Sad to say it's likely to be 1 or more transistors in the power amp circuit, although there are other possible causes.
Luckily the repair manual is available (hifiengine.com) and the power amp is built with discrete components, so it should be easily repaired
Most common causes would be an output transistor or dry solder joint(s) due to transistors / resistors getting hot and cooking a solder joint or 2.
Inspect all solder joints carefully with a magnifier, looking for signs of localised heating/burning and/or crysalisation of the solder.
It's normal to replace output transistors as a matched pair even when only one has failed, to minimise distortion. Replacement transistors should of course be as close to the original specs as possible (or better) if genuine parts are not available. The bias will need to be adjusted as per manual (1.5mV emitter to emitter of output transistors).
Good luck.
Hi Please do not dessolder anything before a thorough test. You should first check the main fuse. If it is blackened the MOSFET switchinhg transistor is probably bad and need to be replaced. The test should then go on thorugh the output line voltage in search of shorted components. Only when the fuse is clean but open (interrupted) you can replace it and plug in the tv set and test. Be careful and follow safety instructions on dealing with high voltage section of tv set. High voltage is letal.
Check hori output and small blue high voltage capacitor 2k that feeds hori output transistor.
If these componets are OK then replace Both of the STK ICs they are big black ICs and will have PN# on them.example STK392-110.
Mats Electronics has ICs 1-800-628-1118
Encompass Parts Distribution has Free Service Manual for this Model# 57H94 you can print it out online.Go to their website.
You need to confirm where is the trouble before replacing any parts.
Test the B+ on the H-out transistor.
No-check the B+ on 160v electrolytic cap.
If No B+ here then the trouble is in the regulator section before the chopper if it has.
Let me know the reading from your ohmmeter.
Thanks for using Fixya.
JDVillanueva
Don't know this particular transistor but most of the B#### transistors were manufactured by Bendix Corporations Semiconductor Division at South Street, Holmdel, New Jersey 07733. I think most if not all were Germanium PNP high power transistors in TO3 cases. It's just possible that some surplus dealer or electronics buff around Holmdel may have one in the junk box. If not look for a replacement with capability of handling the specified channel power output at the supply rail voltage. Gain is probably not too critical.
Your audio output transistors are shorted and your unit is staying in "protect " mode to protect your speakers from 40 to 60 volts that is being sent at them from the shorted outputs. If you can use a meter you won't need the schematic MOST likely because the outputs are USUALLY the only parts that short out. The output transistors( or chip ) are mounted to the large, finned heatsink. The #'s on the transistors start with "2SA-" and "2SC-" followed by numbers. There are two output transistors per channel. If your unit uses an IC for audio output then the # on the IC will be "STK-" followed by numbers. These parts are available from tritronicsinc.com. Good Luck!
First, locate the horizontal output transistor. This is found very
close to, or next to, the horizontal output transformer (also known as
the flyback). The flyback should be on an aluminum heat sink, or on the
side of the metal chassis. Disconnect or unsolder two of the three legs
of the transistor. Measure it with your meter, or plug in the set with
the light bulb attached across the fuse. If the transistor is
shorted, or the light bulb doesn’t glow bright anymore, replace the
transistor and plug back in. If the light bulb glows bright again, you
must replace both the flyback and horizontal output transistor
simultaneously. In some cases this will fix the set, but sometimes
there are multiple problems with a set. Go to where the flyback
is, and start measuring the diodes and capacitors on the flyback
itself. If you don't find any shorts there, it could be a shorted
vertical output IC, a shorted sound IC, a shorted disc capacitor in the
Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or
tuner.Feel free to ask and post whatever the result of your troubleshooting..
Through my past experience I mwould remove the solder point at the input power B+ line to primary winding FBT. If the HOT has shorted there will be no power.Straight to the point if you know where the HOT is , you can desolder the middle pin or collector of the HOT transistor. If you desolder the pin which result the power led light turn up. That indicates either FBT or HOT has shorted
Did you found the part?I have the same problem.THx
Did you found the solution or the part?I have the same problem.THX
