Question about Samsung HLP4663W 46" Rear Projection HDTV
Noisey tv The tv is making a humming noise when turned on
  • Samsung Master
  • 5,138 Answers
Replace Color Wheel-Google to Encompass Parts Distribution and type in your Model Number
1-800-638-3328
Posted on May 30, 2010
When i start my car uo its makes this noise from the rear that sounds like the suspension its a humming noise
sounds like the air pump for the auto ride height is what your hearing.if it stops it could be normal
& pump is getting noisey, if it continues running you may have a leak in system.
Jun 19, 2011 | 1997 Cadillac Eldorado
Refrigerator is making a rather loud humming noise. It is still working fine, just noisey.Is this a problem? By the way, its only two years old. It is a GE model #GSH25JJTA SS
pull the unit away from the wall and see if the motor is gummed up with dust. motor is behind unit on the bottom. if it is, clean it off with a tolit brush. if its clean and still humming thats your motor making the noise. call a repair man.
Jan 02, 2010 | GE Refrigerators
My car makes a humming noise when excellerating and is especcially noisey when turning steering wheel to the left. there is also a continous squeak. my husband put WD40 on the bolt on power steering box...
If WD-40 got on belt, and squeak went away for a while, it may just need a new belt. The humming noise sounds like a worn wheel bearing that should be checked and replaced if needed. If squeak goes away when you push slightly on brake pedal, it may be rotor on same side as wheel bearing making the noise due to slight shifting of rotor because of worn bearing.You can try swapping tires on front from one side to other to confirm it isn't tire problem as well. If noise shifts to other side, then it's a tire.
Dec 03, 2009 | 2003 Pontiac Grand Am
Humming noise when tv starts up
Sound like the Color wheel motor is bad (noisey bearings ) It will usually get worse - louder and then stop all together Part # 5030204280 - google it.
Sep 22, 2009 | Toshiba 62HM95 62" HDTV
Humming while driving
Hub bearings,notorious for these,expensive parts.They go bad on the front and the rear.YOu need to find out which one is the noisey one,maybe more than one.I had a customer that we had to replace all four on within 6 weeks.Hope this helps
May 21, 2009 | 2005 Saturn VUE
I have a 2003 Mercedes C240. When it starts up there's a humming noise that quits after a few minutes, but when the car starts moving it starts clicking.
THE HUMMING NOISE IS YOUR SECONDARY AIR INJECTION PUMP. THEY TEND TO BE NOISEY AT START-UP. IF IT IS NOT WORKING COREECTLY IT WILL SET A CHECK ENIGNE LITE. THE CLICKING NOISE IS NORMAL IF IT GOES AWAY AFTER WARM-UP. THESE MOTORS ARE NOISEY WARMING UP DUE TO THE HYDRAULIC LIFTERS.
Mar 21, 2009 | 2003 Mercedes-Benz C-Class
Tv makes a humming noise
check for bad color wheel....may sould like a grinding sound
Mar 01, 2009 | Samsung HC-P4752W 47" Rear Projection...
Noisey front end
Change the tire. Your tires might be worping from the inside. I had the same problem. It might need an aligment too.
Jul 16, 2008 | 2003 Mitsubishi Lancer
Tv makes humming noise when on. how can I eliminate or reduce the nose?
Some of the larger TV's are DISH ready, meaning that they have the tuner inside for SAT TV. The SAT tuners often have an internal fan that makes a humming noise. If it sounds like something other than that, you might have a bad component in your sound circuit that allows 60 HZ hum through the speakers.
If it is a rear projection LCG TV it has a fan in it to cool the bulb. You will hear the fan if you listen closely. It usually cannot be heard over the volume.
The fluorescent bulb and electronics inside make humming sound naturally. Kinda like when you turn on a lamp, and some lamps make a low humming sound.
Apr 03, 2008 | Televison & Video
Samsung HLP4663W 46" Rear Projection HDTV Logo
246 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
