Question about Sanyo PLC XU35 Multimedia Projector
Where do i get a controller for the projector
  • 75 Answers
You can contact Sanyo USA and they will provide you with a dealer in your area to be able to purchase thru them. There is a website remotes.com that can sell to you as well. I think they will be a little more expensive.
Posted on Jun 05, 2010
Do you know if the Epson Remote 151944201 will work for my Epson Projector Emp-6110 also known as 6110i
this remote control works for all the Epson Projector, Have a good day! We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. Jerry Lampdeng Limited
Oct 24, 2014 | Epson Replacement Remote Control Projector...
Projector only in stanby mode does not switch on
This projector provides two different remote control codes; the factory-set, initial code (Code 1) and the secondary code (Code 2). This switching function prevents remote control interference when several projectors or video equipment are operated at the same time.
When the projector is operated in "Code 2," both the projector and the remote control must be switched to "Code 2." To change the code for the projector:
Select either "Code 1" or "Code 2" in this Setting Menu.
To change the code for the remote control:
Press and hold both the MENU and IMAGE buttons together for more than 5 seconds. After changing the code, make sure the remote control operates properly.
Remote control
Press and hold MENU and IMAGE buttons for more than 5 seconds.
You can change the brightness of the screen.
High ...... Brighter than the Normal mode
Auto ...... Brightness according with the input signal
Normal ... Normal brightness
On start
Note:
•When different codes are set on the projector and on the remote control, any operation cannot be made. In that case, switch the code on the remote control to fit the code on the projector.
•If the batteries are removed from the remote control for a long period of time, the remote control code will be reset.
Mar 12, 2013 | Office Equipment & Supplies
I have a Epson lcd projector mp-x3 the lamp light is blinking so I replaced the lamp and the lamp light is still blinking and there is no light do I need to reset the lamp if so How do I do thatMukrray
Connect the power cable, power on the projector and then press the [Menu] button on the remote control. The configuration menu will be displayed.
Select Reset Lamp Timer from the About menu, and then either press the [Enter] button on the remote control or the [Auto/Enter] button on the projector's control panel.
Select Yes, and then press either the [Enter] button on the remote control or the [Auto/Enter] button on the projector's control panel.
The lamp operating time will then be reset.
Aug 11, 2011 | Epson EMP-X3 LCD Projector
Miss operation to launch "Control
When the control panel lock ON of the projector so that the projector can be operated only with the REMOTE CONTROL.
If you loos your remote control then keeping the POWER key on the projector control panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you press and hold the MENU key for about10 second when the power is on the lock will be released and "panel key lock" is automatically set to "OFF"
Feb 23, 2011 | Sony VPL-CX70 Multimedia Projector
My projector pt-lb10e cannot start up, the standby light is on but when try to press the on button nothing works. How can i reset the projector?
The "CONTROL KEY" may be set to "OFF".
In order to set the "CONTROL KEY" to "ON" without using the remote control unit, keep holding down the ENTER button on the projector and press the MENU button for more than 2 seconds.
Sep 16, 2010 | Panasonic PT-LB10E Multimedia Projector
This projector was given to me by a friend. The control buttons on the top of the projector do not seem to work. The projector seems to work fine otherwise. Any idea what the problem could be?
The projector was in security mode B which lock all of the projectors controls. I found the solution to this problem in an online manual for the projector. The solution is this button sequence: power-- enter-- power--enter-- power--- enter-- menu. This sequence unlocks the projector controls by resetting the security password.
Dec 17, 2009 | Sharp Notevision PG-M20X Multimedia...
Remote control
Remote of projector just control projector only and wont do questioned / asked job as power point slides are in laptop / desktop.
Sep 12, 2008 | Sanyo PLC XU35 Multimedia Projector
EPSON OWERLITE PROJECTOR REMOTE CONTROL does not turn the projector on/off
my epson projector epson eb-g5100 is locked the control panale can not prees any key in the rer control panal and i lost my remot control how to reset my projector setting to defoult setting
May 02, 2008 | Office Equipment & Supplies
Remote control for HP mp2220 projector
possibly it the remote controls battery that needs to be changed
Mar 11, 2008 | HP mp2220 Multimedia Projector
Sanyo PLC XU35 Multimedia Projector Logo
54 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
