Question about HP 5500 Color Laser Printer With Internal Print Srver (554000042) Print Server
HP 5500 dtn. On start up, after INITIALIZING OK, CALIBRATING OK, display locks with message ORDER CYAN TONER. Display does not move on to READY. No buttons are responsive. Note: ALL SUPPLIES INSTALLED OK.
  • 1,675 Answers
Hi i had the same problem with mine, i found that putting the old colour back in , restarting the printer till it gets to the checking the colours again, it will obliviously say that the cartridge is out again, so then replace it with the new one, then restart it again, also check the contacts inside where the cartridge plugs into, this could have a bit of dirt on it and may just need cleaning, or try another cartridge as you can never guarantee even new ones have problems with their chips...hope this helps get back to me if still having problems..
Posted on May 30, 2010
  • 4 more comments
  • mwbrocklehur May 30, 2010
    Your solution worked up to a point. The printer now says READY, and all buttons work. However, on requesting PRINT CONFIGURATION
    Your solution worked up to a point. The printer will start up OK, and the READY mode is shown plus all the buttons work OK. However, on requesting PRINT CONFIGURATION, the green light strobes, the display says PRINTING CONFIGURATION, but nothing further happens.
  • steve morris
    steve morris May 30, 2010
    this sounds like you might have it spooloing instead of printing directly, go to settings for the printer and change this if it has not allready been changed, when you go to print click on the start bar icon to see where the print is going, it might be printing to file and not to the printer itself...hope this helps
    Thanks. I am going away on business for a couple of days, leaving now, and will try it when I return.
  • mwbrocklehur Jun 01, 2010
    This does not work as the request to print CONFIGURATION is an internal process within the printer itself, and has nothing to do with the connection from my computer.
    Every time I put the old empty cartridge pack in the printer, things seem to work OK except that obviously the cartridge is empty.
    What if I top up the old cartridge with fresh powder from the new cartridge. Do you know how I can easily get to the powder container? I could simply use a funnel and fill the old cartridge? Any ideas?
    Thanks
  • mwbrocklehur Jun 02, 2010
    The cartridge supplier is sending me a new one. Let's try that first.
Hp m5550 cyan not printing after calibration,, need an urgent answer
TRY REMOVING AND RE-INSTALLING ALL 4 TONER CARTRIDGES AT ONCE. SOMETIMES THE CYAN CARTRIDGE ISNT SEATED RIGHT. ALSO AS YOU CLOSE THE TRANSFER UNIT SEE IF ALL 4 CARTRIDGE COVERS ARE MOVING IN UNISON. GOOD LUCK !
Dec 07, 2016 | HP Office Equipment & Supplies
My printer HP LASER JET 5200 DTN shows "Ready" on the display but it doesn't print, how can I fix this?
First thing you need to do is establish whether the print engine itself is at fault, or not.
From the relevant printer front panel menu, invoke printing of one or more of the available reports (configuration, font list, etc.); do these print?
If the reports print OK, try to send some plain text to the device.
On a Windows system, you could do this by using the DOS copy command in conjunction with an appropruate net use command to redirect LPT1: to the (USB) port associated with the relevant Windows printer instance.
Jun 02, 2015 | HP Office Equipment & Supplies
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
My HP CM1312nfi laserjet has started to print a shadow behind all color text and images. The same day this started, the printer kept going into cooling mode as I attempted to finish a print job. I moved...
According to your problem first clean the toner cartridge by dry cotton carefully. May be the toner is almost finished or get damp few toner of the cartridge. Refill the toner cartridge. Then install the cartridge properly and reboot it. It will solve your problem.
Jul 25, 2011 | Office Equipment & Supplies
5 0f 6 cf message when initializing
Hi
replace all colors toners ( black magenta cyan yellow)
in order to start working again
Nov 25, 2010 | HP Color LaserJet 5500 Printer
Hi there, need your kind help. My Hp laserjet 5550 has a missing colour problem. Cyan is missing in the print out, giving rise to to blue and green colours being absent in print-outs. Scanner is confirmed...
Cyan cartridge is OK, means that the display shows the level of toner in the cartridge, right? Then chip it is ok.
Try another cyan toner, the printer may be that it has broken the opening flap of the laser. Or check if the laser's flap cyan is blocked.
Nov 14, 2009 | HP LaserJet 5550 Printer
HP 5500 can not print with 59.CK error code on display
You probally need to contact an engineer on this one, from HP trouble shooting manual
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
1. Press the green <Tick Symbol>(Select) button to continue.
2. Turn the printer off, and then turn the printer on.
3. If the error message returns, turn the printer off.
4. Perform a cold reset.
a. Turn the printer on.
b. Watch the control panel.
c. When the memory starts counting, press and hold the green <Tick Symbol> (Select) button.
d. Continue holding the green <Tick Symbol> (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
e. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
f. Press (Down Arrow) button once. The control panel will display COLD RESET.
g. Press <Tick Symbol> (Select). The printer will perform a cold reset and then continue its power-on sequence.
5. If this message persists, contact an HP-authorized service or support provider.
Sep 22, 2009 | HP LaserJet 5500 Printer
HP Color laserjet 5500 leaking toner
Make sure your using OEM toners. My best guess would be DC controller or high voltage board.
Feb 23, 2009 | HP Color LaserJet 5500 Printer
Adding IP addresses to a HP 5550 DTN printer
ok then install that printer as a network printer to one pc share ti and ad to as much pc you need after that without ip adress
Dec 10, 2008 | HP 5500 Color Laser Printer With Internal...
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
HP 5500 Color Laser Printer With Internal Print Srver (554000042) Print Server Logo
82 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
