Question about Car Audio & Video
I just bought a 2005 Honda civic type s and the stereo is locked, i have pressed buttons 1-6 and power and have the numbers U3003L1390, can you please help, John.
  • 1,675 Answers
I discovered a very easy and FREE way to fix your radio. Make sure your radio is OFF. Hold down the preset buttons 1 and 6 at the same time. Turn the radio on and your SERIAL NUMBER will appear. 4 numbers first and then 4 more. Write them down (obviously) then call (800) 999-1009. Make sure you have your VIN number handy because they will ask for it. They will ask for your name and approx. mileage, and your radio's serial number. They will then give you your radio unlock code -- WRITE IT DOWN....hope that helps
Posted on May 30, 2010
I bought a honda civic sport 2005 got it resprayed and i built it up and now the alarm keeps going off the key fob doesnt work etheir the battery has been flat . does any body no how to reset the fob or...
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press lock or unlock button. Within 10 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
IMMOBILIZER CAN ONLY BE SET BY DIAGNOSTIC EQUIPMENT
May 13, 2011 | 2005 Honda Civic
Problem with sterio code for honda civic LX 2005
Are you looking for a code to unlock your stereo ?
Jul 01, 2008 | Alpine CDM-7833
I just changed the battery in my 03 civic and need the codes for the stereo. Any idea where i can get the code?
turn key on with your radio off then press buttons one and six at the same time while holding the buttons down press power. you will see a series of one letter and four numbers then it will blink another letter and four more numbers the combination of eight numbers is your serial number disreguard the letters....get me that and ill get you a audio code
Oct 30, 2010 | 2003 Honda Civic
Unlock my 2005 honda civic radio
only dealer can get you code they will need your serial number on the radio to get you code or really check your car mauals
Jan 29, 2010 | 2005 Honda Civic
I cannot find the radio code. I bought the car
If you have the owners manual the dealer has probably put it somewhere in it. It is a 5 number series of 1 thru 6. If you cannot find it in the owners manual. Turn your stereo off and press and hold the #1 and #6 buttons on the radio. While holding them press the power button and that will give you the ser. # of the radio. You can contact your dealer and they can supply you with that info. Or you may have to contact the radio supplier for the code.
Aug 17, 2009 | 2007 Honda Civic GX NGV Sedan
I have a 98 Honda Civic EX - the power locks do not work. I have checked the fuses and replaced the control box in the driver door. Still not working. I bought the car used and it has an after market...
The remotes 'die' after a few years of use. I have a 98 EX and am currently on the third remote. However, before you go and locate a new one, you need to know that part of programming the new remote requires the original sound system which has a button that has to be pressed and held to cycle the new remote so it will work with the door locks.
May 01, 2009 | 1998 Honda Civic
I dont have radio code of civic 2005
Look through the glove box for what looks like a white credit card, the "Code card". The code can be four or five digits depending on automobile and stereo. Many times, dealerships write the code on a piece of tape or label and may place it in one of several areas. On one of the sides of the glove box, on the bottom of the ash tray, in the trunk on the trunk lid, in the trunk on the bottom of the package shelf, or in one of the door jams. Check the owners manual, the code may be written in on the stereo pages, one of the covers or other pages by the previous owner. On rare occasions, the code may be written on the stereo.
However, if this does not help, your local dealership parts or service dept can retrieve the code if they are given the serial number of the stereo. There are two possible ways to find the serial number. One, remove the stereo and locate the serial number from one of the labels on the stereo. Two, with the stereo off, push and hold preset radio button 1 and 6 while turning the stereo on, four digits should appear in the display for several seconds followed by four more digits, this is your stereo serial number.
Nov 17, 2008 | 2005 Honda Civic
2005 Honda Civic Radio
you need to get the unlock code
Aug 06, 2008 | 2005 Honda Civic
I need to reset my radio anti-theft code. Currently, when I press the radio buttons, (eg. number 1, it says, " code 1, press number 2, it says code 2.. and so on to number 6 button. I have the code...
This will fix it. I just did mine. You do NOT need to pull out your stero to get the Serial Number.
If you lost the code, you may retrieve it from https://radio-navicode.honda.com/
Jul 23, 2008 | 2004 Honda Civic
2005 honda civic stereo code
check your log books or get it from your honda dealership
May 24, 2008 | 2005 Honda Civic
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
