Question about Raymarine Linear Feedback Unit For Outboard Engines, 12"
My outboard wont start ive fixed the the ignition coils starter motor and spark plugs it gets spark but no fuel there is fuel getting there but just wont start tryed sparying fuel straight in the carbs but still wont start
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
If you have spark and fuel it should atleast fire when you spray fuel in the carbs. if your spraying it just into the air intake it may not be making it to the intake manifold. have you checked the fuel pump? you also need to check for the possibility of a air leak in the fuel system causing the motor to fail to run because it has a very lean fuel mixture. check all fuel lines, fuel tank, couplers and carb gaskets. if you havent take the air intake cover off and try spraying some wd 40 or other mildly flammable product and see if the motor will fire that way. its likely the fuel tank or fuel lines are the problem from my point of view. good luck.
Posted on May 30, 2010
Testimonial: "thank you very much and i think ill replace all gaskets and fuel lines cheers"
Car died while stooped at light
if it won't run on starting fluid then you have a no spark issue. i'd check spark out of the coil to the distributor. you could have a bad ignition control module or coil
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Apr 18, 2014 | 1986 Toyota Cressida
I was driving my 1998 zx2 and it shut off it sounds like it gonna start but just wont turn over ive checked igntion coil fuel pump and filter im stuck what else do i look for?
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Feb 28, 2012 | 2001 Ford Escort ZX2
I have a 1990 mitsubishi might max it wont run smooth unless you keep your foot on the gas and keep the rpms up a little bit and it wont drive cause it stalls everytime you try to move it. ive replaced the...
You've already eliminated the spark plug & wireset, distributor cap & rotor.
Sounds like your car needs a tune-up, specifically, the PCV (positive crankcase ventilation) valve, and/of the EGR (Exhaust Gas Recirculation) valve.
Components checked/replaced during a tune-up are:
air filter
motor oil
motor oil filter
breather filter
fuel filter(s)
fuel strainer
PCV valve
EGR valve
spark plugs
spark plug wires
ECM or distributor cap & rotor
cabin air filter
transmission oil filter
transmission oil
engine coolant
check all vacuum hoses and lines
Troubleshooting the no-start condition - from the 1990 Mitsu Mighty Max Repair Manual:
Priority Action Part Type -- Cause
1 Inspect Battery -- Battery Discharged or Faulty.
2 Inspect Battery Cable -- Corroded, Broken, Shorted or Poorly Connected Battery Cable.
3 Inspect Distributor Cap -- Distributor Cap Cracked or Burned.
3 Inspect Fuel Filter -- Clogged or Dirty Fuel Filter.
5 Inspect Ignition Coil -- Faulty Ignition Coil.
6 Inspect Wireset -- Worn, Damaged or Faulty Spark Plug Wire(s).
7 Inspect Spark Plug -- Incorrectly Gapped or Fouled Spark Plug(s).
8 Inspect Starter -- Starter Motor Faulty.
9 Inspect Fuel Pump -- Low Fuel Pressure.
10 Inspect Solenoid Switch -- Faulty Starter Solenoid Switch.
11 Inspect Fuel Pump Relay -- Faulty Fuel Pump Relay.
12 Inspect Fuel Injector Pressure Regulator -- Faulty Fuel Injector Pressure Regulator.
13 Inspect Ignition Switch -- Improperly Connected or Faulty Ignition Switch.
14 Inspect Starter Drive -- Faulty Starter Drive.
15 Inspect Fuel Injector -- Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer -- Clogged or Dirty Fuel Pump Strainerat.
17 Inspect Engine Control Computer -- Incorrect Operating Information Being Delivered and Sent From The EEC.
18 Inspect Fuel Tank -- Fuel Tank Empty.
19 Inspect Carburetor -- Carburetor Flooded or Faulty Choke.
20 Inspect Distributor -- Worn, Loose, or Incorrectly Installed Distributor.
Aug 17, 2011 | 1993 Mitsubishi Mighty Max
My mitsubishi eclipse 95 gs wont start and theres no light on my dash bored it will cranck but wont start at all i need help asap
Since the engine cranks, the battery, starter motor/starter motor solenoid are most likely
good, so suspect everything else on the list. When you narrow it down, re-post with a
more specific question about that particular component, since 100s of components must operate
nearly perfectly for a vehicle to actually start.
3 Inspect Battery Cable Connector -- Broken/Corroded/Loose.
4 Inspect Fuel Filter -- Clogged or Dirty Fuel Filter.
6 Inspect Wireset (aka Spark Plug Wires) -- Worn, Damaged or Faulty Spark Plug Wire(s).
15 Inspect Fuel Injectors -- Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer (inside fuel tank) -- Clogged or Dirty Fuel Pump Strainer.
17 Inspect Engine Control Computer -- Incorrect Operating Information Being Delivered and Sent From The EEC (faulty computer)
20 Inspect Distributor Cap -- Worn, Loose, Cracked, or Incorrectly Installed Distributor Cap.
21 Inspect Distributor Rotor -- Worn, Loose, Burnt contact surface
22 Test/Inspect Neutral Safety Switch -- Faulty Neutral Safety Switch
Aug 16, 2011 | 1995 Mitsubishi Eclipse
My car wont start
5 Inspect Coil - Ignition -- Faulty Ignition Coil.
11 Inspect Relay - Fuel Pump ----- Faulty Fuel Pump Relay.
12 Inspect Fuel Injector Pressure Regulator --- Faulty Fuel Injector Pressure Regulator.
13 Inspect Ignition Switch --- Improperly Connected or Faulty Ignition Switch.
14 Inspect Starter Drive --- Faulty Starter Drive.
15 Inspect Fuel Injector --- Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer ---- Clogged or Dirty Fuel Pump Strainerat.
