Question about Philips VOIP8411B/05 Cordless Phone
No display light
Due to humidity ( the phone was left outdoors all night!) the display light does not come on. The other functions are all working. Can it be repaired, could worming it with a hairdrier help?
  • rcvandenheuv May 30, 2010
    Thanks for the quick reply
  • Philips Master
  • 4,737 Answers
Yeah you can get a replacement from the service center, but if there's a repairing shop near you, let them check, it's likely that your display cable is the problem (flex cable). For best result, please power off the set and if you have idea how to open it, take it apart and let it dry itself or you can let the technician at the repairing shop do it for you. If you keep it power for long, it's possible that, i'll never be repaired. There are very complicated and sensitive parts inside. You can give a try with your hairdryer, but remember to set the speed very low and don't do it very near to it. You know the hairdryer also blows out warm air which can destroy the parts inside. Hope this helps. Good luck. Thanks for using FixYa.
Posted on May 30, 2010
My 6yo NatGeo super weather station has quit transmitting outdoor temp & humidity info. The display is present and correct for all other categories. Changed batteries, no help. Any ideas?
  • Remove all batteries
  • Install batteries in transmitter and wait for it to begin sending data
  • Install batteries in receiver. You should see temperature and humidity displayed
Jul 18, 2017 | Measuring Tools & Sensors
Springfield precise temp in out thermometer 91756
Return it to the manufacturer for warranty repair/replacement
Jul 23, 2014 | Taylor 91756 Wireless Thermometer With...
IR light doesn't work on security camera.
nitevision is in monochrome.. but if the irs dont work in that camera need to either get an ir light for that unit or replace that specific camera..the ir board is burnt out..or disconnected..I have several systems in use at different locations and I do installs for residential locations..I get some of my units off ebay..
Jan 20, 2014 | Zmodo Surveillance CM-S38901SV 540TVL High...
WE ARE CURRENTLY IN NORTHERN TERRITORY VERY HOT AND HUMID. RUNNING AC THRU THE NIGHT IT STOPS BLOWING COLD AIR AND FAN SEEMS TO BE NOISY. HAS IT ICED UP DUE TO THE HUMIDITY. UNIT BEING RUN THRU THE DAY NO...
If your coil is freezing at night, it sounds like your getting cold enough at night to have your saturation temperature drop below the design of what the AC is able to do. If it runs all day without an issue and freezes up at night, you need to add what is called an outdoor fan cycling switch. This will turn the condenser fan off when the saturation temperature drops so it will not freeze your coil at night. You need to have an HVAC technician install this. It is not a DIY projuect since it has adjustments that need to be right. Plus, it it's a heat pump, it needs to drop the switch off in the winter.
Sep 28, 2010 | Heating & Cooling
Water only runs with humidistat in test/reset mode. Aprilaire 600 with an Aprilaire 56 Automatic Humidistat, both about 5 years old. Water line is clear, and test mode runs fine for the 1 minute interval....
you need to make sure your humidity level in the house isnt higher then what your humidifier will provide at any givin outdoor temp. this chart is in the owners manual. you cant remove the wires going to the ODS or it will give an error unless you have a resistor to put in its place. Anyway if the humidifier works in test mode according to AA it works so you may have higher humidity than you think, the highest your gonna get is 45% as the temp outside drops it will allow less humidity so it doesnt cause window condinsation (property damage) here is a copy of the chart. the #s on the left are the dial setting
TABLE 2 – % Relative Humidity Guide
Outdoor Temperature (°F)
-10°F 0°F 10°F 20°F 30°F 40°F
10% 10% 10% 15% 20% 25%
2 10% 10% 15% 20% 25% 30%
3 10% 15% 20% 25% 30% 35%
4 15% 20% 25% 30% 35% 40%
5 20% 25% 30% 35% 40% 45%
6 25% 30% 35% 40% 45% 45%
7 30% 35% 40% 45% 45% 45%
Nov 28, 2009 | Aprilaire 600 Humidifier
Left brake light is out, but it is not the bulb, as it works for the other functions, just not as a brake.
Brake light bulbs have 2 elements in them. One bright one for the brakes, and a dimmer one for the night time lights. It's possible for the brake light element to burn out prior to the other element due to using the brakes more often than the night time lights.
Jun 30, 2009 | 2005 Jeep Grand Cherokee
Outside unit not registering temp and humidity to base unit
Uniden EWCI936
To get the outside temperature working again, open the outdoor sensor box carefully loosening the one screw with a screwdriver, insert 3 brand new AA batteries, check phone for outside temperature. If not showing on the phone display, try changing the 'channel' setting, just above the batteries. Be careful not to break the tiny switch. Gently use a smaller flathead screwdriver, if needed. There are 3 settings. Mine worked fine on the first setting. If it is showing on the phone set screens, then, carefully screw the lid back on to the sensor box, and re-insert into the sensor wall holder. I keep mine in a plastic bag on a shelf outside, away from sun, so I can get a true reading day or night. It is always a bit warmer in the sunlight than the true outdoor air temperature. Enjoy
Apr 24, 2009 | Lands Phones
Problem with display of Nokia 6600 mobile
my nokia6600 occurs same problem
when i switch off and then switch on the phone then display comes for the time i am using the phone. As i left the phone for sometime without pressing any key it again goes to that white screen mode..but phone is functioning .plz help me to rectify the problem.....
Jul 14, 2008 | Nokia 6600
Nokia 6230 keypad problem
sounds like the phone got wet or was left inVERY humid enviroment Clean ALL corrosion from the contact points and the back of the phone's logical key pad(where the electronics are) other wise get it replaced....
May 28, 2008 | Nokia 6230
Accessing ir5000 engineers console
You do not need humidity readings. If the copied paper curls at the edges as soon as it comes out of the unit, the paper (not the copier) is humid. Besides, there are no humidity sensors on the copier. There is a humidity switch to reduce humidity, but no sensors to notify any levels.
Anyway, the code is: 5,8 (simultaneously) - ADDITIONAL FUNCTIONS - 5,8 (simultaneously) - ADDITIONAL FUNCTIONS.
Oct 23, 2007 | Canon imageRUNNER 5000 Copier
Philips VOIP8411B/05 Cordless Phone Logo
18 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
