Question about Canon PowerShot A540 Digital Camera
Broken shutter I dropped my canon powershot A540, and it seems fully functional..... but when i press the shutter nothing happens! I can't take pictures!
  • 477 Answers
Could be a loose ribbon cable or a frozen internal shutter issue. with out looking at it it is hard to properly diagnosis the issue. let me know if I can help out any futher.
Posted on Jun 12, 2008
SOURCE:
Shutter is not working - have solid orange light when shutter button is pressed but does not take pictures.
I have the same problem. If I am outdoors, the camera seems to work fine, but indoors, even with fresh batteries, it will not take a picture.
Nov 05, 2010 | Canon PowerShot A540 Digital Camera
My A540 clicks like it takes a picture but nothing shows on the display screen. When I take the memory card out and insert to computer the frame of pictures show but the photos are black.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
But if you do notice shutter movement, then this would then likely be a CCD imager failure. It would in that case require Canon service to repair (1-800-OK-CANON).
Nov 10, 2009 | Canon PowerShot A540 Digital Camera
After one flash foto, the orange led will contiuos blinking, and after a while "replace batterie", happens wih new batterie (alkaline) and NIMH 2700 fully charged batterie
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Aug 01, 2009 | Canon PowerShot A540 Digital Camera
Wondering if you could take a delayed picture with a canon powershot A 540, would like to set it so I can get the whole family in the picture
Press the FUNC/SET button. Use up/down to select Drive Mode (the rectangle, third item from the top). Use left/right to select the desired delay and press FUNC/SET. Start the self-timer by pressing the shutter release button as usual.
Dec 29, 2008 | Canon PowerShot A540 Digital Camera
How do I use my self timer on canon powershot A540?
when in picture mode, press "set" then go to "drive mode" and choose either 10 or 2 seconds
Dec 10, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Can't find canon powershot a560 self timer
Dec 03, 2008 | Canon PowerShot A540 Digital Camera
Canon A540
The date will only show up on the picture under a limited set of circumstances on the Canon PowerShot digital cameras, of which the A540 is one. You've probably found the Date function in the menu, but discovered that it was off, grayed out, and skipped over whenever you tried to reset it.
Date stamp will only work in "Postcard" mode. Press the Function button (labeled "FUNC SET"), then press the down button until you reach the Recording Pixels selection (usually labeled "L", but not always). It's probably the bottom onscreen selection. Use the right or left buttons to select Postcard, then press the Function button again.
Press the Menu button and scroll down to Date Stamp. Now you should be able to select "Date" or "Date & Time" with the right or left button. Press Menu again and take your pictures.
Sep 29, 2008 | Canon PowerShot A540 Digital Camera
Canon Powershot A540 - Change Batteries when Batteries Fully Charged
May 27, 2008 | Canon PowerShot A540 Digital Camera
Delay in taking pictures
Shutter release button has two positions. Auto focus function activate first when u press butten halfway(u can see a focus indicator icon with beep sound).Now if u press it some more, camera will take snap at earliest .So pl confirm the subject to be focused by keeping the button half way pressed then press it some more at the right moment.Also cancel the red eye reduction function when u r using flash because it creates more delay .
Nov 26, 2007 | Canon PowerShot A540 Digital Camera
Canon PowerShot A540 Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
