Question about Aspyr Top Spin 2 (PC)
I have installed top spin 2. when i click the play game icon on the desktop everything runs normal.when i select the exhibition mode. the screen turns black and no players can be seen.only words like players name and P1 is seen.
2 Suggested Answers
SOURCE: Homeworld 2
Downlaod the 1.1.1 patch.
I'm having trouble with the sound--clicking in soundtrack--I turn down music volume, and it goes away, but is also present in voice tracks as well.  It worked once for me perfectly, and I can't remember what  I did to fix it the one time.
Posted on Oct 25, 2008
Why dark manor game didnot support my monitor risolution
Windows XP
  1. From your desktop, right-click and select Properties.
  2. Click the Settings tab.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and select OK.
  4. Try playing your game again.
Windows Vista
  1. From your desktop, right-click and select Personalize.
  2. Select Display Settings.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and click Apply > OK.
Windows 7 and Windows 8
  1. From your desktop, right-click and select Screen resolution.
  2. Adjust your screen resolution to 1024 x 768 (or higher) and click OK.
  3. Try playing your game again.
Mac
  1. Open up the Apple menu.
  2. Select System Preferences.
  3. Click on the Displays icon.
  4. Select the Display tab to adjust your resolution to 1024 x 768 (or higher).
  5. Reopen your game.
    _
    Try this out it seems to work for some people, if that does not work try this out:
    Switch to Windowed Mode
    If you continue to have trouble playing your game in full screen mode, switch to windowed mode. Under the main menu of the game, select Options, and un-check Full Screen mode (or vica verse if you already have windowed mode on, switch to fullscreen)
    Thanks and I would appreciate a reply if that got fixed or not.
    Good Luck!
Apr 27, 2014 | bigfishgames.com
Install onto windows vista
Your having problem with Silent Hunter 3 on you windows Vista, It is because Silent Hunter 3 is not compatible with windows Vista. Maybe the game may work if you play it with XP compatibility. Heres how to do that.
  1. Locate the shortcut icon of Silent Hunter in your Desktop.
  2. Once you locate the icon, right click on it and click on Customize to show the Customize Menu.
  3. On the Customize Menu, Select Play and then click on Edit. ( This process will show you the Properties Screen)
  4. On the Properties Screen, you will find the Compatibility Tab, Click on it.
  5. find the sentence that says " run in compatibility mode for: ", you will see a drop-down list underneath it. It contains all the OS that can be compatible with your game.
  6. Browse the drop-down and select Windows XP.
  7. Click Apply and OK then close the Customize Menu.
  8. Now your game will try to run in XP compatiblity mode.
  9. Your done. Run the game now.
If the solution above doesn't work and you really want to play the game. I suggest you change your operating system in which the game is supported.
Goodluck , Hope that this solution will help. Please give some feedback regarding my solution thanks.
Thank you for using Fixya!Have a great day!
Jul 09, 2011 | Encore Silent Hunter 3 OS Windows Xp Vista...
How do i make heroes of might and magic v work on windows 7? I installed that game (original game not using crack or pirated version) on win7 everything installed correctly but it wont start the game i...
Try running it in compatibility mode, and if that doesn't work you could also try messing around with some other settings near compatibility mode. I had to do this for an old game called Diablo 2, but it's easy enough to do.
Find the game's launcher, either the desktop icon or the .exe file. Once you find this file, right click on it and in the menu that comes up, select the tab that says compatibility. Here, check the "run in compatibility mode for" and select Windows XP, since that is the OS that you are sure it works on. If that doesn't work, try messing with some of the options too, like the resolution and display scaling. For some odd reason, those make a difference sometimes. I remember Diablo 2 having a strange combination required to work on Windows 7 for me.
Apr 07, 2011 | Ubi Soft Heroes of Might and Magic V for...
I have windows 7 installed on my pc.i installed cossacks II napoleonic wars properly,and when i try to start the game,i get information that the game can run only on older versions on windows (95,98 XP )....
Well, try this, we call this "compatibility" mode, most programs can be run on windows 7 with this trick.
I assume your Cossacks II Napoleonic Wars icon is on the Desktop,
Right-click the Icon (game's icon), select "Properties" and click "Compatibility" tab, select "Run this program in compatibility mode for" click the "Windows 95..." and select "Windows Xp (Service pack 2)", click "Apply" > "Ok" and try again.
