Question about Refrigerators
Low hum or buzz in fridge/freezer (mostly from the freezer side)
Our GE side by side fridge/freezer is making a low moaning type of noise and it sounds as though it is coming from in the freezer. It might also be described as a low pitch kind of hum of sorts. Plus sometimes when I open the freezer door it seems to have a fan that goes off and on kind of random.It is not constant but kind of comes and goes. Just wondering how serious it might be? Thank you.
  • 327 Answers
Hello, the solution was the ASM control circuit board, ordered one online for around $100 and replaced it
Thanks
Posted on May 30, 2010
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Buzzing/humming noise with jenn-air bottom freezer
i have this problem too on my GE Profile. A youtube video seems to suggest a compressor problem. Turn off the fridge for a while and let it cool down and try again? I tried but to no avail. Would someone answer this? Please :)
Mar 21, 2010 | Jenn-Air Refrigerators
GE - SIDE BY SIDE MODEL TFX25JR - Continous HUM
Probably the condenser fan motor is going out they will often make noise for a long time before anyone notices. Get it looked at soon. overheating the compressor on that old of a fridge could spell trouble.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Humming and frosting in freezer
Your defrost has stopped. Either the defrost heater, bi-metal or the control board has failed.
Sep 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Our fridge/freezer is making a moaning sound. we
if the timer is making clock sound is the timer may be you have a fan making noise
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
Ge side by side - high low humming noise from freezer section
Sounds like its the evap fan motor to me. Not very easy to axcess. I have had one GE make the same noises you are describing to me. Let me know if you are going to attempt it and need more assistance
Nov 19, 2007 | Hotpoint HSS25GFP Side by Side...
Water Dispencer not working.
check your freezer for ice. do you have alot of ice in your ice maker tray? if so your water line could be frozen. try to self defrost the freezer for about 3hrs to thaw out the water line. check your water valve also. when you call for water do you hear a humming or buzzing noise? on ge fridges ive worked on if you hear a humming noise when calling for water, most likely your water valve is ok. trace the water. meaning where does the water start? at the wall then through a hose then to your valve which is behind fridge on bottom. trace the hoses and you will find the prob
Feb 09, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
341 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
