Question about Hotpoint WMA50 Front Load Washer
Select program, water fills then nothing happens. Have to cancel program to empty water to retrieve washing.
  • k325 May 30, 2010
    Thanks for that, luckily I'm not bad with a soldering iron, so will have a go.
  • Hotpoint Master
  • 1,525 Answers
Hello sorry to say sounds like the programmer may be the trouble i was luck when i repaired mine there were dry joints on ther circuit board on the back of the programmer it's worth a try if you know someone that can use a soldering iron good luck
regards
shaun
Posted on May 30, 2010
Hotpoint WMF760 fills but won't wash
http://www.how-to-repair.com/help/faqs/hotpoint-wml540-washing-machine-that-wont-start/
Aug 30, 2016 | Hotpoint Washing Machines
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
My washing machine stopped before the end of the cycle, wouldn't drain, tried pressing the cancel button worked first time so I put the programme round to rinse and spin. It started washing again but...
hello, it sound like the pump could be blocked or the drain hose could be kinked or blocked. do a test on the washer with no clothes fill the washer see if emptys you should hear the pump. if you don't the pump could be faulty hope it helps
regards
shaun
Jan 02, 2011 | Washing Machines
The washing machine will run a complete cycle perfectly, when i then empty it and refill with dirty washing, i put it onto the programme and press start, the machine sounds like the motor is running to...
On some machines when you start a programe the pump may run for a short while Restart machine and just give it a try for 3/4 minutes first just incase.
Sep 15, 2010 | Washing Machines
Last night I tempted to clean the large duet washer with the chlorine program. After starting, I realized I only had clorax bleach for colors and reluctantly used this. Large suds formed. I paused/cancel...
Drop your drain hose to floor level with bucket under it this will drain with no power applied , pour in as much water as you can to flush it out / clear pump .After all suds clear refit / restart ..Should now fill, wash/ empty and spin...I hope ...
Apr 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Whirlpool duet front load washer
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Hotpoint WMA50 Front Load Washer Logo
77 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
