Question about GE 24" Built-in Single Electric Wall Oven - Black
F-1 on oven - GE 24" Built-in Single Electric Wall Oven - Black
  • phil mcinnes Dec 06, 2011
    are the erc and touch pad the same thing.???
  • 327 Answers
Hello,The f-1 simply means failed transistor in control and you have to replace the Electronic Range Control (ERC) or touch pad.
Thanks
Posted on May 30, 2010
Oven overheats. It doesn't matter to the temperature you set it. The oven temperature goes higher.
The first thing to look for is the temperature probe inside the oven. If it is bent and touching the side of the oven, the oven wall will cool the probe, and the oven will always be to hot.
Then next answers depend on the vintage of the oven.
If the oven always runs 20? hot (for example) it is possible to adjust the set point on older ovens by removing the oven temperature setting knob and by using a long thin screw driver through the centre of the shaft to adjust the oven temperature to match the oven setting. You will need to buy or borrow an oven thermometer.
May 06, 2016 | Ovens
Do you have a thermonstate for a preway wall over - model 501-1
  • Range/Stove/Oven Thermostat Parts In Stock from ... www.repairclinic.com/.../a13c24/Range-Stove-Oven-Thermostat-Parts Shop for your Range/Stove/Oven Thermostat from our ... What is a model ... Repair Help. SEARCH. Range/Stove/Oven. Thermostat. Clear All. Range/Stove/Oven Thermostat ...
  • Preway Wall Oven Parts ' Sears PartsDirect www.searspartsdirect.com > All Brands > Preway Parts Shop the best selection of Preway wall ovens repair parts and accessories at Sears PartsDirect. ... Preway Wall Oven Parts ... Model retention may be affected by your ...
  • Preway Oven - Network54 www.network54.com/Forum/124162/message/1109513545/Preway+Oven Preway Oven February 27 2005 at ... I like you was searching for information on parts for a Preway wall oven we have in our ... I have the manual on the oven. The ...
  • Mar 24, 2016 | Ovens
    Blomberg BEP 906. After power went out a couple
    Hello.
    When baking or cooking common foods in your oven, it is important that the oven heats to the proper temperature. Otherwise, the food in your oven could become over- or undercooked. The electric ovens are able to be calibrated if only slightly off, however, if the temperature is 25 degrees off or more, you should replace the oven sensor. The oven sensor is the device in the oven the detects the temperature. The control board increases or decreases the oven temperature, depending on the oven sensor reading. Before calling a repair technician, attempt to calibrate your oven or change the oven sensor.
    Instruction
    1 Turn on the oven and set the temperature to a medium-heat setting, such as 350 degrees.
    2 Allow the oven to preheat and then open the door and insert the oven thermometer.
    3 Allow the oven thermometer to remain in the oven for a few minutes and the look at the temperature reading, comparing it to the oven temperature setting.
    4 Recalibrate the oven if the temperature is only slightly off, or replace the oven sensor if the temperature is greatly off, such as 25 degrees or more.
    Calibrating the Oven
    1 Turn off the oven to prior to calibrating.
    2 Press and hold the "Bake" button until the calibration settings are displayed on the display.
    3 Use the arrow buttons or "+" and "-" buttons to adjust the temperature the number of degrees that the oven is out of calibration.
    4 Press the "Start" button to save the calibration settings.
    Replacing the Oven Sensor
    1 Unplug the oven from the wall or cut the power to the oven in your breaker panel.
    2 Open the oven door and remove the oven racks.
    3 Locate the oven sensor, located at the top-center of the rear oven wall.
    4 Remove the mounting screw securing the oven sensor to the wall and then pull the oven sensor away from the wall.
    5 Remove the cable connected to the terminal on the rear of the oven sensor and then discard the oven sensor.
    6 Connect the cable to the terminal on the new oven sensor and then reposition the oven sensor and secure it using the mounting screw.
    7 Replace the oven racks and then restore power to the oven.
    Thanks.
    Dec 23, 2011 | Ovens
    Tecnick tck 8522/2 oven
    power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
    Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
    My Kenmore gas oven does not light.
    Remove the oven Racks. Remove the oven base plate. Turn the oven on. You can then see the oven ignitor next to the oven burner. If the oven ignitor does not glow a bright orange,replace it. About a $90 part.
    Oct 05, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
    Oven won't light - electronic ignition oven
    Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
    Aug 12, 2009 | Kenmore 33169 Gas Single Oven
    I cannot get the oven to come on after I used the self cleaning.
    Things to check- The screw in fuses, they are usually the 30 amp fuses for the oven. Next is the clock assembly, often these clocks will have the words "push for manual" or "turn for manual", this will put the clock back into the normal operating mode rather than the automatic mode. Next, you may have to remove the power and check for any burnt wires. If all checks ok, you will have to test the selector switch and oven control.
     Oven temp problems: Temperature is too low possible trouble makers, blown oven fuse, bake element is out, burnt wire, oven probe clips, oven temp control, oven temp sensor.
    Temperature is too high in the oven possible trouble makers, oven temp control, oven relay ( if used ), oven probe clips, oven temp sensor, shorted wire.
    These oven probe clips often rust off and the oven temp probe hangs down, or touches the oven wall giving false temperature readings to the oven control.
    Apr 01, 2009 | Whirlpool RBS275PD Electric Single Oven
    My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
    Control panel and oven door lock
    The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
    To lock the control panel and both oven doors:
    1. Press and release Cancel.
    2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
    To unlock the control panel and both oven doors:
    1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
    Dec 22, 2008 | Jenn-Air Electric Double Oven
    OVEN TURNS ON BUT WONT HEAT UP.
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
    GE Double Oven JKP45BA, lower oven wont heat
    If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
    heatman101
    Jul 30, 2007 | GE JTP48 Electric Double Oven
    GE 24" Built-in Single Electric Wall Oven - Black Logo
    56 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
