Question about Altec Lansing VS4121 Speaker
How to open the subwoofer housing to change the fuse
Hi! recently my ALTEC LANCING VS4121 stopped working all of a sudden. Even the power LED on the right satellite is not glowing up. I think its the fuse or the power adapter/transformer inside the subwoofer case that has blown up. I can mend this on my own but can't get any clue how to open up the woofer casing. Its all sealed from evrywhere. Can't get the power circuit outside. Experts please help fixing it.
Thanks and Regards
Amit Mula
On the back unscrew all the screws (there should be 8 in the plastic square around the jacks... and then undo the four that are in the wooden back) then pull out the plastic square, it will take a decent amount of force, try prying with a flat head screw driver. Once you have that out, you should be able to access what you need inside.
Posted on Jul 23, 2010
  • 1 more comment
  • Noel adriano
    Noel adriano Apr 14, 2014
    hi dead! how about on right speaker how to open the case?
  • Noel adriano
  • Noel adriano
    my problem is when I turned max the volume the sounds dead when I lower the volume the sounds cam back! Please help
Altec Lansing VS4121 speakers stopped working for no reason????
I had a similar set and they drove me mad because they hissed when they were switched off. I bought a pair of Bowers and Wilkins MM1 instead. Fabulous.
If you want yours fixed you would have to take them to an electronics engineer or return them.
Altec Lansing VS4121 Specs
Bowers Wilkins MM 1 Computer speakers Hi Fi Speakers for PC laptops Bowers...
May 14, 2017 | Altec Lansing VS4121 Computer Speakers
My Altec Lansing VS4121 played excellent sound, even at high volume untill recently. A friend had borrowed them for weeks and I got them back recently. Played music to find out that sound of main woofer...
I think that some wirings inside the main woofer or the tray holding it might have loosed. It could be the speakers were accidentally dropped or anything.
You can bring it to a local store Best Buy, Staples, etc. have it checked by one of them technicians or to see if it can be put back to it's place. I'm no speakers expert but that's the only reason I could think of.
If you are comfortable opening the speaker covers and checking inside the speakers then you can also try to check for some loose parts.
Hope this helps!
May 25, 2011 | Altec Lansing VS4121 Speaker
My altect lansing bxr1121 speakers stopped working suddenly. I have checked all the connection but the power led is off.
Hi. i think it is the internal connections or jacks need to be resoldered, but first try to check the continuity of each wires. tact switch cleaning and replacement is another approach.
Mar 07, 2011 | Altec Lansing BXR1121 2 Speakers
I accidentally connected VS4121 speakers to 240V instead of 120 V
Hey i am also from india. Every speaker unit has a built in fuse unit which protects it from the over voltage. just replace that with a new fuse of same rating. if you are not sure of what rating the fuse is, consult with the electrical shops. and then ask them to give a 240v to 110 or 120v AC to AC dimmer. just use this with your speakers and they will run with no problem. but if it is a serious damage inside then you need to take it to a service center.
Dec 21, 2009 | Altec Lansing VS4121 Computer Speakers
Speakers stop working need to replace don't know where the part suppose to go
Probably the fuse, you need to take out the woofer in order to reach it.
May 27, 2009 | Altec Lansing ATP 3W Computer Speakers
My Altec lansing multi media ada 745 just stopped working all of a sudden. It doesn't work for all media ie. ipod, tv, computer. We can hardly hear it. I changed the fuse but it still doesn't work. Wh
unplug the power from the speakers, reseat the all the connections for the satellite speakers, ensure the power switch on both the subwoofer and the Right Front Speaker are in the ON position.
If that doesn't resolve the issue, then you are most likely going to need to replace the speakers, as the fuse is the only serviceable componet.
May 20, 2009 | Dell Computers & Internet
Altec Lansing VS 4121
It is unlikely that this is a problem with your speakers more likely that it is a problem with the DVD player itself. I would recomend trying another DVD player.
Regards, Andrew
Sep 17, 2008 | Altec Lansing VS4121 Speaker
No Power (LED off) in the Altec Lansing VS4121
There is no way to open the satellite speaker without destroying it. I tried and found that the whole thing was glued together. Mine is now destroyed
Apr 15, 2008 | Altec Lansing VS4121 Speaker
Changing battery with enrgizer 2025
even cahgning to fresh battery , you still cant turn on your speaker? you may have a faulty wiring inside the speaker. one quick way s to open the speaker and manually check if the connections are ok. if they aree ok, it may be a capacitor problem.
Apr 02, 2008 | Altec Lansing VS4121 Speaker
Altec lansing vs4121
u dont need any driver to play the speakers, yes the sound card does, take down ur sound card modle no. and try looking in www.driversguide.com let me know.
Feb 12, 2008 | Altec Lansing VS4121 Speaker
Altec Lansing VS4121 Speaker Logo
2,381 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
