Question about Panasonic Lumix DMC-TZ2 Digital Camera
Hi, when i turn my camera on, it says that the mode dial is not in the proper position, even when it is?
    Brigadier General:
  • 11,967 Answers
Have you tried moving it to a different click stop?
Posted on May 31, 2010
Nikon Coolpix S8100 and when I turn it on it says Mode Dial is not in proper position
Return the camera right away, it is clear this is a manufacture defect, nothing more can be done.
Mar 22, 2012 | Nikon S8100 Digital Camera
My camera when it turns on says ' Mode Dial Is not in the proper posistion ' I haven't dropped or anything! Will my warrinty cover it!?
Hi jayderehbein,
Make sure that the dial for selecting either video capture or image capture is not stuck somewhere in the middle , therefore a good idea would be try moving it to different positions and then back to the usual image mode and this message would go away ...
Hope this helps ..:) Your feed back would be appreciated.
Jun 19, 2011 | Nikon S8100 Digital Camera
Lumix camera says mode dial is not in proper position
Hi and welcome to FixYa!
Please try to remove the battery and let it sit for atleast 5mins. then reconnect it again. This should reset the system and can resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one!
Dec 21, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
When you turn it on the screen displays "mode dial in not in the proper position." Mode dial does not turn properly.
Something seems to be broken or off between the mode dial and the switch. It also may have broken internal parts.
I have had a camera with a similar problem. It was that the small switch inside was broken, and could not be repaired.
These mode switches can be changed, but will require a digital camera repairman to do such a job. It also could be sold for parts/repair on a site such as Ebay.
Aug 31, 2009 | Panasonic Lumix DMC-FX100 Digital Camera
Mode Dial is not in the proper position on Panasonic DMC-FX3
Hi I am Rob and be an expert on Panasonic camera.
Your modedial knob is shifted and needmechanical re-adjust other solution is that he must be fix soldering.
Rob
Jan 31, 2009 | Panasonic Lumix DMC-FX3 Digital Camera
Warnin! Mode dial is not in the proper position
I used to have the same problem. Make sure the picture of the setting you are using on the turn dial is lined up with the beige pointer on the top of the camera. When you turn the dial, you can feel it lock into position. It could be that the dial hasn't quite clicked into the right position and just needs adjusting.
Aug 08, 2008 | Nikon Coolpix 2100 Digital Camera
MODE DIAL IS NOT IN PROPER POSITION
Try turning the mode dial again. It may not have been turned properly.
Jun 13, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Mode Dial and Lens Problems! Nikon Coolpix 4600
i had the same problem try this: tap the outside of the dial lightly while turning the camera on it should basically "pop" right out!!!!!!!!;)
May 04, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC-TZ2 Digital Camera Logo
76 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
