Question about Dell Inspiron 1501 Notebook
My computer wont charge the battery
New battery, new adapter, and my computer still wont turn on or charge the battery.
  • 3,940 Answers
If the Battery and the AC adapter have been replaced then the only thing remaining is to replace the motherboard
Posted on May 30, 2010
  • Dell Master
  • 32,281 Answers
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Worked off the battery but it wont charge or run off power cord adaptor
Check and make sure the power adapter doesn't have a fuse somewhere in it. Then chk the wattage output of the adapter. Watts should be marked on the adapter.. Now see what the computer requires. Computer info is on the sticker on underside of computer.To determine how many watts the computer needs, Note the amps the computer draws(on label) and multiply the volts(on computer again) x the amps. Answer will be your needed wattage.
Use only the adapter that came with the computer. They may look alike, but there is a difference. Make sure the computer is powered off. A full charge is needed now since the battery was dead. Allow time and don't use the machine prematurely.
Make sure the adapter output matches or betters the requirements of the computer.- Good Luck-Ned
Jul 23, 2014 | Barco R9852000 LC40 Compact PC (R98 52000,...
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
Battery wont charge at all
1. Power off the laptop. Disconnect adapter. Remove battery. Let it sit for a few minutes.
2. Reinsert battery. Replug adapter. Restart computer.
3. Does battery charge normally? If not your battery is probably bad. You can get a new one for $30-$35.
4. If computer doesn't start or stay up with the power adapter attached, than the adapter may be bad.
Jan 29, 2011 | eMachines Computers & Internet
My computer wont turn on but the low battery keeps blinking (one of the symbol things under the keyboard) and when I try to charge it it wont charge.
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Sep 06, 2010 | Toshiba Computers & Internet
My Dell inspiron 9400 wont charged my battery. Both the charger and battery are new
try to charge the battery while the computer is off for 3 hours. if that does not work, remove the battery from the computer and turn on the computer using only the ac adapter. if the computer is working fine using only the ac adapter, call your computer manufacturer for possible battery replacement
Jun 11, 2010 | Dell Inspiron 9400 Notebook
My battery is charged have a brand new ac adapter/charger but it still wont turn on nothing no charging signal nothing at all what might be the problem?
If you have a new power adapter (and it is putting out the correct voltage) and you try to turn on the computer and nothing happens, I would suspect that your motherboard has gone bad.
The good news is that you can probably find a used one on e-Bay.
Oct 10, 2009 | Dell Latitude D400 Notebook
Toshiba laptop wont turn on
Hi, you must remove the battery pack and connect with just the power adapter, and tries to turn on the computer if it operates properly and the battery problem solved
May 05, 2009 | Toshiba Satellite P105-S6104 Notebook
The little orange light that comes on when the computer is charging just flashes and computer wont trun on what does this mean?
Make sure the power cord is securly connected to the computer and that it plugged in. Are you sure the battery isn't emty?
Try taking out the battery and leave the power cord plugged in and try to turn it on.
Mar 13, 2009 | Acer Aspire 4720 Notebook
Dell Inspiron 1501 Notebook Logo
111 people viewed this question
Alun Cox
