Question about Refrigerators
Ny aeg fridge is not cooling now showing +12 oc all lights on & display seems OK I can hera a slight "girgling noise from within the fridge
  • 327 Answers
Hello,turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
Thanks
Posted on May 30, 2010
Tumble Dryer AEG T65270AC isn't heating up
thermal cutout switch usually attached next to the element (little round thing riveted either side)
Sep 25, 2017 | AEG Dryers
Fridge water sound
This kind of noises produced gas in cooling system.
In the old coolers never heard sounds like streaming water because the compressors were very loud due to high pressures (12 bars or more), which were required for efficient cooling. Today we use more ecological gases which work (from 5 to 6 bars) at much lower pressures, thus compressors produce much less noises and now suddenly we hear sounds that never before heard. Generally speaking noises is lower, measured in decibels.
Dado
Feb 01, 2014 | AEG Freezers
S75400kg fridge not cooling
Suggest you try completely defrosting and restarting.
Feb 18, 2012 | AEG Refrigerators
Aeg 71840i integrated fridge freezer. freezer fine but fridge not cooling. light on but not chilling food
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | AEG Refrigerators
MY fridge freezer Model Santo C61841I is not cooling
My Santo C61841i has stopped cooling. Power and the fuse is ok (light still comes on), its 8 years old is it worth repairing or buying nes
Aug 11, 2009 | AEG Refrigerators
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
Samsung twin cooling fridge/freezer model Rs21dcsv Fridge temp control led display digit flashing and fridge not at right tempreture
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Jul 31, 2008 | Refrigerators
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
Most likely it is the Main Control Board also called the Motherboard. It is located on the rear of the unit behind the smaller axcess panel. Becareful with the wiring if you attempt to change the board. There is a slight possibilty that it is the dispay board, but it is unlikely.
Nov 25, 2007 | GE PFS22SISSS Stainless Steel French Door...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
