Question about Fuji Rod Repair Kit
Has the Fujifilm JX530 been launch yet, and are there any problems with it
Hi I bought this camera 2 days ago and could not download the disc for the manual . I rang fuji up to explain and they sent me a manual free of charge which i received this morning . Hope this helps !
Posted on Jun 02, 2010
How to reduce blur on close-up LEGO figure photographs?
Lenses have a limited 'closeness' at which they will focus. That is, unless it is a macro lens, you cannot focus closer than a yard or so (it is different for each lens). look on the barrel for markings or easier yet, move your camera back until the subject is in focus.
If you have to be back 3 feet - take the shots and then crop to make them appear larger.
Aug 15, 2014 | Cameras
Need owners manual for finepix jx530
Hi Tracy,
Here's the user manual in pdf.
Hope this helps.Thanks!
Dec 28, 2011 | FUJIFILM Cameras
My fujifilm finepix JX530 camera wont focus. I tried everything on the menu but still it wont focus. please help i just got it today!
If this is a brand new camera and it won't focus and you've read the manual and followed the directions, then you should return the camera.
Aug 06, 2010 | Cameras
Fuji s3 does not turn on...
You have done the right thing, so far. That which I would first have suggested. Congratulations! You would be surprised how many persons ignore the need for fresh batteries.
Yes, the camera should now be reset, and if that fails, service is required to make certain of your investment.
However, the battery must first be determined to be an actual Fuji battery, and if not, this is not your fault.
Please read the following:
Recommendation for Use of Genuine Lithium Ion Rechargeable Battery Pack for FUJIFILM Digital Cameras Thank you for using Fujifilm Products.
It has been our policy to recommend that the genuine Fujifilm rechargeable battery pack be used for Fujifilm digital cameras that use a battery pack.
However, it has been confirmed that there are certain counterfeit battery packs available in the market that look very similar to a genuine Fujifilm rechargeable battery pack.
Some of these may not comply with safety standards, they may cause serious problems, such as overheating, leaking, bursting, or fire.
For your safety, we would like to remind you to only use genuine Fujifilm rechargeable battery packs for Fujifilm digital cameras.
Please note that Fujifilm will not accept responsibility for any camera problems, accidents, and damage of any nature that may occur due to use of non-genuine Fujifilm battery packs.
We appreciate your kind understanding and cooperation in this regard.
FUJIFILM Corporation
Apr 07, 2009 | Fuji FinePix S3 Pro Digital Camera
When i connect my fujifilm s1000fd to my mac it doesn't detect it although it i listed as connected in my system profiler?
Serge de Montréal,bonjour,hi,here is a work aroud i have the same problem when my s1000fd is connect to my mac os 10.5.7 i can see an usb icon into the caméra lcd but there is no action from the computer,or Fine Pix doesn't launch as describe in the manual.
Here is what i found go to the application folder,you will find (transfert d'images)or in english, image transfert this is the application with a little camera .Connect your camera and launch this application
you will able to transfert onto your hd and after import onto Fine Pix.
Voilà Do not thanks me thanks people at mac Thank you Mac
Bonne journée à tous :)
Nov 08, 2008 | Cameras
What do i do
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
2) Resolving the problem
1. Plug the USB cable into the camera and Macintosh again.
* If you are using a USB hub, do not connect the camera to the Macintosh via the hub.
1. Select "Other".
2. Click the "Applications" folder.
3. Click the "FinePix Viewer" folder.
4. Select "FPVBridge" and click "Open".
5. Click [OK].
1. Launch FinePix Viewer.
2. Select "Automatic Save Settings" in the Settings menu.
3. Tick the "Auto save images when the camera is connected" checkbox in "Operation Settings When Camera Is Connected".
4. Click [OK] and close the "Automatic Save Settings" window.
5. Exit FinePix Viewer.
6. Turn the camera off and then on again to test whether FinePix Viewer launches automatically.
Apr 28, 2008 | Fuji FinePix S5700 Digital Camera
Fuji Rod Repair Kit Logo
479 people viewed this question
Top Fuji Sport & Outdoor - Others Experts
Mark Gough
Rick
Baz Hawkeye
Level 1 Expert
Are you a Fuji Sport and Outdoor - Other Expert? Answer questions, earn points and help others
