Question about Olympus PEN EPL1 Digital Camera
Where can I find tutorials to learn to use the Olympus E-P1 and E-P2 online?
I have johnson jet 7000 treadmill and its showing error 2 what can i do
HI,
Error 2 means P0 P1 P2 P4 P5 ( P0 ....Min. ,Speed P1 ....Max, Speed P2 ....Mid.Speed, P4 ....Min.Slope, P5 ....Max.Slope )have a wrong parameter values. You have to go the engineering mode and set the parameter. Here i have added a link which will guide you to the service manual of Jet 7000. read the section 4 (console maintenance mode guide) and re-calibrate the treadmill parameters P0 P1 P2 P4 P5 .page no(4.3).
http://www.cross-ir.com/Downloads/JET7000-6000-1.PDF
WWW.electro-medical.blogspot.com
Sep 16, 2015 | Exercise & Fitness
Tip
How to jailbreak using redsn0w on a PC (Windows) or a Mac
Updated January 15, 2012
This a general guide on jailbreaking any iDevice with iOS version up to 4.3.3 using redsn0w.
This guides focuses on redsn0w versions prior to 0.9.9b1 which has am all new UI and a bit different steps.
Redsn0w can jailbreak all existing iOS version (including the latest iOS 5.0.1) for any iDevice. CLICK HERE for more information and to see the list of all versions with their supported iDevices & iOS version.
A guide on how to use the newer versions of redsn0w will be posted here.
Supports the following devices with iOS 4.3.3, 4.3.2, 4.3.1, 4.2.1 and 4.1:
  • iPhone 4
  • iPhone 3GS
  • iPod touch 4G
  • iPod touch 3G
  • iPad
Download links for redsn0w 0.9.6rc19:
CLICK HERE for earlier versions of redsn0w for jailbreaking older iOS versions.
Below are IPSW files you'll use. If an Ad appears, just click SKIP THIS AD on the top left corner to continue on downloading:
For iDevices with iOS 4.3.3 installed:
For complete list of IPSW files, CLICK HERE.
WARNING!: This guide is for JAILBREAKING ONLY. Refer to UNLOCK GUIDE for more information on unlocking that includes a list of all the currently supported basebands.
DO NOT UPDATE if you need the unlock, otherwise you might lose it for good.
For best results, update iTunes to 10.1.
Procedure:
  1. Plug your iDevice to your computer
  2. Turn OFF your iDevice[space]To turn OFF, press and hold the POWER button for about 3 to 5 seconds then slide the red bar saying: slide to power off[space]
  3. Open/Run redsn0w and click Browse[space]NOTE: The screenshots you'll see here are taken from an earlier version of redsn0w using a Mac, however, as noted above, the process is completely the same if you'll be working on a PC (Windows), or a newer version of redsn0w.[mac1]
  4. Locate the official IPSW and click Open.
  5. redsn0w will process and identify the IPSW[mac3][mac4][space]
  6. Click Next and wait until it completes processing[mac5][mac6]
  7. Select your preferences and click Next[mac7]
  8. Turn OFF your iDevice (just a reminder from step 2).[space] Before you click Next, read steps 9 to 11 first in preparation for putting your iDevice to DFU mode[space][mac8]
  9. Press and hold the POWER button for three (3) seconds[ma9]
  10. Continue holding down the POWER button then press and hold the HOME button as well. Hold them both for another ten (10) seconds[space][mac10]
  11. Release the POWER button but keep holding the HOME button. You can release the HOME button once you see redsn0w in the process of jailbreaking your iDevice[mac11][mac12]
  12. Click Finish and you're done on the computer, and as it says, the rest takes place on your iDevice.[space][mac 15][space]
All you need to do now is wait and keep it plugged in your computer. DO NOT INTERRUPT![space]
Watch the complete process here:[space]
After the process, swipe through your homescreen pages to find Cydia. Usually, you'll find it on the 2nd page.
There are times that Cydia's icon would be blank. It will still work though, the important thing is it's already installed.[space]
If you have an iPhone and you want to UNLOCK, CLICK HERE.
Credits:
iPhone Dev Team
kidantvideos
Read more tips from kid_ant
on Sep 21, 2010 | Apple iPhone 3G
Stats 2 prop z test
n1 and n2 are integers. The proportions p1 and p2 must satisfy the conditions of the Hypothesis you are testing. p1 not equal to p2, p1 < p2, p1>p2.
Dec 10, 2013 | Texas Instruments TI-89 Calculator
Expected returns: You have chosen biology as your college major because you would like to be a medical doctor. However, you find that the probability of being accepted to medical school is about 10...
