Question about Dyson DC25 Vacuum
Wirring noise when machine is turned off as the motor slows down.
When the machine is turned off, as the motor slows, it makes a loud whining noise more than it used to.
Is this normal or is something wrong ?
The machine is 14 months old and been cleaning carpets about once every 6 days for about 20 mins each time.
Hopefully this is normal usage.Have you had this question before ?
I was told the you also have a phone number for the
listening analysis test ? Is this so ?
Hope to hear from you soon.
Thanks for your help.
chrispurs1
  • 372 Answers
SOURCE: suden loud noise when vacuming carpet
Hi.
Check that brush roller (beater bar) is free to turn with no obstruction.
If it is still noisey after doing this try this site for Dyson repair manuals.
http://dysonmanuals.inc.io/
Chris.
Posted on Nov 19, 2007
Vac Belts
  • 701 Answers
SOURCE: Older Dyson 07 Animal, loud ratcheting noise on carpet setting
That is an indication that the belts are worn, stretched or broken. You simply need to replace the belt. Here is a link to the belt(s) you need and a manual you can view:
Dyson DC07 Belts and Manual
Posted on Dec 05, 2009
VacuumRepair
  • 438 Answers
SOURCE: roller does not turn
When a Dyson DC07 makes this horrible grinding noise, it can only mean one of three things.
The Dyson DC07 uprights use a clutch mechanism to control the brush spinning when you change the floor / carpet switch. When you hear this grinding noise, it's actually the clutch slipping because it can not spin the roller brush. Most other uprights use a belt to spin the roller brush, and if something is stuck in the roller brush it will cause the belt to break. Dyson's however will make that awful grinding noise rather then breaking the belt, and will only make that noise if the roller brush can not spin.
When you hear this noise on a Dyson, it can only be 1 of 3 things. Either your clutch mechanism itself has gone bad, or the roller brush itself was not properly put back into the vacuum, or the brush itself has gone bad.
I'll be happy to walk you through step by step on how to diagnosis this problem and find out which one of these two parts is bad on your vacuum2_bing.gif.
Step 1. Make sure the vacuum is unplugged. Then turn the vacuum upside down so that the brushes are facing up. It's easiest if you put the head of the vacuum on top of a bench, or counter top. This is how the vacuum should look:
Step 2. You see on the bottom of the vacuum 3 plastic screws that are usually the same color as the vacuum cleaner2_bing.gif. If you're vacuum is purple, the screws will also be purple. Use a flat head screwdriver, and turn each of the 3 screws a half of a turn, counter clockwise to loosen then. After each screw has been turned (you don't need to remove the completely, just a half of a turn is all), simply pull upwards on the bottom plate to remove it.
Step 3. You should now be able to see the roller brush exposed. You'll now need to remove the roller brush. This will take some patience, and some work in order to get this brush out of the vacuum. There is a special tool that has been designed to help you get the brush out easier. I would try getting the brush out first before buying this special tool. The easiest way is to use a flat head screw driver and pry the belt up while pulling up and out on the brush. With some patience and some maneuvering, you'll be able to get the brush out of the vacuum. Here's where you should put the flat head screw driver on the brush:
Step 4. Once you get the belt out of the vacuum cleaner, it's time to test it. Use your finger tips to hold just the end caps on the very end of the roller brush. While holding just the end caps, use your thumbs to try and spin the roller brush. Does the brush spin freely? It should rotate completely several times on each spin. If the brush doesn't spin, or you feel some kind of resistance to the brush spinning, then this indicates that your roller brush has gone bad. Here's a picture of how to test the brush:
If the roller brush went bad, then you'll need to purchase a new one. Here's a direct link to the roller brush your machine uses on our website GoVacuum:
http://www.govacuum.com/dysondc07.html
If the brush however was able to spin freely, and it spun multiple times, this indicates that most likely the brush was not put back in properly, or it could be a little more serious of problem in the clutch itself has gone bad. The clutch replacement repair is a much longer, more challenging repair to do. There is a very helpful video on how to replace the clutch below so that you may follow step by step instructions on how to change it. It was really helpful for me the first time I did this repair.
