Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
How do I get at the drain pump to fix a water leak
The dishwasher has a minor leak from underneath the main cupboard but I cannot get at it. Does anyone know how to dismantle the diswasher in order to get at the parts underneath?
    Problem Solver:
Would respectfully offer a diverse perspective from DOUBBLEJ34 (Though I do this guardedly since clearly this person is highly skilled and experienced in the world of FIX IT. I mean NO disrespect in my "naive" counterpoint. I would suggest that anyone who wants to try such a repair on a Bosch D/W begin by watching the following video - - repeatedly, if necessary. http://www.youtube.com/watch?feature=endscreen&v=FsjE7CTwUIk&NR=1
This video will explain the basics of dismantling a Bosch dishwasher to gain access to the mechanicals. From this video you should also be able to access some other Bosch D/W repair videos.
If you are feeling comfortable at that point, then give it a shot. Otherwise, go with DOUBBLEJ34.
If you decide to try it yourself - - worst case scenario - - The repair technician you wind up calling after surrender will appreciate not having to disconnect or remove the unit - - depending on how far you got.
Alternatively, you got to a fix, re-installed it using a repair part that doubtless cost you less than retail + repair markup, you also saved the repair call & labor cost, and you are now feeling much more skilled in the area of DIY home repair.
" Knowledge is Power."
Know this is long after the question was posted but it might prove useful to others who land here through a search.
Posted on Jun 02, 2013
  • 523 Answers
Dont even try call a tech!
Posted on May 30, 2010
THE DRAIN PUMP DO NOT STOP EVEN WHEN THE DOOR IS OPEN OR WHEN WE TURN OFF THE POWER..WHAT IS IT?/
You have leak there is an anti flood device causing your pump tookeep running have to drain the water from underneath machine best way is to pull it out and lie on it#s side let water drain off it use a few towels make sure you un plug from mains it might be only a lslight leak building up over time
Nov 30, 2015 | Dishwashers
My dishwasher will not drain completely
Most likely, the drain pump is clogged or the filter for the main pump is clogged with goo. If, during the drain cycle, water is just "peeing" into the drain line or sink drain, something is clogged. Broken glass, food, bones, etc., can find a way into the main pump mech or into the drain pump. You didn't specify what model washer you have but check the round removable filter found in a lot of Frigidaire dishwashers. Yours could be square, rectangular, etc. Get the users manual if you need help finding out how to clean the filter! Remember, if water can't move freely through the filter, your washer won't spray strongly either. Also, dishwashers will not drain out every drop of water--they will drain past where you can see the water but there will always be a small puddle of water in the motor. This keeps the seals moist and prevents dry-rotting, cracking and leaking.
Aug 18, 2015 | Frigidaire Dishwashers
Water leaking out from underneath
How to Fix a Leaking Dishwasher Hose. *. Whirlpool Dishwasher Connection ... the drain hose pushes water from the dishwasher without water buildup ...www.ehow.com/how_12089937_fix-whirlpool-dishwasher-leaks-underneath.html
hope this will help
Jan 31, 2012 | Whirlpool Dishwashers
I have water leaking under my dishwasher (probably right in the middle). I put a paper plate underneath to catch the water during the cycle. There seems to be some "soap scum" on the bottom where it is...
Hello there
Here is several ideas that will help you
also (fyi) type in search engine how things work and once it opens just enter dishwasher and it will bring you to the dishwasher section ok?
here it is
Dishwasher is leaking water
  • Inspect the seals for the main tub, float, heating element and blower diffuser
  • Check for overfilling
  • Inspect the water and drain hoses
  • Inspect the door gaskets
  • Check the water inlet valve
  • Check the pump
Water or soap leaks around the door
  • Make certain that your detergent is intended for dishwashers. Do not use liquid dish soap.
  • Inspect the door seal gasket
  • Check the door latch
  • Inspect the door hinges
  • Inspect the spray arms for damage
Water drains through the air gap into the sink
Sep 16, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher leaks from bottom left corner
If its just that corner check that it is level (if not leak could be somewhere else)
Then check your hoses and valves for holes or leaks (try putting some food dye water when running to see easier
Most likely a loose hose connector or hole in the rubber hose
This hould help you
Dishwasher Basics The main parts of a dishwasher are: Control mechanism
The control mechanism is located inside the door behind the control panel. Many units use a simple electro-mechanical system: a timer determines how long each part of the cycle lasts and activates the proper function at the proper time (such as the detergent dispenser, wash spray and draining functions). Units that are more expensive might have a computerized control system. Modern units also have a door latch that must be closed for the unit to run. Some also have child safety locks. Intake valve
This is where water from the home's water supply enters the dishwasher. The unit's pump doesn't pump the water into the basin – when the intake valve opens, water pressure drives the water into the unit. Pump
An electric motor powers the pump. During the pump cycle, the pump forces water up into the spray arms. During the drain cycle, the pump directs the water into the drain hose. The motor-pump assembly is mounted beneath the basin, in the center of the dishwasher. There are two main types of pump:
  • Reversible
    These pumps switch between pumping water to the spray arms and pumping water to the drain by reversing the direction of the motor. Reversible pumps are usually vertically mounted. dishwasher-11.jpg
    -->Reversible pump
  • Direct-drive
    The motor runs in one direction, so the direction of flow is switched from spray arms to drain by a solenoid that opens and closes the appropriate valves or switches one hose connection to another. Non-reversible pumps are usually horizontally mounted. dishwasher-12.jpg
    -->Direct-drive pump
Dishwashers can be installed in either a portable or a permanent configuration. Portable units have finished sides and top that can be used as a countertop. When not in use, the machine sits in place next to the wall. When it's time to run a cycle, the unit can be rolled on casters over to the sink, where it connects to the faucet and plugs into a nearby outlet. In a permanent installation, the dishwasher goes underneath the existing countertop and bolts into place. Hoses underneath the kitchen sink connect directly to the hot water line and the drain line, and the unit usually plugs in under the sink as well. Both types of installation require a 120-volt grounded line.
Jun 07, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
No fill - drain pump running - I assume stuck float switch
remove the bottom plate of the dishwasher and the bottom pan is revealed. reason the drain pump is running will be that this pan has water in it ie you have a leak. mop out the water and dishwasher will work - switch off mains when you do this
Sep 10, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
The cupboard next to dishwasher becomes full of condensation during drying cycle
Is the machine properly lined up?
Could be a small leak at the top - won't leak water, but steam can escape maybe.
Sep 03, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
Dishwasher Leaking
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Aug 27, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
Mar 18, 2007 | Neff 24 in. S5543X2 Built-in Dishwasher
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
275 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
