Question about ASUS P5B-VM DO Motherboard
PC DOESNT START WITH 4GB RAM WINDOWS 7 64 BITS DDR2 667
    Scholar:
  • 94 Answers
The motherboard you have are did not much in 4GB RAM that's why it cannot start. Try to check the manual of that motherboard if what is the maximum memory can be read to run it normally. Or else checked the compatible 4GB RAM for your motherboard.
Posted on Jun 04, 2010
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
I have been given a Toshiba MK 4025GAS laptop, it has 240 MB of RAM. How much more RAM can I put on it?
click start right click on my computer select properties you should how much ram you have installed and how much available it looks like it is capable of 4GB of ram remember when adding more ram try to keep the same brand/type as some motherboards will only work with the one type of ram together and always place the larger ram closest to the cpu central processing unit
Toshiba Mk4025gas Pm ... Shipping: FREE Total: $98.72 Memory Specifications Module Size(s): 2x4GB Type
CPU
Intel Celeron M 370 1.50GHz BIOS Phoenix BIOS. Press F2 to enter Chipset SiS 661 Memory 512MB PC2700 DDR SODIMM (2 memory slots. Max 2GB) ** Hard Drive 40GB Toshiba MK4025GAS CD Drive Philips DVD+-RW SDVD 8441 Screen 14" TFT (Native Res.1024x768) Video Card SiS 661FX (64MB shared) Sound Card Realtek AC'97 audio Network Card SiS 900 integrated fast ethernet
Atheros AR5BMB5 Wireless LAN * Modem Agere systems AC'97 modem Ports 1x Headphone
1x Microphone
1x PC Card
4x USB 2.0
1x Modem
1x LAN
1x VGA
1x S-Video (TV-Out) Touchpad Synaptics Touchpad Battery SQU-504 (11.1v 4400mAh) Dimensions 33 x 314 x 258 (HxWxD in mm) Weight 2.3kg Made By Quanta LE1D
The full system specs are:
CPU: AMD Sempron LV 3000+ (1.8 GHz.)
RAM: 1 GB. DDR-333, Kingston
Chipset: ATI Radeon Xpress 200M (RS480M/SB450)
GPU: ATI Radeon Xpress 200M
HDD: Toshiba MK4025GAS (40 GB., IDE, 4200 RPM)
ODD: TSSTcorp Combo (DVD-ROM/CD-RW 8x24x24x24)
Other:
- Texas Instruments UltraMedia Card Reader PCI xx21/xx11
- Broadcom 802.11g Wireless LAN
OS: Windows 7 Ultimate (32 bits, obviously
as you can see there is a contradiction in how much ram but if its a windows 7 it will need a minimum of 2 gb of ram but it could use 4gb
hope this helps
Jun 17, 2011 | Toshiba MK4025GAS (c99529) 40 GB Hard...
Model: ASUS A7V880 BIOS: 1010.005 OS: Microsoft Windows Server 2003 R2 Enterprise Edition English-US Intel 32-bit (x86) A symptom: I installed 4GB RAM, but BIOS and Windows recognized only...
versions of windows that are not 64 bit do not register over 2.7 gigs of ram, i had this exact same issue with my previous computer, i had to upgrade my operating system
May 27, 2011 | ASUS A7V880 Motherboard
What is maximum ram i can install in Asus U50F laptop and what kind
Asus U50F has 2 memory slots (204-pin SODIMM).
Each memory slot can hold DDR3 PC3-8500, DDR3 PC3-10600 with a maximum of 4GB per slot
for a total of 8 GB ram.
Mar 05, 2011 | ASUS U50F Notebook
My notebook has 4 gb of memory but the operation system see just 3 gb. I have tried using 64 bits OS but the issue remains. Somebody told me that could be a bios limitation
Your BIOS is limited to 4GB according to Toshiba's specification, so this is not the problem. You're best to check the RAM total in the BIOS (F2 on start up I think) to clarify this rather than your operating system. If it says 4GB in the BIOS, then dont worry too much. Its likely 1GB has probably been reserved for your graphics instead, so not to worry. If it says 3GB in the BIOS and you definitely have put 4GB in, then try a BIOS update
Jun 09, 2010 | Toshiba Satellite A105-S4334 Notebook
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
I added more memory to my vista 1501
How much memory do you have now? What Vista are you using (32 bits or 64 bits) ?
A 32 bit Windows XP or Vista system won't be able to address more than 4Gb. Actually it is less than that.
Only a 64 bit system will see more than 4Gb of RAM.
Hope it clarifies things.
Aug 26, 2009 | Dell Computers & Internet
I cant get my puter to start after i put 4gb ram into machine, both slots work independantly. how can i fix this
First need more info on your setup. your puter may not support 4gb. If it does do you have the right ram. Make sure ram is same type. If so take ram out & reseat it. Make sure to shut down & unplug power from back of computer. If this does not work try putting one stick in & start puter
Sep 25, 2008 | Computers & Internet
RAM for Intel E210882 mboard
This are the compatible RAM for this mobo :Support for DDR 400, DDR 333, and DDR 266 and you can upgrade up to 4GIG or RAM this is the complete specs for this mobo http://www.gearxs.com/gearxs/product_info.php?products_id=8076
Hope that helps..........
Sep 10, 2008 | Intel Motherboard
Problem with DG31PR while loading windows 2003 server with 4gb ram
You MUST run a 64 BIT if you want to run anything more than 3 Gb of ram ( such as windows xp 64 BIT , Vista 64 BIT , or even winows 2008 server 64 BIT ) Windows 2003 does NOT support 64 BIT ....
Jul 29, 2008 | Intel DG31PR Motherboard
ASUS P5B-VM DO Motherboard Logo
280 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
