
Apr 11, 2008 | Computers & Internet
Computers & Internet Logo
353 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
