I have a pinnacle 500 pci capture card, a sony slv-se70 VHS recorder, and a creative soundblaster X-FI Titanium Fatal1ty sound card. Previously, I was able to transfer video via a scart lead from the video into the video-in on the pinnacle card, and the audio from 2 phono plugs from the video into the mic/line in jack on the audio card. I recently had to reboot the hard drive, and I have been have problems getting the Pinnacle program to work again. First I had problems getting the video to work. After taking out the PCI card, un-installing the software, and re-installing the software, I got the video to work. Then I discovered that the audio was distorted when playing back recorded material. If I play a video, the sound and picture are synchronised and no problem from the sound when playing through the computer. It all falls apart when I try to capture the footage! I have tried reducing the audio bit rate, to the lowest settings. I have tried changing the audio in from line-in to mic-in. I still have the same problem. At the moment I have succeeded in stopping any audio playback in the pinnacle edit facility (although there was audio during the capture process, and there is distorted out of sync audio if I play the video clip through VLC player). I have been trying to sort this problem out by looking at forums on the web, but nothing I have tried has worked so far. I think my computer is powerful enough to do the task. I have the following instsalled - Pentium dual core 6300 @ 1.86GHz 2.86 GB DDR RAM Nvidia GeForce 8600 GT Graphics card SoundBlaster X-Fi Titanium Fatality Sound Card 3 hard drives (2 IDE & 1 SATA) Windows XP Professional (Service Pack 3) Regards Ian
  • Ian Martin May 31, 2010
    I have the ACE Mega Codecs Pack installed. I have also updated Pinnacle Studio 10 to. I only have one desktop computer, and a laptop. The PCI card would not fit into the laptop, and I would be scared of taking someone else's computer to bits to test the card. I must admit that the last time I used this software was over a year ago. So unfortunately, I don't know when it stopped working.
  • 1,472 Answers
Hermitage9
You stated that "I recently had to reboot the hard drive". Exactly what do you mean by this. Did you have to reinstall Windows XP on the computer? Also let me know the model of motherboard you have.
The reason I ask this is it is possible that you are having a resource conflict on the system that is causing your trouble.
With your current computers on the market they like to put al-ot of onboard devices on the system which can cause problems. The one thing that can help is the virtual IRQ and they manage the system resources. However sometimes they will have issues and/or reset causing the system to destabilize.
Issken
http://www.fixya.com/users/issken
Posted on May 31, 2010
    Yes I had to re-install Windows XP, this was because when I first ran the pinnacle program, it kept freezing the computer. After a couple of hard resets, Windows wouldn't start at all. I kept getting the message that essential windows drivers were corrupted or missing. So after using a spare hard drive to load windows on, I backed up all the files I wanted to save on the crashed C Drive, and started with a clean install again. The motherboard I have is an ASUS P5VD2-VM.
  • Will Hartford
    Will Hartford May 31, 2010
    hermitage9
    So this link is to your motherboard. If you look on page 1-22 you will see the routing chart for the system. If you look at IRQ assignment chart you will see the that both your PCI slots are sharing resources with your USB ports. So you might try disabling those ports in the BIOS to see if this make a difference. Also you might try moving the capture card to the other slot as well.
    http://dlsvr.asus.com/pub/ASUS/mb/socket...
    Also make sure that you have the onboard audio and video disable since you are not using them. In addition if you are not using your serial or LPT printer port I would disable those as well
    This should help out alot
    Let me know if you have any more problems or questions
    Issken
  • 19,396 Answers
Hi.
Did you try installing audio and video codecs? The codecs are used to play compressed MP3 and video files. Update audio and video codecs.
Download K-Lite Codec Pack
Free-Codecs.com :: Download Codec Pack.
If that does not work, test the Pinnacle adapter using a different computer. You need to find out if the problem suddenly started because of a defective Audio interface adapter (the Pinnacle Studios PCI card) or because of a software problem (often caused by automatic updates).
If problem happened recently you could also try rolling back the system to a date before the problem started. If you have uninstalled the Pinnacle software in the meanwhile, then you will need to reinstall the software.
All settings will be rolled back to the date of restore.
Regards.
Posted on May 30, 2010
  • 1 more comment
  • Ian Martin May 30, 2010
    I have the ACE Mega Codecs Pack installed. I have also updated Pinnacle Studio 10 to 10.8.
Will I be able to convert from VHS format to DVD using the SLV-660HF assuming I have the converter cable and software?
