Question about Intel Motherboard
No boot. see initial msi display but nwindows 7 operating system
I am trying to load windows 7 on a new p55g80 but windows fails to boot up. I get continous rebooting, Windows repair does not work.
8 gig of ram and geforce video card.
  • Intel Master
  • 11,800 Answers
The corruption in Windows is too extensive to be fixed by a simple Repair. You will have to do a proper reinstall (with full format). Once that is done test the hard disk for errors, it might be dying.
Posted on May 31, 2010
How to fix hp laptops
Step one: Turn your computer on, booting from either your Windows 7 Installation DVD or Windows 7 System Recovery Disc. Remember, you may need to change the boot order inside your BIOS to have the your DVD drive boot first.
Step two: After the installation or recovery disc loads, if prompted, select your language settings and then continue. If you are using the installation DVD, when prompted by the following screen select Repair your computer.
Step three: The computer will take a moment now to scan itself for any Windows installations, after which you will likely be given a choice to select which installation you wish to repair. Select the appropriate Windows installation from the list and then continue. If by chance a problem is detected in one of your Windows installations at this initial stage, the system may also ask you if it can try to repair the problem automatically. It is up to you if you wish to let the system try to repair itself, but otherwise just select No.
Step four: Once you have reached the System Recovery Options screen, as shown below, you will be faced with a list of choices that can aid you in repairing a damaged Windows 7 operating system. If you wish to try the Startup Repair option first, it is often successful in automatically fixing many different start up issues, but in this article we will be using the Command Prompt option to resolve our problems manually. So, click Command Prompt to continue.
Step five: Now sitting at the command prompt, enter the following command and then press enter:
The above command will scan all your disks for other operating systems compatible with Windows 7 and allow you to add them to your system's boot list. If this fails, you may need to backup the old BCD folder* and create a new one in its place with the following commands:
bootrec.exe /RebuildBcd
Aug 12, 2014 | HP Computers & Internet
My bios setup is locked with password and i dont know the password,what shall i do?
The Windows operating system allows you to compress the files on your drive to conserve disk space. In some situations, this compression process will compress files required for the operating system to boot. Files that are compressed must be decompressed prior to execution. Since the operating system has not loaded, boot files cannot yet be decompressed. In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear. An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer. Hope this helps
b>
Jan 21, 2013 | MSI Wind U100-016US Laptop
Black screen with cursor
Windows is corrupted or the hard drive has issues. If you have a backup cd recovery disc try it now, if that fails have the hardware tested for possible replacement.
Jul 27, 2012 | Toshiba Satellite L500 Series Notebook
How to Replace Bios? Boot & Reformat Attempts Hang (on every HDD) - I guess BIOS is Corrupted
You can go to the manufacturer web site and go to support then to drivers and downloads there should be a BIOS flash software utility at their site. Click Here to go there. Select your model and make sure it is the correct one. I would also go for the automatic driver update, this will find and seek any drivers for your laptop that are needed, missing, or upgrade them.
If that does not provide the info you need their is also a support number as well as live chat at the link above. I hope this assisted you in some way. John
May 02, 2012 | MSI Computers & Internet
MSI usb problems
Sounds like your O/S was damaged when the old MB failed. I'd boot the computer with yoru system disk and run a scandisk or, in the case of Win Vista or 7, choose the option to repair Windows.
Mar 21, 2012 | MSI Microstar KT6 Delta (MS-6590)...
I have msi k8mm-v desktop... which cannot display to windows but can display in safemode.....
Sounds like an OS( operating system prob ), get into the bios set up and set the boot sequence to D:( dvd/cd rom ) first and save it upon exit.
Put the Win7 or any operating system that you use and let it run, read the instructions carefully.
Hope that helps!
Oct 25, 2011 | MSI K8MM-V Motherboard
Dell latitude d600 i hit f1 then nothing else happens the d600 just stays on window loading up page i can only get into safe mode nothing else what do i do
If the problem lies on Windows this can be repaired. First, If you are using Windows 7 or Vista, we can try to launch startup repair from the advance boot options menu. You can access this through tapping F8 right after you turn the computer on. Tap F8 until you get to the advance boot options menu. Choose "Repair your Computer" and this should guide you on how to do the startup repair.
If you are using Windows XP, we need to try to boot to safe mode and see if you can boot the Operating System from there. To do this, it's the same drill, tap F8 repeatedly on your keyboard once you turn the computer on until you get to advance boot options menu. Choose safe mode and press enter. This should load the operating system to safe mode. If you are able to boot from here then that means one of your "drivers" has failed the OS to boot normally. If all of these fails, We can try to repair the Operating System by booting using your Restore CD or your Operating System CD from the CD-ROM drive. Reboot the computer and press F12 (or whatever it is that makes you choose to boot to CD) while seeing the pc manufacturer's logo, this should give you the options to boot to CD-ROM. It will give you a quick prompt of "press any key to boot to cd..". Make sure you press the space bar during this time to initiate the boot from CD-ROM.
For Windows XP, Once the Windows Setup loads, Choose "Recovery Console" to repair your computer. Just choose the installation you would like to repair (normally it's number 1) then it will ask you for the administrator password. By default, the password is blank, but if you set a password for admin then use that password.
Once you get to the prompt, Type this command. "CHKDSK /R" (without the quotes). It will initiate the repair for your OS. This might take an hour or so. Just wait for it to finish and it will automatically reboot your computer. Let the computer computer reboot normally. You should be able to get to your normal windows screen back.
For Windows 7 and Vista, do the F8 and choose Repair your Computer, Choose the installation you want to repair then choose command prompt. Type CHKDSK /R and that shoudl initiate the repair for your OS. Most of the time, the "startup repair" should do the fix for Vista and 7, but just in case it fails, do this step.
BTW, these repairs are designed to repair the OS without you losing the data you have on the pc.
Hope this helps. Good Luck.
Sep 04, 2011 | Dell Latitude D600 Notebook
It crashes and asked me to reinstall it when I did that now it will not install at all.
Aug 22, 2011 | Computers & Internet
I have an msi ms-7390 k9n sli ver 2 motherboard and I updated the bios to the latest ver. 1.2. After that when cold booting the motherboard does not initialize usb you have to press delete to enter setup...
move the sata connection for your bootable HDD to another port like 3 or 4 and the bios will detect then run bios setup to boot from the sata 3 or 4 and it works like normal, must be a bug in sata 1 and 2. had same issue trying to install win7 x64. Win 7 refuses to detect sata DVD drive, moved it on the MB and it installed fine.
Jul 19, 2010 | MSI K8N Neo4-F Motherboard
Intel Motherboard Logo
62 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
