Disc drawer pops open when trying to burn video
Disc drawer pops open when trying to burn video on to said disc all most streight away
    Problem Solver:
  • 12 Answers
You may have a virus, scan your computer
Posted on May 30, 2010
Magnavox ZV457MG9 A DVD drawer won't open
one of the faults with the home dvd player it seems we have to open them to remove the stuck dvd .and more often than not we end up braekingthe danged thing anyway
Mar 15, 2015 | Magnavox Televison & Video
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Cd disc drive on Toshiba laptop pops open when i try to burn disc
Please make sure you have enough space available on your disc.Please switch to a new empty disc and let me know if you get the same error.Before trying with a new disc restart your laptop and then burn with the new disc.
Thank you.
Aug 13, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Dvd drawer wont stay closed
take it back to the store or repair shop. Same thing happened to a friend and because it was new, the machine was exchanged.
Jan 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
CANNOT OPEN PLAYER
To open the drawer, unplug the unit while the power is on (so that the drawer doesn't try to open on its own). Keeping the unit flat on a table, look underneath and find the small hole where you can turn the loading gear. Rotate it until the unit opens, using a standard flat screwdriver. The loading gear is a white plastic part with a slot in it. You should be able to see it rotate if you move the drawer by hand.
After manually removing the disc, turn the gear with your screwdriver until the drawer is all the way in, The gear should be able to be turned for three or four more turns when the drawer stops loading. If it doesn't, turn it a bit further unit it "pops" past one more gear notch. It should then turn freely for a few more turns, at this point you should stop. Do not force it once it stops the second time. This is the "Disc Loaded" position.
Power the unit back up and see if it loads a disc and plays correctly.
Dec 18, 2008 | Sony CDP-C445 5-Disc CD Changer
Cd changer drawer won't open
the common problem for this would be some of the disc/discs are out of place . just opening the shell
and removing the discs can resolve the problem.
Feb 23, 2008 | Technics SL-PD5 5-Disc CD Changer
My cd/dvd recorder
open the program uuse to burn with try itthat way ok
Feb 12, 2008 | Lenovo ThinkPad T61 Notebook
X box 360
The ribbon cable going to the Laser is popping up and dragging on the bottom of your discs. You must have opened the DVD drive for some reason or other to disturb the restraints to keep the ribbon cable or other wires laid down and kept away from the disc media surface.
Jan 30, 2008 | Microsoft Xbox 360 Console
Disc drawer sticks
i had this happen when my 460 was standing up. when i "sat it down" the disc drawer opened and closed fine.
Jan 03, 2008 | Microsoft Xbox 360 Console
Xbox, not 360
try calling xbox customer support at 1-800-4myxbox and see what they say.
Jan 02, 2008 | Microsoft Xbox Console
Computers & Internet Logo
David Payne
David Payne
