Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
My regrig is working but the freezer is not
Do i need a new refrig?
  • alanatbridge Apr 08, 2008
    Whirlpool ET18PKXSW10
    Top Freezer
    Fan is running...freezer is not cold enough...
    refrig seems cold
    fan blowing cool not cold air in freezer
  • Gary Davd
    Gary Davd May 11, 2010
    need the model and it is not likely that the refrigerator is working and the freezer is not because the freezer works the refrigerator are the fans funning is the compresser running is there an ice build up in the freezer??
  • 770 Answers
Have you checked the condenser area ? for blockage of dirt remove the front toe kick and make sure the condenser coil is clean also open the back panel and check that the condenser fan motor is running and the compresser is as well check that and let me know
Posted on Apr 08, 2008
I have a montegormery wart side by side regrig and freezer. The freezer working wonderful, however refrig barely keeping items cool
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 29, 2011 | Refrigerators
My new Hotpoint regrig.will be at my lake home and in the winter I set the heating thermostat to45 to 50 degrees. Will this cause the refrig. to not operate properly. Model #HTS18GBSCC Top Mount
I will be just fine at 45... they will only give trouble when you get down towards freezing... no worry...you will be okay...
heatman101
Aug 10, 2010 | Hotpoint Refrigerators
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Refrig. is about 4-5 years old and regrig side stop getting cold then the freezer followed suit-not getting cold. what should i do
Look inside the freezer on the back wall. If there is ice on the back wall the defrost heater and defrost thermostat are the usual suspects. They are both in the freezer behind the back panel.
Look for a deformed defrost thermostat. The glass heater will look burned. Both can be checked with a meter set for continuity. No continuity equals a bad part. Remove the wires from the parts before checking or a false reading will occur.
Nov 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GSS25PGMF FREEZER NOT WORKING. This morning when I opened the freezer door, everything was defrosted. The ice tray was half water. Their was frost on the inside back of the refrig. The regrig side...
You have a defrost problem. You can defrost the unit down by removing the back panel and get a hair dryer and go back and forth over the defrost. Make sure that you don't get any of the coils too hot or you'll destroy your unit. But you'll need a meter to check which part or parts are bad. Do you have a meter? But you will either need a defrost timer, defrost heater or a defrost themostat. But you'll have to have a meter to OHM out the defrost heater. If your unit beeps then you'll need to replace the defrost timer and defrost themostat. If the heater checks bad then you'll need to replace only the defrost heater.
Aug 20, 2009 | GE Refrigerators
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Jul 23, 2009 | LG LSC26905TT Side by Side Refrigerator
Refrig cooling
Sounds like the evaporator fan is not working. Check to see if you can hear the fan running in the freezer. If not running, try removing the panel in the back of the inside freezer and manually spin the fan blade . This sometimes works.
Jul 03, 2009 | Refrigerators
Refrig/Freezer not cooling
"compressor not functioning". You Probably need a New Compressor. I have a Family Member whos Refrig/Freezer Compressor had to be replaced under Warranty when it was only 2 years Old.
May 12, 2009 | Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
67 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
