Question about Konaki MP4-NS MP3 Player
I accidently hit the calibrate button. Now I've got a blue screen and the pen function does not work.
  • 4 Answers
There is some small type of components are fitted in board, if they damage its not work & as same as display components damage.
Posted on May 30, 2010
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
Jan 10, 2011 | Sony DSC-T70 Digital Camera
I have a AVH-P5700DVD and the screen is off on calibration, if I hit the play button, it actually hits the button to the right. Does this stereo have a way to calibrate it or is it possible that it is...
In order to calibrate the AVH-P5700DVD you need to press and hold the Boost and the + button and then press the reset button with a pen. continue to hold the Boost and + until the screen opens back up and you can see the calibration screen. use the arrow nob on the right to select the menu item, and the A button to select your item.
Aug 11, 2010 | Pioneer AVH-P5700DVD Car DVD Player
My leapster does not respond when touched, what can I do to fix that?
It needs Calibrated! Very easy to do. Push and hold the "?" while turning it on. Let go of the power button but keep the "?" held down. It will bring you to a screen and on the upper right side you will see a blue "Calibrate" option so press A. Then with the pen just hit the "x"'s you will see appear. After that's done restart your leapster by pressing and holding down the power button. Leapster will turn off and then release the power button after it's off and it will automatically turn back on. Problem will be fixed!
Jul 13, 2010 | Leapster Learning System
How to calibrate the pen on a ingenico debit and credit
I've done this several times, but it's been a while, so it won't be exact. Hit all the corner buttons except the bottom left, all at once to reboot the machine.Then hit the green button to get in to setup. Then arrow down to the More options and hit enter. Scroll down to pen calibration and follow the prompts. We actually threw out all our pens, and do a finger calibration. It save time at check out, them not having to mess with the pen. Hope I was close. You should be able to figure it out from what I've told you.
Apr 09, 2010 | Ingenico 6550 TERMINAL OPOS POWER SUPPLY...
Coby mp3 player touchscreen wont work
to fix this problem go bak to calibrate and the screen will go blue and in the corners you will see a cross hit the crosses in order in 3 sec or less and the mp3 will go back to touch screen! if it works let me knoow via email gaudettemichael3@gmail.com
Dec 25, 2009 | Audio Players & Recorders
Can no longer calibrate my cintiq pen
i found a button that switches the pens location, it says display toggle in the wacom properties, idk when i click it it switches back to the right position try pressing all your buttons or put your settings to default and try the buttons
Nov 15, 2009 | Wacom Cintiq 21UX (CINTIQ21UXNR)
Can't see "Setup" screen, or any other screens on t.v. monitor
There should be a tv vcr button on the remote control. What you done was you accidently shut off the VCR function. If you hit that button again the tv vcr button it will come back on.
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Leapster2 comes on but won't allow me to sign on. The pen does not respond to the pen
Turn leapster2 off. Press and hold question mark button, then turn on leapster2. Keep holding the question mark button until you get a screen that says "touch calibration" on the right. Once you get this screen, let go of question mark button. Press the "A" button to select touch calibration. A small "+" will appear in one corner -- touch it with the pen. Repeat this for all four corners and then the middle. You have re-calibrated the pen. You can then turn the leapster2 off and then on again to play.
If you have tried this and the pen still doesn't work, change the batteries and repeat steps above.
Apr 20, 2009 | Leapster Learning System
The touch screen and the pen do not pair to function
my i9 phone does not apply the touch screen anymore and the pen calibration i cant click on screen . when i try to calibrate it keeps on the same infomation of "touch where the point is , left, center and right.
Dec 24, 2008 | Dual Electronics CECT P168 Cellular Phone
Pen Problem
First try updating to SP2 and then get the latest Windows Updates from Microsoft.com.
If that doesn't fix it, here are some Win2000 drivers for your laptop.
http://www.fujitsupc.com/www/content/exe/PenW2k1.4.exe
http://www.fujitsupc.com/downloads/mobile/st3400_pen_w2k.exe
If that doesn't fix it, try these Wacom drivers.
ftp://198.145.255.42/drivers/IBMPC/consumer/503/PenTablet_503-3.exe
Oct 17, 2007 | Fujitsu Stylistic LT C-500 Tablet PC
Konaki MP4-NS MP3 Player Logo
98 people viewed this question
Top Konaki Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Konaki Audio Player and Recorder Expert? Answer questions, earn points and help others