Mar 17, 2011 | 1995 Buick LeSabre
New fuel pump and still wont start
1 Inspect Battery Battery Discharged or Faulty. 2 Inspect Battery Cable Corroded, Broken, Shorted or Poorly Connected Battery Cable. 3 Inspect Distributor Cap Distributor Cap Cracked or Burned. 3 Inspect Fuel Filter Clogged or Dirty Fuel Filter. 5 Inspect Coil - Ignition Faulty Ignition Coil. 6 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s). 7 Inspect Spark Plug Incorrectly Gapped or Fouled Spark Plug(s). 8 Inspect Starter Starter Motor Faulty. 9 Inspect Fuel Pump Low Fuel Pressure. 10 Inspect Solenoid Switch Faulty Starter Solenoid Switch. 11 Inspect Relay - Fuel Pumpat Faulty Fuel Pump Relay. 12 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator. 13 Inspect Ignition Switch Improperly Connected or Faulty Ignition Switch. 14 Inspect Starter Drive Faulty Starter Drive. 15 Inspect Fuel Injector Dirty or Worn Fuel Injectors. 16 Inspect Fuel Pump Strainer Clogged or Dirty Fuel Pump Strainerat. 17 Inspect Engine Control Computer Incorrect Operating Information Being Delivered and Sent From The EEC. 18 Inspect Fuel Tank Fuel Tank Empty. 19 Inspect Carburetor Carburetor Flooded or Faulty Choke. 20 Inspect Distributor Worn, Loose, or Incorrectly Installed Distributor.
May 22, 2010 | 2000 Dodge Caravan
Wont start turns over but no start
1 Inspect Battery Battery Discharged or Faulty. 2 Inspect Battery Cable Corroded, Broken, Shorted or Poorly Connected Battery Cable. 3 Inspect Fuel Filter Clogged or Dirty Fuel Filter. 3 Inspect Distributor Cap Distributor Cap Cracked or Burned. 5 Inspect Coil - Ignition Faulty Ignition Coil. 6 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s). 7 Inspect Spark Plug Incorrectly Gapped or Fouled Spark Plug(s). 8 Inspect Starter Starter Motor Faulty. 9 Inspect Fuel Pump Low Fuel Pressure. 10 Inspect Solenoid Switch Faulty Starter Solenoid Switch. 11 Inspect Relay - Fuel Pumpat Faulty Fuel Pump Relay. 12 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator. 13 Inspect Ignition Switch Improperly Connected or Faulty Ignition Switch. 14 Inspect Starter Drive Faulty Starter Drive. 15 Inspect Fuel Injector Dirty or Worn Fuel Injectors. 16 Inspect Fuel Pump Strainer Clogged or Dirty Fuel Pump Strainerat. 17 Inspect Engine Control Computer Incorrect Operating Information Being Delivered and Sent From The EEC. 18 Inspect Fuel Tank Fuel Tank Empty. 19 Inspect Carburetor Carburetor Flooded or Faulty Choke. 20 Inspect Distributor Worn, Loose, or Incorrectly Installed Distributor.
Jul 02, 2009 | 1997 Ford F250 SuperCab
WONT START
Not so many reasons she won't start. 4-Strokes are Simple!
Here they are:
Motor:
Fuel Tank-> Fuel Line-> Fuel Filter-> Carb-> Intake (Valve)-> Piston-> Exhaust (Valve)-> Muffler
Carb (Old Style):
Fuel Side:
Fuel Bowl-> Float-> Needle Seat-> Fuel Ports (Venturi)
Air Side:
Air Filter-> Carb Air Intake-> Butterflies (2)
(Clean 'em ALL!)
Hardware (Motor):
Rotor (Magnets)-> Magneto (Ignition Coil)-> Spark Plug Wire-> Spark Plug-> Cylinder Head (Spark Plug Ground)
Ignition:
Kill Switches (Seat, Clutch, etc.)-> Spark Plug/Ignition Coil-> Ground
Key Ignition-> Battery->Starter/Generator
If one of those fail.......= Non-Starting 4-Stroke!
Fixes-
Fuel:
You are either getting too much, or too little. Too much = Carb.
Too little = Carb. Therefore, tear down the Carb (COMPLETELY-Careful!) and clean it up.
Electrical:
Grounding out the System (Kill Switches)
Battery-> Ignition-> Starter.
Magneto->Plug Wire->Plug (Check 'em all!)
May 28, 2009 | Mtd Garden
1996 S-10 cranks but no fire
did you check to see if fuel pump is pumping. fuel filter isnt clogged is it? but you're sure there is no spark. because if there is spark it could be air flow problems.
and you changed the ignition switch so that's not it, how about the starter. is there any noise coming from the starter when you turn key? if it isn't lined up right.
there has to be spark if you did what you said take off a wire at night and try it . electricity to start goes, ign switch battery starter(is there a relay on s10s cant remember), the alternator is here also.to coil/distributor to wires to plugs to gasoline
also it could be the wires coming from the battery , check them for corrosion. if they are really corroded could be problem. and make sure your ground is good contact. ive seen corrosion inside wires causing no spark.
just a few ideas to check.
Feb 25, 2009 | 1996 Chevrolet S-10 Pickup
Raymarine Linear Feedback Unit For Outboard Engines, 12" Logo
283 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
