Question about Whirlpool GU2400XTP Built-in Dishwasher
The cycle does not complete - it seems to end when the detergent doors should open - but this doesn't happen. Water is running in and out ok - spotless machine - detergent door easily opens manually. Any suggestions any one? Running out of plates!!
  • 159 Answers
That is about the time it should start to heat the water.if its not heating at all then this could be the problem.when you say it ends i'm wondering if it has pump out the water or stopped with water in it.If they don't heat then they generally don't progress any further.the detergent door probably hasn't had a chance to open yet.
Posted on May 30, 2010
Detergent cake left in dispenser after wash cycle
Has the dispenser door open at end of cycle. If dispenser door is open but not fallen down to the tub means most likely the water arm pressure is not good enough to get flush down to the tub.
Door not open means dispenser failure or control board not giving power to dispenser at right time. In some cases dispenser door is stuck with harden earlier soap so it cannot open completely in the cycle.
Why not when opening the door at end of cycle, listen to dispenser area to see the flapper opening while you are opening the door. That means dispenser not opening properly in the cycle.
This issue is a hard solve sometimes. Don't wont to spend the money, then just use the tablets and through them in the tub in the beginning and say good bye to dispenser.
Apr 06, 2015 | Whirlpool ADG450 Slim-Line Built-in...
When I put detergent in dishwasher and turn it on, it seems to go through the cycles, but when it stops, the detergent is still in the detergent bin and the dishes are not clean.
Assuming the detergent dispenser door does open, it is likely the water is not reaching the top arms. Put a cup in normal position on the top rack and see if there is any water in it at the end of the cycle.
Likely causes are blocked arms or water distributor or the wash impeller is not working in the pump. The dishwasher uses the same pump motor for wash and drain cycles. You can check this by hearing if the water is getting swashed around when the wash cycle is on.
Check the impeller and water feed as shown in this diagram.
Hope this helps.
Jan 19, 2011 | Tappan 18 in. MDR251RE Built-in Dishwasher
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
Following the wash cycle with my Miele G464SC
sounds like you mean when the unit is running you are getting water dripping from the bottom of the door panel. if you remove the door panel at the bottom where the door hinges you will find an overflow tray which runs the width of the door. This is probably blocked with food deposits.
If not you may be using too much detergent. try running with no detergent and see if there are any leaks.if you open the door mid cycle the water level shouldn't be any higher than the bottom spray arm. hope this helps
Jan 02, 2010 | Miele 24 in. G646SC Plus Free-Standing...
Detergent does not get released
i have seen a problm perhaps similer to yours on several makes of dishwashers .. some washers have a flip up lid that normally covers the detergent cup .. if the upper basket is in the lower position (if its adjustable) then it blocks the flip up lid from opening ... this seems to be a design problem with several makes (probably all made by the same company ) .. if you put the upper tray in its up position then the door still doesnt open all the way but enough that the detergent gets washed out eventually .. that is if there is no large items just benieth that flip up lid .. if so that can block the water from getting into the detergent cup .. you end up with undesolved detergent still in the cup and in the washer at the end of the rince cycle .. very bad ... you may have a different problem .. for instance if the detergent cup door is not opening at all (bad opening mechanism) .. or if the pump screen is clogged then no water is circulated to desolve the detergent ..
Jan 02, 2010 | Dishwashers
The place where u place the soap won't let all the soap out why
hello. i can help you.
When the detergent cup doesn't open, check these:
Timer
Bi-metal switch or wax motor
Detergent cup, itself
Timer On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary.
Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards.
The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it.
On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly.
Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door.
Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly
The cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
Jul 05, 2009 | Electrolux Kenmore 24 in. Built-In...
Dishwasher not cleaning well
clean the dispensor assy around the spring door hinge witha vinegar water solution . liquid detergent has a tendency to not fully break if your water is not hot enough, causes doors to stick, reccomend running hot water before starting d/w, and using a quailty powder( not tabs) detergent
Feb 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
He4t - monthly bleach cleaning cycle
Washer Monthly Maintenance Procedure:
This cycle uses higher water volumes in combination with liquid chlorine bleach to thoroughly clean the inside of your washing machine.
  1. remove any clothing or items from washer
  2. CLOSE door (duh)
  3. open dispenser drawer and remove the detergent compartment and set aside. No laundry products will be added at this time. You will be required to add only liquid chlorine bleach at a later step.
  4. For Kenmore Elite HE products press a specific combo of buttons.
  • Select Rinse/Spin program
  • select low spin speed
  • select warm/cold water temp.
  • select 2nd rinse option
  • push the "end of cycle" signal button 4 times within 5 seconds to start the cycle
The machine will fill and run a short sensing cycle. This will take about 3 minutes.
Step 5
  1. The washer will provide 4 short tones. Check the: ESTIMATED TIME REMAINING display for the codes indicated below:
  • if "Ab" (add bleach) displayed in the estimated time remaining window (you'll hear 4 short tones) proceed to Step 6.
  • if "rL" (remove load) displayed in the Estimated Time Remaining window an error tone will sound. The door will unlock.
    -open the door and remove the items from the washer.
    -continue the cycle by pressing the START button.
    NOTE: The water in the unit will dispense for a moment, then the door will unlock, lock again, and then the cycle will continue with another check for items in the washer.
    The machine will fill and run a short cycle to determine whether any items have been left in the washer. This will take approx 3 minutes.
    the washer will repeat Step 5 until it can determine that there are NO items n the washer and will display "Ab" (add bleach).
6. Add liquid chlorine bleach.
  • If using the maintenance procedure for the first time, open the dispenser drawer and immediately add 1 cup liquid chlorine bleach to the Main Wash detergent compartment. The liquid bleach should immediately flow out of the dispenser.
  • If doing a monthly maintenance procedure, open the dispenser drawer and immediately add 1/3 cup bleach to the Main Wash detergent compartment. The liquid chlorine bleach should immediately flow out of the dispenser.
    NOTES:
  • Water will be flowing into the dispenser drawer when the bleach is added ... this is normal.
  • Do not add any detergent to this cleaning cycle. Use of more than 1 cup of bleachw ill cause product damage over time.
7. Once the cleaning cycle has begun, allow the cycle to complete. An est cycle time will appear on the display.
8. After the cleaning cycle is complete, leave the door open, clightly to allow for better ventilation and drying of washer interior.
9. Replace the detergent compartment divider.
Feb 04, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Whirlpool GU2400XTP Built-in Dishwasher Logo
297 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
