Sound device is uninstall
I want to install sound device in my computer.
can you tell me? from where and how?
    Scholar:
  • 75 Answers
firstly do u have the sound drivers as an .exe file ... if so just run this file on your system and it should install everything needed for your sound card including drivers and software....
the other method would be to get the driver file and save it on your desktop or somewhere u can access ....and this is for a non .exe driver file...
go to device manager > right click on the unknown device ..in this case its your sound > go to update driver> and point to where u save your sound drivers and install....
Posted on Apr 21, 2008
No sound
on board audio... remove all traces of software (uninstall sound card software) remove device (uninstall sound device in device manager)
restart computer, if it finds sound device, install software.... if it doesn't, turn off sound card in CMOS and install daugter card sound board dependant on available expansion slots
Apr 16, 2012 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
I purchased d845grg but when i install sound driver it give error "NO SOUND DEVICE "please tell me which driver should i install
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
you might have to get a portable usb sound card if you mean dont have a sound card installed
hope this helps
don
Feb 21, 2011 | Computers & Internet
Please tell audio drivers
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
Jan 29, 2011 | Matsonic 8328E (MS8328E) Motherboard
There is a sound problem. i installed window xp recently , after that i installed drivers everything is done but sound driver is not performing so please tell me solution right now
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver or scroll to sytem speaker right click select properties you will see at the bottom use this device enable/disable this device
hope this helps
Nov 26, 2010 | AMD Sempron 2800+, 1.6 GHz (G54222)
My sound from my laptop turned scratchy
Try using an external speaker or headset. If the the scratchy issue does not happen again then its your internal speaker. If the issue persist, try uninstalling and reinstalling your Audio Driver. Make sure that you have the disc that came with your computer for reinstallation of the audio driver.
If you have Windows XP:
[Control Panel > Add/Remove Programs] to see if there is a dedicated removal program and if so use it.
More likely you'll have to go to [Control Panel > System > Hardware > Device Manager > Sound, video and game controllers > (Your sound card) > Driver > Uninstall], a reboot will almost certainly be required.
If you are using Windows Vista or Windows 7 follow this:
1. Open the Control Panel (Classic View).
2. Click on the Device Manager icon.
3. Click on Continue in the UAC prompt.
4. Click on the + sign next to the device you want to uninstall to expand it. (See screenshot below step 5)
5. Right click on the listed device and click on Properties.
NOTE: You can also click on Uninstall and go to step 8 instead.5439d1232212816t-uninstall-device-device-driver-device_manager.jpg
6. Click on the Driver tab. (See screenshot below step 7)
7. Click on the Uninstall button. 5440d1232212816t-uninstall-device-device-driver-properties.jpg
8. To Uninstall Only the Device -
NOTE: This will only uninstall the device and leave the device driver still installed for the device.A) Uncheck the Delete the driver software for this device box. (See screenshot below step 9)
NOTE: If you do not have this option, then only the device will be uninstalled. Go to step 10.
B) Click on OK.
NOTE: Sometimes, you may be prompted to restart the computer to finish uninstalling the driver. If you do, then click on Yes to restart the computer.
B) Go to step 10.
9. To Uninstall the Device and Device Driver -
NOTE: This will uninstall both the device and device driver software installed for the device. A) Check the Delete the driver software for this device box.
B) Click on OK.
10. Device Manager will now no longer have the device listed. (See screenshot below)5442d1232212816t-uninstall-device-device-driver-device_manager_uninstalled.jpg
11. Close Device Manager. (See screenshot below step 5)
Restart your computer. Once the computer restarts, it will automatically detect your hardware. Or you can manually install the driver that came with your computer
Aug 17, 2010 | Computers & Internet
Last day I did uninstall my sound device
You need to install driver for your soundcard. Usually it is on manufacturer CD or you can search the driver on google. Also search for your mainboard drivers. There must be your soundcard driver.
Aug 24, 2009 | Computers & Internet
My computer cannot detect my multimedia audio controller
Download Microsoft UAA drivers for your O/S
Uninstall your sound drivers through device manager. then install the UAA drivers and REBOOT
then install your sound drivers
The only thing I can think of was you did not reboot after installing UAA drivers
Nov 10, 2008 | Intel D845GVSR Motherboard
My computer cannot detect multimedia audio controller
Download Microsoft UAA driver then install it
Uninstall any sound driver first then
Go to device drivers and update your sound driver will go on net and find them and install them
Nov 01, 2008 | ASUS P5S800-VM Motherboard
No audio output device installed
does your sound system work before
what windows you are using xp or vista ??
Aug 15, 2008 | Toshiba Satellite A135-S2386 Notebook
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
