Question about HP vs15 15"LCD Flat Panel Monitor
My HP 15'' lcd has suddenly stopped displaying, can youhelp in this
  • 11,361 Answers
Power supply section will be the first place to check.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 30, 2010
My camera nikon d3000 suddenly stopped working...the lcd has no display,and even the viewfinder...it happenned today..it was so sudden..i was clicking pictures and suddenly it stopped working
Try resetting the camera by removing the battery for 15 mins, replace the fully charged battery, go to the Menu setting and set the Date and Time.
If it still does not work then - this camera needs to be sent away for repairs. Just like a motor vehicle, some repairs to your camera require a technical specialist to fix your problem.
Apr 18, 2012 | Nikon D300 Digital Camera
No video from my monitor. i have a hp pavilion 1520.
- plug an external monitor
- if there's a display on the external monitor, the LCD is defective
- if there are no display at all then its a graphics card issue
May 22, 2011 | HP Compaq 1520 15 in. Flat Panel LCD...
HP printer all-in-one model2410xphotosnart keeps giving me the message to remove and check print cartridges which I have done and both are full. Will not stop blinking and when trying to print makes...
Welcome to Fixya
This means the the printer cannot determine which cartridge is causing the error. Make sure that you are using original HP cartridges.
Please see troubleshooting procedure below:
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts. Click here to see how.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  3. If replacing cartridges fails to correct the problem, click the link at the top of this page to contact HP.
Thank you for using Fixya!
Apr 03, 2011 | HP Office Equipment & Supplies
While playing video aur audio...video suddenly stops like pause and make large sound than starts again.and if watching movie it repeats after every 15 minutes...........model hp pavilliondv4...
you need to update the direct x and update video display card drivers.
download http:// microsoft.com/directx
check your which directx version you have
type in run dxdiag.
Jun 08, 2010 | HP Pavilion dv6000z Notebook
Scanner error 6
my hp 3052 suddenly stops, and there is a display "scanner error 6,turn off then on" Of course i did turn off and on several times but it keeps on coming back.
Apr 27, 2008 | Office Equipment & Supplies
HP NX9030 15" display problem
Well the most common problem in this series is a bad inverter.
If you remember your LCD being RED tinted before it went dark, then the backlight has failed. Backlight replacement is typically $150-$200. But I see 15" LCD screens in good used shape for $80-$160. There are multiple LCDs on your laptop and we would need the exact part number off the back of the screen to give you an idea what to search for.
If you still suspect the inverter, the nx9000 series are the same as the presario 2100 and 2500, as well as pavilion 4000 and 5000 series. They are NOT the same as DV4000, DV5000 or V2000 inverters can be had for $20-$40.
I would hit up ebay there are tons of parts there for these.
Dec 28, 2007 | HP Business Notebook NX9110 Notebook
Brightness is not working
15" samsung monitor have display is blard, what is cause and remedy
Dec 12, 2007 | HP L1520 15" LCD Monitor
HP vs15 15"LCD Flat Panel Monitor Logo
132 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
