Question about Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100
Motherboard problem. when i press the power button it displays floppy disk failed and it require to press f1 to continue. how to restore the previous? please help.......MCP6P M2+ Ver. 6.x
  • 3 more comments
  • Adnan Bhatti
    Adnan Bhatti May 30, 2010
    You can disable the floppy driver from the BIOS. This will ensure it doesn't check for it on start up but a better option is to remove the floppy drive.
  • Kevin
    Kevin May 30, 2010
    The answer varies on whether you have a "floppy disc" installed. Could you please advise, then I will post the required action to be taken. Kind regards
  • Robin ray Derro
    Robin ray Derro May 30, 2010
    i have no floppy disk
  • Robin ray Derro
    i have no floppy drive installed.
  • Robin ray Derro
    Robin ray Derro Jun 02, 2010
    i have no floppy disk installed
  • 4,737 Answers
Go to bios settings (Press F2 or Delete or as shown there to enter the Bios settings), and locate the "Floppy Seek Boot" and disable it. This will fix your problem. I can't give you specific answer since I am not much familiar with Biostar. But i hope at least this helps. good luck. Thanks for using FixYa.
Posted on May 30, 2010
  • Lebanon Raingam
    Lebanon Raingam May 30, 2010
    It is not necessary to for a floppy to be installed or uninstalled from the System, this feature is built-in on the bios, not with the system. Even if we remove the Floppy drive, we will always see it's icon when we open the My Computer. The only options is to set the "Floppy Seek Boot" to "disable". Good luck.
  • Lebanon Raingam
    Lebanon Raingam Jun 02, 2010
    Well done @smeeagain42, I appreciate your effort helping this way. You've added the exact steps to be followed. Keep it up.
    Scholar:
  • 77 Answers
As per nonontech's answer, when you enter the BIOS Setup, select Standard CMOS Features, then arrow down to the Floppy Disc, select "none", press f10, select "save and exit, system will reboot and it will load through to your operating system.
I have referred to the manufacturers manual for your motherboard, it is available as a download in the link as a PDF file.
http://www.biostar.com.tw/app/en/mb/content.php?S_ID=315
Kind regards
Can a failed bios update be recovered?
Do you have a floppy drive in this PC? From what I've found you you *may* be able to fix it, but it will more than likely require a floppy drive and a disk. Also, you would need another computer to be able to get the files prepared for the floppy disk, and that computer also would need a floppy drive.
In a nutshell, you would use the 2nd PC to make yourself a boot disk, then put the boot disk in the broke PC and turn it on. In theory, if all goes will, it will read the disk and restore the BIOS.
But you may have to change some files on the disk so it will boot to the BIOS recovery program.
If you do have a floppy drive in the dead PC, turn it on and see if the floppy drive light comes on at all. If it does, then the computer is trying to access the floppy drive, which may allow it to read a disk. You will stand a better chance of getting any recovery to work.
Mar 26, 2014 | Medion Computers & Internet
I have a Dell 2400 Desktop that all of a sudden won't access the login screen. It powers on then the hard drive makes noise with the green lights blinking but it then says press F1 to continue but
First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Nov 05, 2012 | Computers & Internet
When i on my system its start windows and stop and shows hdd error press f1 continue press 2 del f1 i press its booting failed
Your Hard Disk Drive is crashing or has crashed. You need to buy a new hard disk drive, and then you will have to reinstall windows and start over.
Jan 27, 2012 | Mercury Computers & Internet
Hi i have a sony vaio pcg-505gx laptop and once i turn it on it ak me to press f1 to continue and then it takes me to ascreen that sayd invalid system disk replace the disk, and then press any key what...
windows cant find the operating system to boot from check that there are disks in usb cd/dvd or floppy if there is an external floppy drive if there is nothing in these drives
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also check the Cmos battery and computer ram make sure they are securely seated
hope this helps
Jun 16, 2011 | Sony VAIO PCG-505 PCG-671L PCG-700...
What should i do, please help on my problem, it happens when i turn on the computer, it displays Press DEL to run Setup and Press TAB to view BIOS message,when i press it, it displays "a disk read...
first make sure there on no disks in the drives cd usb floppy
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
May 31, 2011 | Computers & Internet
Can't boot up computer unless i press F1 something about a floppy disk
when the pc is about to start press the required button to go into bios then by Disabling the 'floppy drive seek' option in the 'advanced BIOS features' section of the BIOS youll be fine
May 30, 2011 | Computers & Internet
No beeps, no video, fans working,
no the floppy disk is not faulty, it is normal and required that the floppy disk drive light blink to indicate that the drive is working. And about the power on the power button might be stuck inside that is why it keeps turning on immediately you connect to main power
Aug 03, 2010 | Intel D845PESV Motherboard
Soyo KT400L-2AA5 Motherboard - CMOS checksum error - Defaults loa
This message is usually accompanied by another more explicit, like: "Memory changed from 1GB to 2GB. Press F1 to continue". The message should display and go away after pressing F1. Since you cannot press F1 because the keys do nothing, chances are your keyboard is disconnected, which should display a message indicating this failure.
Try pressing the ScrLk (Scroll Lock) key as messages are being displayed to catch all
messages (they go by quickly) and stop them before they disappear.
If that's the case, then reconnect the keyboard and try again.
Aug 20, 2009 | Soyo AMD KT400 Dragon Ultra Black (K7VX4B)...
Same problem
You need to flash the bios to a newer version for this cpu to be supported by your motherboard. Your descriprtion says asus so go to www.asus.com; click on the support link; lookup your specific board model #; select the operating system you are running. Download the latest bios file and follow the directions on the download site for proper flashing. Once you have flashed the bios everything should identify properly and allow you to continue setup. Hope this helps.
Jul 19, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Do I really need a floppy disk to do an upgrade bios?
Of course floppy is the easiest but if you configure a flash drive with flash drive utilities to be bootable, and the BIOS will support it you can flash from the USB flash drive.
Mar 21, 2008 | ASUS P4S800D-X Motherboard
Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100 Logo
200 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