If even after doing this, the game can't be played, then there's no option. The fact is that, this game is made to run on system with Windows xp and earlier version, but somehow if fortunate, it's possible, not will all software, some may work, some may not.
Good luck.
Thanks for using FixYa.
Aug 12, 2010 | CDV Software Cossacks 2: Napoleonic Wars...
Can this game be played with a vista os....
Install the game to the computer as you normally would. Try to run the game. If the game will not run you will need to change the setting on the games desktop shortcut. "Right click" on the game icon, click on properties. Then click on the "compatibility" tab. Check the "Run this program in compatibility mode for" box then click the down arow and select "Win XP SP2" Click appy then ok. The game should run.
Jan 27, 2010 | Hasbro Interactive Missile Command for...
The Learning Company CD Rom Game Liberty's Kids will not play on my Vista laptop. In will install, but not play.
Right-click on the icon for the game in the start menu or on the desktop (if one was placed there) and select Properties. Click on the Compatibility tab. In the section marked Compatibility Mode, select the checkbox and from the drop-down list choose Windows XP (Service Pack 2). Click OK and try running the program using the modified shortcut. If you get any error messages about insufficient permissions, you may need to go back to that same tab and select the Run as administrator option at the bootm of the property page.
Jul 27, 2009 | Computers & Internet
Icons on computer are very large after closing a program; restart doesn't fix
Yes, it is normal because your game is running in a lower resolution. When the game is exited properly, then your normal resolution is restored but since it didn't exit properly, it forgot to change your resolution back.
Assuming this is windows xp, right click anywhere on the desktop that does not have an icon and select properties. There you can change the resolution to what it was; since I don't know what it was, you'll have to test a few to see which one looks the way it did before. Then once you find it, press okay and it will save.
Jun 01, 2009 | HP Pavilion dv7-1132nr Notebook PC
We have a windows vista computer and a game which we havent installed yet because we were wondering if it might damage the game or computer because on the minimum requirments it says that the computer must...
the worst that could happen is that the computer may not run the program. try installing the game, your cd (assuming that's the source of the setup files for the game) should not be affected.
after you install the program try to run it as usual by double clicking the icon to run the program if it doesn't run as expected try this.
1. right click the icon you use to run the game.
2. select properties
3. select the compatibility tab and select an appropiate mode. (ex. windows xp service pack 2)
not completely sure but you may also want to try to run the installation/setup program by changing the compatibility mode so you may be able to trick the program into believing the app/game is being installed on a windows xp service pack 2 system increasing your chances to have the installation running properly.
Sep 27, 2008 | Computers & Internet
We have purchased "Let's Ride Silver Buckle Stables" and installed it. The play screen has a pop up that says" Input Signal out of range", which is on every screen, so you cannot see...
1. If there is an options program that you can run for the game, set the video resolution to something your monitor can handle.
2. Since few programs have that option, you may right click on the icon, select properties, and select compatability mode. Force the resolution to 640 x 480 and see if that helps.
You are getting this error because your monitor cannot handle the resolution that the program is requesting and it's out of range of what the monitor can handle.
Jun 23, 2008 | Computers & Internet
Lego Island
Older programs will sometimes not work with Vista. This is likely the reason that Lego Island 2 (a 2001 game) will work a opposed to Lego Island (a 1997 game). There are a few things that you can try, though:
  1. Right click the 'play game' icon and select 'Properties'
  2. Click the 'Compatibility' tab at the top of the window
  3. Click the 'Run this program in compatibility mode for:' box and select Windows XP or Windows 98/Window ME (you can try another later if one doesn't work)
  4. Make sure that the 'Run this program as an administrator' box is selected.
  5. Click 'OK' and close the window
Give the icon the good ol' double click and see if she works. There's no guarantees that this will work with Vista since it is an older program, but this is where I would start.
I hope this helps!
Mar 29, 2008 | Computers & Internet
Aspyr Top Spin 2 (PC) Logo
234 people viewed this question
Top Aspyr Video Game Consoles & Games Experts
James Wishart
Are you an Aspyr Video Game Console and Game Expert? Answer questions, earn points and help others