So expected returns are just a little more advanced version of probability - without getting too in detail it uses weighted averages so you do not have to add the same number 17 times.
Let's first define our variables:
E(X) = Expected Return X1 = Variable 1 P1 = Probability 1 (in decimal format so 55% would be .55) X2 = Variable 2 P2 = Probability 2 (P2 is also equal to 1 - P1)
So the expected return formula is as follows:
E(X) = (X1)*(P1) + (X2)*(P2)
Plugging in our given numbers we get E(X) = Expected Return X1 = 300,000 P1 = 10% or .1 X2 = 40,000 P2 = 1 - P1 = 1 - .1 = .9
E(X) = (300,000)*(.1) + (40,000)*(.9) E(X) = 66,000
Now remember this does not include the opportunity cost of spending your four years in college studying biology instead of another degree.
Feb 27, 2011 | Texas Instruments BA-II Plus Calculator
Can u calculate the gradient of a line?. If s how?
What you call the gradient is usually called the slope of the line. Select two points P1 and P2 on the line. Read their coordinates P1(X_1, Y_1), and P2(X_2, Y_2).
The slope of the straight line that passes through P1 and P2 is the ratio s=(Y_2-Y_1)/(X_2-X_1).
Nov 18, 2010 | Casio fx-300ES Calculator
Send to read/writer a plus hoop design it only reads the p1 file
After I stitch out the p1, I have to go back and load the p2 design and continue stitching after I adjust the hoop to the p2 setting. Then I do the same thing with the p3. It is a pain to go back and forth, but it works!
Nov 08, 2009 | Husqvarna Rose
Polar wind dehumidifier: p1 or p2 code after emptying tank.
P1 error indicates that:
  1. The water tank on the side of the unit is full.
  2. The water tank in not properly seated in the housing.
  3. The switch at the back of the water tank housing is not engaged or is loose
Jul 24, 2009 | Kenmore 54501 Dehumidifier
How to create owr own calculater
for all os ? you must use java language! this is the code:
//<applet code="calmayank"height=300 width=300></applet>
import java.awt.*;
import javax.swing.*;
import java.awt.event.*;
public class calmayank extends JApplet
implements ActionListener
JTextField t1;
JButton b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,
b11,b12,b13,b14,b15,b16,b17,b18,b19,b20;
GridLayout gl;
JPanel p1,p2,p3;
public void init()
gl=new GridLayout(5,4);
p1=new JPanel();
p2=new JPanel();
p3=new JPanel();
p1.setLayout(gl);
t1=new JTextField(17);
b1=new JButton("1");
b2=new JButton("2");
b3=new JButton("3");
b4=new JButton("4");
b5=new JButton("5");
b6=new JButton("6");
b7=new JButton("7");
b8=new JButton("8");
b9=new JButton("9");
b10=new JButton("0");
b11=new JButton("+");
b12=new JButton("-");
b13=new JButton("*");
b14=new JButton("/");
b15=new JButton("@");
b16=new JButton("$");
b17=new JButton("%");
b18=new JButton(".");
b19=new JButton("?");
b20=new JButton("=");
p2.add(t1);
p1.add(b1);
p1.add(b2);
p1.add(b3);
p1.add(b4);
p1.add(b5);
p1.add(b6);
p1.add(b7);
p1.add(b8);
p1.add(b9);
p1.add(b10);
p1.add(b11);
p1.add(b12);
p1.add(b13);
p1.add(b14);
p1.add(b15);
p1.add(b16);
p1.add(b17);
p1.add(b18);
p1.add(b19);
p1.add(b20);
p3.add(p2);
p3.add(p1);
getContentPane().add(p3);
b1.addActionListener(this);
b2.addActionListener(this);
b3.addActionListener(this);
b4.addActionListener(this);
b5.addActionListener(this);
b6.addActionListener(this);
b7.addActionListener(this);
b8.addActionListener(this);
b9.addActionListener(this);
public void actionPerformed(ActionEvent e)
if(e.getSource()==b1)
t1.setText("1");
else if(e.getSource()==b2)
t1.setText("2");
else if(e.getSource()==b3)
t1.setText("3");
else if(e.getSource()==b4)
t1.setText("4");
else if(e.getSource()==b5)
t1.setText("5");
else if(e.getSource()==b6)
t1.setText("6");
else if(e.getSource()==b7)
t1.setText("7");
else if(e.getSource()==b8)
t1.setText("8");
else if(e.getSource()==b9)
t1.setText("9");
Dec 15, 2008 | Computers & Internet
P1 and P2 error codes
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
I hope that helps.
May 25, 2008 | Danby DDR2506 Dehumidifier
Olympus PEN EPL1 Digital Camera Logo
156 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
