Question about Fisher and Paykel Washing Machines
Washing machine cycle far too long
I have a fisher & paykel intuitive eco washing machine trouble shooting. I have noticed recently that it is taking at approx 150min for a load to be done. 90% of the time I do a cold wash but the time factor doesnt seem to change when I do a hot/warm cycle. I have gone through the manual and done a Factory reset, did not change, clean filters to hoses at tap end of machine, did not change, I have also done a clean bowl cycle as well Can you help
Thanks Fiona
  • 159 Answers
Hi Fiona.I believe the cold valve is probably faulty & is not flowing fast Its probably dribbling water in?taking forever to fill.the machine should be giving up & beeping at you if thats the case.If you have a faulty cold valve then switching to warm won't help as the hot valve will close itself off to compensate for the lack of cold water..afterall you have told the machine to fill with warm,,if it cant make warm water because of a faulty cold valve then the hot will decrease to a point where its not letting any water thru..try a hot only wash..if it goes thru wash cycle ok then good chance its cold valve problem.wow i hope that helped.
Posted on May 30, 2010
Fisher & Paykel GW612 won't spin
you want to check the drain pump if there is nothing stuck there sometimes a drain restriction will cause the machine to stop
Jan 27, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
May 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Have an eco washer gwl 10. worked fine for years today stopped wokring. tried all trouble shooting and diagnostics. always coming up error code 43. replaced switch and no different. any idea?
Hi there
Try bridging the switch out(join the wires together) and if that doesnt work you may have to replace your motor controller module.
I hope this helps.
Nick
Aug 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Intuitive Eco switching itself off during cycle.
Could be a bad drain pump or controller or rotor position sensor. You will need a Tech to take a look. Unfortunately with these machines there can be many reasons for a failure. Call F/P to get a certified technician out there.
Jun 14, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
How do i put intuitive eco on to just spin clothes not a whole wash cycle
press power button press up button 2 times on option button to "wash advance" press adjust button to which ever rinse cycle youd like to use. press start.
Jun 05, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco w.machine showing error code 130 and sometimes 240
switch the power off for a little while minute or 2 & turn it back on and press the power button and pstart the cycle again.
Apr 05, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
186 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
