Question about Sony Cyber-shot DSC-T50 Digital Camera
Error 62.10 image shakes - Sony Cyber-shot DSC-T50 Digital Camera
  • 1,170 Answers
Basically what many people said was the error was probably due to focusing problems if you may have dropped the camera before. On the site they recommended to hit the camera lightly on the side where the battery is located, while the camera is booting up. I did this, and to my surprise IT ACTUALLY WORKED!
Posted on May 30, 2010
Error code c5102
take each of the image units out not toner image units. Then shake each unit along its axis to spread the developer in side each one along the whole image unit. then reinstall. next pull out the transfer belt and reinstall properly. if this does not work you might have and burned out main motor or worse the control board that controls it is bad.
Oct 16, 2015 | Konica Minolta Minolta Bizhub C353 Copier
Error code c-2558
Sampath: According to Mike Roark on FixYa.com: "This error means abnormal tonder density in the black image unit take the black image unit out and shake it while holding it level and put it back in the machine. To reset the error code leave the machine on and open then close the front door"
May 17, 2015 | Konica Minolta Office Equipment & Supplies
How do we properly shake the image unit of the Konica Minolta bizhub c203 to clear error message C-2558?
ugh sorry replace the toner hopper and all of the componets if a new iu dosnt fix the problem
Aug 18, 2014 | Konica Minolta Bizhub c203 Copier
Bizhub c451 error code c2259?
Black developer motor failure to turn. You mite try pulling out the Black image unit and shake it to spread the toner and developer along the whole unit. The image unit mite have been stored standing up image units should always be laid flat. All the developer may be sitting at one end of the image unit an so the motor is having a difficult time turning.
Nov 27, 2012 | Konica Minolta KONICA BR BIZHUB C451...
Hp laserjet 9500 is showing error 59.6k. and asking for restar.after re start error is same pls solve this issue
59.6K is a problem with the black image drum.
Take the black cartridge out of the printer. Shake it, reinstall it. Power cycle the printer. If the error comes back, remove the black image drum and reseat it. The image drums(one for each color) sit below the toner cartridges.
If the error still comes back a tech is going to have to look at the printer.
Apr 04, 2011 | HP LaserJet 9500hdn Printer
How do I clear error message C-2558 for the Konica Minolta bizhub C253
As the Installation Manual and Imaging Unit replacement instructions mention, pay close attention to shaking the Imaging unit properly to level the toner and also keeping the Imaging unit level when installing it into the machine
Jan 24, 2011 | Konica Minolta bizhub C250 All-In-One...
Sir, i am using Konica Minolta C252. I am getting error message C-2553. If i opened the front door and closed then the error message will go, but again it will come after some copies. What is the problem...
Magenta Image unit mite be the problem have it replaced if it already was then mite have a bad new one also check the sensor that monitors the toner for the magenta Also pull out the magenta image unit shake side to side to spread out the develop inside the image unit along the entire length of the image unit reseat the image unit.
Aug 20, 2010 | Konica Office Equipment & Supplies
Images are blurred
Blurred images can have different reasons. Greasy lens, camera shake or focus error.
You can clean a greasy lens with a lens-cleaner solution and lens-paper.
Camera shake will (most likely) only occur on images taken without the flash. Most likely there will be a warning on the display if risk of shake. it's a hand with an "!". Focus error will usually also give a warning in the display.
May 09, 2010 | Fuji FinePix S2000hd Digital Camera
Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Vibration of camera
Sony Cyber-shot  DSC-T50 Digital Camera Logo
231 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
