Question about SanDisk Sansa e250 MP3 Player
Hi, I have unplugged my MP3 player from my computer and it does not respond to any switch. If I put it back into the computer it reads that it does not recognise the removable device . Can you help? Thanks
    President:
  • 2,185 Answers
Initially, you can hold down the power button down for 20seconds to do a reset.
You should do the "safely remove" procedure when unplugging the MP3 player from the computer's USB port, otherwise it will get fried and damaged over time. If you have just been simply pulling the plug off all these times, then I guess that was what happened - the battery got fried. Anyway, just try to plug your MP3 player to another USB port on the computer or better yet, to other computer's usb port.
Please let me know how this goes.
Posted on May 30, 2010
Testimonial: "Thanks so much ,it worked within 30 seconds"
    Problem Solver:
  • 12 Answers
Try to reset it !
Testimonial: "brilliant"
  • 4 Answers
If u have internet connection, put device into a computer its auto detect urs device & update. after 10min unplugged the device. its work very nice......
I connect my sansa e250 into my computer and the mp3 player says connected but i see no sansa hardrive and the computer doesnt respond .
Turn Sansa off. Unplug USB and make sure its clean. Plug back in as normal. If no hardrive comes up go to My Computer and look for it and troubleshoot if necessary.
Finally, repeat this action above accept when you turn MP3 off, hold button for 15 seconds - release and then turn back on.
Nov 05, 2009 | SanDisk Sansa e250 MP3 Player
I plug in my mp3 player into my computer, computer is on open everything like i use to have it when it did charge but now the screen comes on and sits, then i take it off and i cant turn it on for more...
When the mp3 player is plugged in to the computer, it won't respond to anything except the computer- the screen will just sit there and say it's connected. After you unplug it, it probably doesn't respond for 3 seceonds because it's refreshing its media. It might tell you it's refreshing or just refresh without saying anything.
Aug 10, 2009 | Mach Speed TRIO Onyx MP3 Player
Computer won't read lyra opal mp3, and now it won't turn on..
I can't get it to download music but you can push the reset on the back with a pin & it will turn on again.
May 18, 2009 | RCA OPAL M4001 MP3 Player
Laser mini mp3 player 4GB
I found that MP3 players need to be plugged into a USB PORT not a USB HUB. Good Luck!
Mar 19, 2009 | Laser MVP-1G MP3 Player
OMNITECH 2GB WON'T RESPOND
you can change the battery and format the player
then you should not sync it with wmp please drag and drop into it directly
Mar 02, 2009 | iLO (2 GB) MP3 Player
Can't delete folders. response is devise not responding
to delete files there are 2 ways to do this.(1) first is with the on and facing you. on top the is the black menu switch. (2)hold down until it reads play music,and release (3) cycle either way until it reads delete.(4) cycle the switch until it reads del / push switch in (5) cycle to voice (6) push switch in to delete files. (cycle to exit and push switch again it should go to your music.
Second way is to plug it into a computer with plug and play.with the Trio MP3 on, the computer should open up a menu, chose open files (2) the screen should have music, voice and other files on the display. chose the voice file and click it open. use the mouse to delete files / or point and use the key board delete key to delete files. IF PLUG and Play does not open up goto MY Computer and openit up. drop down to the removeable disk and click open. you should be where you can delete the voice file. good luck and have fun.
Dec 17, 2008 | Digital Audio TRIO MP3 Player
Transcend MP2 player Tsonic 610 not working
hi anit
m sure u have turned ur HOLD switch on
switch it back off and its all done man
Jul 07, 2008 | Transcend T.sonic 610 MP3 Player
Black Screen, Not turning on but charges?
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Feb 06, 2008 | Creative Labs ZEN V Plus MP3 Player
Craig mp3 122 mg
When you put songs on your mp3 player don't put them in folders if you do.
Also did your mp3 player come with any software, you may need to use the software in order to put songs on.
When you've finished putting songs on do your safely remove your mp3 player from the computer, if not that could be your problem.
Also it could be anything from a small read error, try formating your mp3 player which may fix this problem to do so follow these steps below:
First connect your mp3 player to the computer, once you've done that go to "Start" - "My Computer" - now look for something called "Removable Disk" which is your mp3 player, once you've found it "Right-click" on it then click "Format", once format as complete put music back on your mp3 player, then see if the problems been fixed.
Good luck. Hope my solution was helpful in some way. Further problems, leave a comment on here and i will get back to you a.s.a.p.
Nov 22, 2007 | iLO (2 GB) MP3 Player
SanDisk Sansa e250 MP3 Player Logo
222 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
