Question about Mercury P4VM800M7 Motherboard
Mother board fault
My machine is not starting..CPU fan stops just after starting for 3-4 sec..I am sure that the CPU,RAM and SMPS are OK.Most probably the problem is in the MB.Kindly help me to solve the problem.I am using Motherboard with Intel 845 chipset,350watt smps,512mB DDR RAM
  • 516 Answers
NO problem about..... the mb..
its ok.. The problem may be with SMPS or motherboard...
Contact the from where you buyed your PC..
Posted on May 30, 2010
Compaq Presario g62-225nr wont boot
check the ram card. also the battery on the mother board if the are fine then the mother board may have gone.
Sep 21, 2013 | Compaq Computers & Internet
Smps working indivudually but motherboad no disply and when i conect to board in that time smps and cpu fan also not working why
1.) Use alternative SMPS
2.) Use alternative motherboard
3.) Unplug HDD, check if BIOS screen is displayed
4.) Check if your input voltage power to the SMPS is sufficient
Feb 26, 2013 | Intel DG31PR Motherboard
Toshiba sattelite c660 restart
Try to access the BIOS screen, as check for the hardware helth and connection status.1) Black screen shows fault in RAM check he slot settings or other RAM.
2) If device shuts down itself in 2 seconds as you said, there might be a fault with the mother board or SMPS circuit which is not at related to any quarantined file by your AV.
Regards:
Himanshu
Aug 28, 2012 | Toshiba satellite c660
My machine is not starting..CPU fan stops just after starting for 3-4 sec..I am sure that the CPU,RAM and SMPS are OK.Most probably the problem is in the MB.Kindly help me to solve the problem.I am using...
if your power supply is good and has DC output.....i have encountered a leaky capacitor at motherboard near the power supply connector socket...need to replace it esp. if it manifest bulgy appearance..it is a electrolytic type, replace w/ same value, it does affect the power to supply the MB due to fluctuation......try to test run after replacing it..have a nice day...
Feb 12, 2011 | Mercury P4VM800M7 Motherboard
I brought a new Intel H55Tc Mother board, Core i3 Processor, 2GB DDR3 Ram. Now my system fan and smps fans spindling is not continue. But My SMPS is working well with other mother board.
Dear vijay, Please check your power ic of mother board there is problem. When you change it then your cpu and processor fan will be working.
Thanks. Rakesh.
Nov 26, 2010 | Intel H55TC Motherboard Core i5 650...
When I connect 2nd and 3rd hard disk my system wont starts......
Just because it has a CPU, it is not a brain
It is ok to set up 2 or 3 harddrives BUT... make sure one is a master, (C:)the others are slaves D-Z
Look at all drives, most now have jumpers and they are master,slave,cselect.
To make it easy, slaves/masters
Jul 24, 2010 | Intel D915GAV Motherboard
Cannot turn on cpu
when you say cannot turn on cpu - what do you mean - ?
cannot boot up?
try removing the cmos battery for a minute then replace and try again.
any error beeps ?
working fine before ?
Oct 11, 2009 | E-Machines eMachines Desktop PC
T30 boot problem
Once again , bad ram will prevent your computer from booting , make sure you are using a known good ram module.
don001996
Mar 08, 2009 | IBM ThinkPad T30 2366 Notebook
Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Feb 15, 2009 | Asrock P4S61 Motherboard
No beep i had 915glvg intel mother board i had recently issued the problem no beep and no display and under cpu it is heating... ram ok smps ok mointor ok cpu ok
Hi there
It could be a memory issue, try different memory, if you still get nothing the bios is probably corrupt rendering the board useless.
Good luck and thanks for using Fixya!!
Feb 11, 2009 | Intel Motherboard
Mercury P4VM800M7 Motherboard Logo
190 people viewed this question
Top Mercury Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
vsri9
Computer Links
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
