Question about LG Washing Machines
LG front load washing machine WD-8023FB. On power up at the wall - beeps normally. Pressing the power on button does not show any sign of life on the front panel (micro switch on display board tests OK). I have the circuit board exposed and a normally hidden red LED comes on at power up. If I disconnect all the connectors except power the LED display flashes error 35, so the circuit board is mostly working. Other than replacing the 6871ER1010A circuit board what else might it be?
4 Suggested Answers
  • 1294 Answers
SOURCE: LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Posted on Jan 06, 2008
localwonder
  • 6784 Answers
SOURCE: LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Posted on Jun 21, 2009
  • 122 Answers
SOURCE: Hi I've got Washing Machine LG
the alarm is indicating that the machine is not working that u should restart it or better still u check the mabual for p[roper operation
Posted on Jun 24, 2011
Washing machine
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
Lg wd-1438rd wont turn on
It sounds like when you moved the machine it pulled a plug off inside the machine, the only way to find out is to disconnect the power and remove the top of the machine, You will be able to see if anything is not connected as it should be.
May 14, 2017 | LG WM2077CW Laundry XL Front Load...
Hi I've got Washing Machine LG WD-8023FB front load, and SE or 5E alarm is on and machine is not working. What is that alarm for?
Jun 24, 2011 | LG Washing Machines
My aged invalid mother has a front loading LG washer dryer combo and has washed the same garment 3 times and after wash cycle or drying cycle can't seem to get the door to open to remove the clothes. What...
Hi I hope you solved this by now but I thought an answer might be useful if anyone else has the same question. I am not an expert just an owner of a LG WD-1412RD. It sounds like your mum is not aware this is just the normal safety cool down period following drying (as the stainless steel interior gets very hot during drying). The Door lock sign (small red light) is on, and the display shows Cd during this time, then it beeps and the door unlocks by itself. If you need to remove your laundry earlier than this, you can press the START/PAUSE button to end the cycle (it still takes a couple of minutes). This is covered on p 21 - 22 of the owners manual. which can be downloaded from the LG site. http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Nov 28, 2010 | LG WD-14124RD Front Load Washer / Dryer
The display screen is showing CL. Nothing is
CL is child lock. See your users manual for unlocking the child lock procedure. Usually it involves pressing 1 or 2 buttons for 3 to 5 seconds. Many machines actually have a lock button you press for 3 - 5 seonds. Others use the stop pause button.
Kelly
Aug 30, 2010 | LG WD-1280FHD Front Load Washer
LG WM-2277HW Front Load Washer CE error message
Hi
The CE is for Child lock system error. i just had one on my WD-1049C. It is a system used to prevent children from pressing the buttons.
the way I fixed it on mine is by holding the temp button and the option button at the same time.
Jun 28, 2009 | LG WM-2277HW Front Load Washer
My Bosch washing machine shows error code F37 and beeps
My Bosch washing machine shows error code F57 and beeps
Dec 09, 2008 | Bosch Logixx WFT 2806 Front Load...
LG Washing machine
its hard to know without hearing it,is there somthing stuck between the drums try taking the belt off and turning the drum by hand.sorry i cant be of more help
Mar 04, 2008 | Washing Machines
Jan 06, 2008 | LG WD-16115FD Front Load Washer
Washing Machines Logo
73 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
