Question about Kenmore 62602 Electric Dryer
Thumping in kenmore dryer empty or full
Today my dryer began thumping when turned on.
  • kolkatasarah Jun 22, 2008
    My kenmore dryer started thumping today after working perfectly for many years. Model number 110-69912990.
    Is this either the rollers or the drum roller supports?
    So far Ihaven't taken any steps, but plan to open it up now.
    thank you.
  • joepilot95 Jan 24, 2009
    I have the same problem twic with my Kenmore 70 series. mod 110.66755201 I replaced the drum roller support on the left side, facing dryer, and it is bad again with in six months. It is totle worn down to the plastic. Any reason why?
  • 5,911 Answers
Usually this is a symptom of the drum roller supports going bad. Some model dryers have two rollers, while others have four. I need to be sure. Please post back with your COMPLETE model number (located around the door opening) and I can give you better advice and provide you with part numbers.
PS If it IS the rollers, this is not an expensive repair.
Posted on Apr 08, 2008
SOURCE:
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
Kenmore 80 Series dryer's drum is making a thump
I would check all the screw's to make certain they are tight. That was my problem when mine was making noise. Look on the interior of the drum.
Jan 01, 2012 | Kenmore Dryers
My new maytag dryer has a thumping sound when it runs, full or empty. it also has a rattle.
I am wondering if all packaging material was removed from the dryer. If you installed it yourself, please check through your manual and installation guide to see where packaging material may be located.
Dec 24, 2010 | Maytag MEDE500V Dryer
The dryer sounds like an unbalanced washer. Sound is coming from the front top left side. Machine diesn't move. does it even when empty. Began after was on for about 10 minutes.
Possible bad bearing for the drum front or maybe a drive belt with a missing segment that thumps with every revolution. You will need to open the top to inspect--either screws in the back edge of the top or insert a thin putty knife into the front corners to release a spring catch on each side. Hope this helps!
Oct 09, 2010 | Frigidaire GLEQ332A Electric Dryer
SOUNDS LIKE YOU ARE DRYING SHOES IN THE DRYER. EVEN WHEN THE DRYER IS EMPTY!
Bad rollers
These rollers get a flat spot on them and make a thump type noise with every revolution. More HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 10, 2010 | Kenmore Rear Control 8885 Dryer
Kenmore electric dryer making loud noise when running
It sounds like the belt that goes around the drum. I have a similar Kenmore, and I get that same rotational thumping noise. The belt is probably about to break or come apart. If you take it off and run it trough your hands, I think that you'll find either belt separation, or a bad spot missing a chunk.
Fortunately the belt is a cheap item. I've kept my Kenmore dryer running over 20 years now.
Mar 18, 2017 | Kenmore Dryers
New dryer makes a loud thumping full or
I hope he did nt charge you. Because of the seam in a dryer drum, they do make a slight thumping noise but it should not be real loud. I hope the tech took the dryer apart and checked the rollers. One of them may have a flat spot.
I would ask for a factory represent ive to come out and see if they think they would want a dryer in there home that make that much noise.
Please rate solution
Sep 03, 2009 | Dryers
Just moved, dryer won't tumble with a load. Error code PF
Did it get tipped in the move? I don't know about the specific model of Maytag, but on my old Kenmore the belt that ran the drum also had a wheel and kind of like a pulley that it had to seated on in order for the belt to stay centered on the drum and turn properly.I don't know how you get the shell off the front to get at the drum, the Kenmore had screws that you had to take out and lift the control panel off and then back to get at the inside. Sorry
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag front load dryer thumps while turning, empty, full etc.
If your Maytag is like my Maytag, there are two screws at the two bottom corners of the front panel. Once you remove both screws the front panel will lift out, up, and off. Then you can see what is going on inside.
Mar 28, 2009 | Maytag Dryers
Constant "thumping" sound when dryer is going
you can fix it by ordering a whirlpool roller kit but its no big deal the drum sits on rubber rollers when it just sits the rolers get flat spots on them like tires and makes the thumping sounds its just noisey but no big deal but they do make a kit with softer rollers
May 24, 2008 | Kenmore 63942 Dryer
Kenmore 62602 Electric Dryer Logo
130 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
