Question about Fisher and Paykel GWL11 Top Load Washer
Noisy & will not progress to spin cycle
Machine has had rumbling noise for some time & will not now progress to spin cycle.
    Problem Solver:
  • 5 Answers
The tub must pump down before it will go into spin cycle. My pump was making rumbling noises and when I took the basket out (simple process) there were a couple of bobby pins stuck in it. (kids) Cleaned it out and checked the flowpath with a wet and dry vacuum on the drain connection. Still makes the noise. There is a small zip lock bag under the control panel that describes the trouble shooting and error codes. It also says how to go through the diagnostics steps. Hope this helps.
Posted on Jun 02, 2010
  • 159 Answers
This rumbling noise is probably the pump,is it not pumping water out now?
Posted on May 30, 2010
Why is my front loader noisy at end of cycle in spin?
Most likely the rear main bearing is bad
Jul 13, 2015 | LG Washing Machines
Noisy spinning
First make sure that the load is balanced, if you are washing and spinning a dense load like trainers etc this can cause an imbalance. If you are washing a duvet cover or a pillowcase, make sure that the loose clothes washed with it haven't migrated inside the cover or case, this happens so easily. It is always worth checking that the support feet are all touching the ground when the washing machine is empty as this can cause excessive noise
hope this helpsKind regards ki
May 11, 2015 | Washing Machines
My Kelvinator kl 15 tl toplaoder washing machine is very noisy during spin cycles and often becomes unbalanced.
if the noise is a rumble, then you have bearings failing. if it's a clunking then you have an issue with the springs. springs you can replace yourself, bearing / seal replacement is a little more in depth.
Jun 22, 2013 | Kelvinator Washing Machines
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Grinding Noise
Hope this helps.
God Bless.
Jul 08, 2009 | Maytag MED9700S Electric Dryer
Noisy spin cycle
It would be noisier than normal if it was not level.
Best way to tell if it is noisier than normal is to spin the drum by hand, there should be little or no noise from it.
If it is noisy or rumbling, or feels rough, then I would suspect that the drum bearings are worn and noisy.
An hour to complete a wash cycle is not abnormal, and they do do several rinses.
Plz rate my solution.
Thanks.
Dec 26, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Noisy
usually a noisy machine means either the main bearings have gone or the motor has got damaged/worn in some way. to check the main bearings try lifting the drum with the hand from inside or rotate the drum with the hand to see if the rumble can be felt. i cannot think what else would cause a loud humming though.
Jun 11, 2007 | Zanussi FJ1454W Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
411 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