Don't see why not. Search E-Buyer.Com for something called Videomate C100 Video Audio Capture Card, that will set you on the right track to record on to DVD, software included to make DVD's.
Aug 19, 2011 | Sony SLV-660HF VHS VCR
I have lost the driver cd of my pci sound card. now i am unable to install sound in my coumputer.
Hello nan_ad
You can download the driver directly from the Creative website by following this link:
http://support.creative.com/downloads/welcome.aspx?nDriverType=1#type_1
You can manually select the language and OS options yourself, or use Creatives Software Autoupdate.
Hope this helps. Please don't hesitate to contact me if you require any further assistance.
ajblaj
Apr 28, 2010 | Creative Labs Soundblaster X-Fi Platinum...
I cannot get my headset microphone to work in any of my games. I am using a soundblaster fatal1ty x-fi sound card and sennheiser (not usb) and fatal1ty usb headsets. Neither work . Sound of game comes...
knmmjb
What you need to do is make surre that you have your recording source set to "What You Hear" or your Microphone for you to get your audio for the games. The link below will cover this.
http://support.creative.com/kb/ShowArticle.aspx?sid=1540
If you stil have trouble let me know what version of Windows you are running.
Issken
Mar 07, 2010 | Creative Labs SoundBlaster X-Fi Fatal1ty...
Mic boost in SB Titanium Fatal1ty Pro Series?
go install the old oct 06 drivers, yes there old but it solved my problems. mic boost start to work correctly again.
Nov 01, 2008 | Creative Labs Sound Blaster X-Fi...
I can't configure or access my flexijack on Creative Labs Sound Blaster X-Fi Titanium Fatal1ty Pro Series Sound Card
well the ports on the card could be shot and the card might have been installed by a person with a static charge built on thier hands without them knowing, which can cause the card's electronics to fry and be ALMOST completely disabled. try using a different mic or taking the card out and re-installing it.
Oct 14, 2008 | Creative Labs Sound Blaster Live! 5.1...
Sony SLV-N750 sound problem
befor i give u answer of this Q.i m gona ask u some think to make sure u regulur tape is orignal recoding from company is not that means u recrder vcr out of alighnment on audio head ..so chack that ....and hi fi system very sensetive about it,s audio head alighment ....or might u notice movie runs slow some time or fast ......if that kind problem u can't do much about it only u can do use the orignal record tape or alighment a audio head ...good luk...oh yaa clean head first ..
Dec 21, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Soundcard
This Sound Blaster X-Fi Vista Installation CD is intended to support X-Fi products bought before a Vista installation CD was available in the box.
It supports the following models:
  • SB X-Fi Xtreme Music (SB0460)
  • SB X-Fi Xtreme Gamer (SB0730/SB073A)
  • SB X-Fi Xtreme Gamer - Fatal1ty Professional Series (SB046A)
  • SB X-Fi Fatal1ty FPS (SB0466/SB0256)
  • SB X-Fi Platinum (SB0460/SB0251)
  • SB X-Fi Platinum Fatal1ty Champion Series (SB046A/SB0256)
  • SB X-Fi Elite Pro (SB0550/SB0510, SB055A/SB0510) This CD does not support the Sound Blaster X-Fi Xtreme Audio range (SB0790/SB0792).
This Sound Blaster X-Fi Vista Installation CD includes a full suite of drivers and applications:
  • X-Fi Mode Consoles (Gaming/Entertainment/Audio Creation)
  • Creative Mode Switcher
  • Creative Audio Console
  • THX Console
  • Creative MediaSource 5
  • Creative Smart Recorder 2
  • Creative WaveStudio
  • SoundFont Bank Manager
  • Creative 3DMIDI Player
  • Creative Diagnostics
  • Creative Entertainment Center
For more information on how to obtain a copy of Sound Blaster X-Fi Vista Installation CD, please refer to our regional sites at www.europe.creative.com or us.creative.com.
Windows XP applications do not work with Windows Vista. When launched, it will display a message "The audio device supported by this application is not detected. The application will exit" even though your Sound Blaster card is working properly.
If you have installed any Windows XP applications for your Sound Blaster X-Fi card, it is recommended that you uninstall these (Windows XP) applications before installing the Sound Blaster X-Fi Vista Installation CD. To uninstall, go to Control Panel, and select Programs and Features, and then choose the applications that you need to uninstall.
Nov 18, 2007 | Biostar P4TPT - Motherboard
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
Computers & Internet Logo
David Payne
David Payne
