Question about Dell (002TR) Motherboard
I have a dell inspiron 1501.its lcd display not working
I have a dell inspiron 1501.its lcd display does not work,a white screen appears..after switching on and off4-5 times ,sometimes it works fine..later the problem repeats.when connected to external moniter it works fine.what is the problem? something relate to mother moard or cable??
    Novelist:
  • 132 Answers
Hi there!
You can try a few things to check if there is something
wrong with the hardware of the computer.
First, try to update the video driver and also the BIOS
which you can get from the support website of DELL.
If the same problem persist try to run the LCD test .
While the computer is off press d+power the test should run and if it is an LCD problem, the display will either be blank or distorted.
Or if you will be able to re seat the cable connector
of the LCD that can be a good thing to try.
Hope this helps!
Posted on Jun 02, 2010
Dell Inspiron 1501 Laptop-6'' Red Vertical Line
The color red and especially red colored lines or a pinkish hue are indicative of an impending screen failure. The only other possibility is that the data cable on the left backside of the lcd panel may be loose at the socket or on the motherboard. 9 times out of 10 though, it is the lcd panel that it failing.
Jan 17, 2010 | Computers & Internet
Blank Screen. Dell Inspiron 1501 ¿?
#1 Tighten the screws for the Display Hinges (The LCD grounds through the hinges)
#2 reseat the display connector to MB
#3 replace display
Sep 14, 2009 | Dell InspironTM 1501 Notebook
New inverter in Dell Inspiron 1501 now the LCD screen gets hot!
I've had the same problem with a Dell Lattitude D531. I've been told that it's the screen itself (which may have led to the original inverter going bad) but that one should also check to make sure none of the screws are making contact with any wires back there.
Sep 10, 2009 | Dell InspironTM 1501 Notebook
Dell Inspiron 1501 LCD flashing colors,works fine on external
Have you updated the video driver?
If yes but problem persist I suspected it's your LCD screen is faulty and needs to be replace.
If your machine is under warrantly no need to pay any fee for the replacement of the part.
Jun 02, 2009 | Dell Inspiron 1501 Notebook
Broken Dell Inspiron 1501 Hinge.......?????
Its the LCD backcover assembly that is cracked.
Here is the part number for it: UW737
I found one from somebodys Ebay store (not mine or anybody I know) for less then $30.00.
http://cgi.ebay.com/Dell-Inspiron-1501-LCD-Display-Back-Cover-UW737-%22B%22---Z_W0QQitemZ310140987025QQcmdZViewItemQQimsxZ20090509?IMSfp=TL090509125007r14975
Hope this helps.
Ben
May 29, 2009 | Dell Inspiron 1501 PC Notebook
Screen IS black, BUT EVERYTHING ELSE IS OK
there is a invertor in LCD. it makes your lcd bright white shine. if it doesnt work you can have dark view. i mean something going on the lcd but you cant see clearly. take to tecnic service your computer.
i hope it works.
May 27, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 laptop screen will not work.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 20, 2009 | Dell InspironTM 1501 Notebook
Only have half screen on my Dell Inspiron 1501
What your describing is a failure of the LCD or possibly the inverter cable connection to the LCD. Most likely an LCD replacement will be required.
LCDs run around $150 on Ebay
Jan 25, 2009 | Dell Inspiron 1501 Notebook
Dell Laptop E1705 Screen goes Blank
If your video output works fine when connected to an external monitor, then the issue is with the LCD display panel. I’m afraid the only way to fix this is have the LCD panel replaced. The ribbon cable that plugs the LCD panel into the motherboard could also be the culprit. Here's a link to the display assembly for 1501: http://support.dell.com/support/edocs/systems/ins1501/en/sm_en/display.htm#wp1022270
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Jan 09, 2009 | Dell Inspiron 1501 Notebook
Screen problm bcoz of broken
- if an LCD screen is broken, it would show white patches. - Ensure that the display is not in demo mode. (Usually in Demo, one half would be normal, where as the other would be a preview of some custom setting - Check the display controls below the LCD Screen to change them.
Please try these first, then you can go for a replacement, if these don't help
Jan 08, 2009 | Dell InspironTM 1501 Notebook
Dell (002TR) Motherboard Logo
116 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