I think more likely however it's probably that the brush was not put back in properly, and this caused the brushes not to be able to spin, which would cause the clutch to make that horrible noise. Make sure that the roller brush is pictured like the brush above, you may also want to make sure that the bottom plate is put on correctly, this could also prevent the brush from spinning:
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
If you need to replace the clutch, here's a direct link to the clutch your Dyson DC07 uses on our website:
http://www.govacuum.com/dydcclasfore.html
Here's the video on how to replace the clutch:
When you hear that grinding noise, it can only be one of these three problems. This clutch mechanism was so problematic that Dyson removed it on the second series of the DC07 models. I hope that this repair was helpful in diagnosing your problem. If you have any questions about the diagnosing, or the clutch change, please feel free to use the Clarification Request form here on the Fixya repair page. If this was helpful you, please be sure to rate my repair as helpful by clicking the thumbs up icons.
Thank you,
Chris J.
GoVacuum
Posted on Apr 07, 2010
  • 23 Answers
SOURCE: Makes a whistling sound when turned on
bearings in the brushroll might be siezing.
If you start snapping belts, change the brushroll.
Posted on Jul 05, 2010
Testimonial: "Thank you for the feedback!! I think it is about time to replace the brushroll anyway- it is 6 years old and has had alot of use. "
SOURCE: When it is vacuuming the carpet, it makes a loud
Can you be more specific? "part left on the porch" Mine is having the same problem.
Posted on Jul 07, 2010
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Very loud "jet like" noise,please
Vacuums are noisy, but shouldn't sound like a jet.....
Trying to find out what is wrong depends on what kind of noise it makes, i.e. high squeal, vibration, whining and where it comes from.
Here is a webpage with troubleshooting advice on noise in vacuum cleaners. Hopefully you should be able to track down the problem. http://www.ehow.com/how_7493926_fix-noise-vacuum-cleaner-motor.html
If you need further help with repairs, please reply back. Thanks,
Handie Andie
May 09, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
Dyson vac has started to make a loud whining noise when the roller brush is turning
Does the whining noise come from the motor or the brush area?
If it's from the brush area, it's probably the belt. Check to be sure the belt is not worn. Sometimes belts will glass up and slip. Also, check to see if it is still completely on as it should be. You may need to replace the belt.
I woHope this helps, if it does, please place a vote for me. Thanks,
Handie Andie
Mar 28, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
When running it makes a very loud quite high pitched long clicking sound . What can I do about it as I do not want to continue to use it like this
If the noise is continuous from switching on and slows down to a stop when machine is tured of it has to be some thing on contact with the motor or the brush roller the brush roller is easy to check the motor isnt but is less likly to go wrong
Jul 25, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Loud whining sound and wont **** up the water on my f5914-900
Loud whining noise generaly indicates motor issues, which also provide suction to extract water from carpet.
Apr 10, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Vacuum sounds like an airplane after 1 year of use.
the motor bearings are starting to fail most likely. You can diagnose the source of the noise by removing the brushroll and belt, could possibly be the brushroll bearings but if you still get the noise when the belt is off its the motor.
Jan 07, 2010 | Bissell 6594 PowerForce Bagless Upright...
Kenmore upright vac model 33922 - good suction but developed loud whining noise after accidentally vacuuming room without bag. Added bag and changed both filters. Still makes noise. How can I stop noise?
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Sep 14, 2009 | Kenmore 33922 Direct Drive Bagged Upright...
Hoover floormate 500 making super loud noise when
You have a bad motor in the unit. It time for a new machine
May 07, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Temperature light keeps coming on
The whine tells you taht the bearings are bad. Now they may be putting a drag on the armature and causing it to shut down after getting hot. You will have to replace the motor.
Apr 16, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Dyson DC14 all floors.
sept 30,08 bought dc14 all flloor. After 3 to 4 uses it started making lots of noise when on carpet setting. I examined the roller brush and it was cracked at one end. I returned it Oct 13 ,08 and got another dc 14 all floor. Now this one after 2 uses has the same problem only a larger crack in the brush and a small piece of the brush broke off. Very dissapointed.
Jan 08, 2008 | Dyson DC14 All floors Bagless Upright...
Dyson DC25 Vacuum Logo
507 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
