Question about HP Compaq dc5100 Small Form Factor PC Desktop
WHAT GRAPHICS CARD WOULD FIT INTO A HP DC5100 SMALL FORM AS IN NOT SURE IF IT IS PCI OR PCI-E AND THE CASE IS SMALL
  • Adnan Bhatti
    Adnan Bhatti May 30, 2010
    You do not have option to use an add-in card. This PC does not support it.
  • 516 Answers
What Add2 card will fit in the HP 5700 small frame factor?
I understand that you want to add a second display to the
HP Compaq dc5700 Small Form Factor PC. I had checked and found that the Video adapter features RAMDAC integrated (400-MHz); Controller Clock Speed: 667 MHz; Overlay Planes: One 16 bit video overlay plane; Max Color Depth: 32-bits/pixel; Multi-display Support: Support for one VGA and one DVI-D, in conjunction with an ADD2 card, clone and extended desktop modes are supported. It specifies that the clone and extended desktop modes are supported. You may try connecting the second display and check the operation. Also the computer comes with the expansion slots 2 low profile PCI, 1 low profile PCI Express x1 and 1 SDVO/ ADD2 connector. You can go for a video card that can be connected to the PCI slot.
You can refer the link from Micrsoft for the information to How To Configure and Use Multiple Monitors in Windows XP
Nov 18, 2013 | HP Compaq dc5100 PC Desktop
HP intel dc5100 Intel Video Driver required windows seven
Hi
The motherboard in this PC does not seem to support Windows 7.
See here for confirmation:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=447280&lang=en&cc=us&taskId=135&prodSeriesId=454811&prodTypeId=12454
Since windows 7 has a large database of drivers built-in, most of the devices on the motherboard may have found compatible drivers in the Win 7 Driver Database, with the exception the on-board graphics.
The best option is to upgrade to a dedicated Windows 7 compatible PCI Express graphics card, which you can easily install to bypass the on-board graphics.
A dedicated graphics card will also free up system memory previously borrowed by the on-board graphics.
Hope this helps.
Aug 23, 2011 | HP Compaq dc5100 Microtower PC Desktop
I have an ATI - Radeon AGP HD 3450 512 mb video card. can i use it in my hp compaq dc7600 ultra slim with any problems.? can someone please help me out.thanks.
Hi Michael,
The HP DC7600 Ultra Slim Desktop only has either onboard Intel(R) 82945G Express Chipset graphics or a single PCI slot for you to add a PCI (not PCI-express) graphics card.
The system board does have a PCI-express slot, however this is not fully implimented by HP and is only used to run a secondary additional monitor from the onboard Intel Chipset graphics when used with an HP-specific adapter.
AGP is not present on the system board and is therefore not supported.
On a related note, also be aware that some PCI graphics cards required the PCI 2.2 bus standard to be supported in the PC - I have no idea if the Ultra-Slim actually supports this, so do further research to ensure compatability before purchase of any PCI graphics card for your machine.
James
Aug 08, 2011 | HP Compaq dc7600 Small Form Factor PC...
Does this hp dc5100 use sata drives
Yes it uses Sata drives.So if you are planning to use sata drive then you can.Your hp dc5100 uses sata drives.
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 20, 2010 | HP Compaq dc5100 Small Form Factor PC...
No sound on my hp dc5100
Hi, Did you install your sound drivers etc. If you havent done the instalation then your sound card will not work. Follow this process Right click on mycomputer, then properties Device ,manager and then check if ur sound drivers etc. are installed.
Jul 05, 2009 | HP Compaq dc5100 Small Form Factor PC...
HP Compaq dc5100 Small Form Factor Is two hhd
I think is not possible, because no space for additional harddisk, casing is too small, but if you release the cdrom, you can plug additional harddisk to cdrom place, but no screw mount to casing
Mar 29, 2009 | HP Compaq dc5100 Small Form Factor PC...
Graphics card
Desktop Casings are lower enough that can't be closed when inserting Cards like your Graphics card. Change your desktop casing to Tower Casing so you can freely install your Graphics card to the graphics card of your motherboard.
Jan 14, 2009 | HP Compaq d530 SFF PC Desktop
Hi there.
You can get the drivers from HP support here>>>>
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=uk&prodNameId=447291&taskId=135&prodTypeId=12454&prodSeriesId=447279&submit.y=0&submit.x=0&lang=en&cc=uk
Choose your operating system and download the drivers you need, you will need to install the chipset drivers for the audio to work properly.
Good luck and thanks for using FixYa!!
Nov 13, 2008 | HP Compaq dc5100 Small Form Factor PC...
New sound card for HP d530 small form factor..
You just have to look for a "low-profile" PCI card. Creative makes one, Audigy SE SB0570LPVP
Search that for a vendor, or low-profile for other manufacturers.
Jan 29, 2008 | HP Compaq Business d530 Small Form Factor...
What Graphics card will fit in my Hp DC5700 Intel core2 Duo?
from what i can see about your model you can fit a 256mb or 512mb PCI Express graphics card either nvidia or ATI as long as it's pci express, but the details only show one slot so not much room for more expansion.
Apr 13, 2007 | HP Compaq dc5100 PC Desktop
HP Compaq dc5100 Small Form Factor PC Desktop Logo
470 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
