Question about Dualit 20247 2-Slice Toaster
Dualit toaster the inside elements of my toaster are not working which means i have to keep turning the toast to cook both sides. i cant seem to find any where in melbourne, australia who can fix it.
  • 1,711 Answers
You van by the elements fromebay uk they are so slim and light that they shipp them in normal envelope and arive in no time.
You can follow the instruction in the link what to order and how to replace.
We have the procedure here in this link
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
Good luck
Posted on Aug 20, 2010
My toaster only toasts one side - is it the rocker switch or can 2 elements blow at the same time
they can blow at the same time
turn the toaster on without toast and see if both elements light up
if not consider a new toaster as the element and repair costs will exceed a new unit
Aug 06, 2016 | Dualit Kitchen Appliances - Others
1978 ge toaster
Their website claims that the ProHeat elements fit toasters made in the last 50 years...
I would say take the thing to a good electrician, and she can inspect one of the ones that still works, compare it to the one that burnt out, and come up with some sort of fix...
Nov 19, 2013 | Dualit Kitchen Appliances - Others
The toaster is only cooking on one side
u have a broken element on one side. You may be able to look inside and see the broken element. If not take the ends off it may be there. No matter it is a broken element. Keep looking for the broken element it may be slightly tacked to each broken end but not good enough to allow enough current to pass through.
Oct 07, 2010 | Dualit CTS4E 4-Slice Toaster
How do you replace a centre element of a Dualit 3 slice toaster?
You can buy the elements from ebay uk and for 110 v also, they are so slim and light that they ship them in normal envelope and arrived in no time.
Good luck
Jun 07, 2010 | Dualit 31213 3Slice Toaster
Inherited a Dualit Vario 3 Toaster without instructions
Inside your toaster there are six heating element plates four in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Nov 12, 2009 | Dualit 31210 3-Slice Toaster
The toast gets done on one side and not the other
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Good Luck
Jul 12, 2009 | Dualit CTS4E 4-Slice Toaster
The heating element doesn't work in two of the slots.
If its a Dualit model then you should be able to get it repaired. Generally replacing parts on a Dualit is not easy but spares are usually available thanks to the fact that its one of the most well known commercial toasters on the market. Google and see if there's a repairer in your area.
Apr 05, 2009 | Dualit CTS4E 4-Slice Toaster
Dualit 4-slot toaster - is this how it's supposed to work?
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Dualit Vario Combi 2x2 65-Slice Toaster
Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Dualit 20247 2-Slice Toaster Logo
409 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
