Question about GE WSM2420T Top Load Stacked Washer / Dryer
About two years old-get off balance easily-quit spinning . Washer was making a loud baging noise then quit in the spin cycle
    Brigadier General:
  • 3,917 Answers
Thanks for contacting Fixya.com
Either the machine is not balancing correctly or something mechanical has broken. If it works fine when empty then it is a balancing issue. If it does this even when empty then something has broken that supports the tub.
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Probably the bolt that holds the pulley to the drive gear for wash and spin may have come loose and the pulley is free-spinning or the gear has come loose from the shaft. At worst, the gear is broken.
However some general resolutions to stop the machine to make noise or go offbalance are ….
Balance the load.
Inspect the water pump for a blockage.
Inspect the coupling.
Inspect the transmission.
Check the motor bearings.
Check the drum brakes .
Here are some links that are the probable reasons for your machine to act offbalance or noisy…
http://www.acmehowto.com/howto/appliance/washer/check/level.php
http://www.acmehowto.com/howto/appliance/washer/check/belt.php
http://www.acmehowto.com/howto/appliance/washer/check/movement.php
http://www.acmehowto.com/howto/appliance/washer/check/pump.php
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Posted on May 31, 2010
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Noisy when in spin cycle
This could be the drum baring and probably will need professional engineer to do it.
Jun 01, 2017 | Kenmore 24032\24036 Top Load Washer
Our Hotpoint WF321 1200 spin is just 3 years old and now makes a very loud noise when in use - both for the washing and spin cycles. is the drum loose / off balance? any help appareciated
Remove lower rear cover of washer, remove drive belt, and from the front spin drum by hand, if it feels rough, or is rumbling, or noisy, then the main drum bearings are failing.
This is a major repair!!!.
Mar 13, 2010 | Hotpoint Washing Machines
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Making a loud noise when on the spin cycle and not balanced
It could be a drum spring has broken or stretched too far, there is too much of a heavy load in the drum, or the bearing needs replacing.
Sep 11, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer does not spin and makes loud noise
Hi!!! You have a bad motor coupler replace and you should be fine..
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Loud Noise at the End of the Spin Cycle
some item has fallen down between the outer and inner wash tubs? remove it
May 20, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
GE WSM2420T Top Load Stacked Washer / Dryer Logo
62 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
