Yahama MT8X 8 track mixer cassette unit
Hi. I have this 8track casette recorder that, when you put a tape in to play, the tape unit does its' auto stop thing after a couple of seconds.
The cassette unit doesn't have the little finger poking down to measure tape tension - I have no idea how it works.
I've pulled it apart once before and given it a good clean, checked the belts, wheels and cleaned the pinch roller which wanted a bit of fine paper to rough it back up again, and it's still the same.
After a couple of weeks rest, I'm ready to take it on again - what can I be looking out for?
Many thanx and I appreciate you help.
  • 2 more comments
  • tru2form Apr 24, 2008
    I and thanx. I checked and didn't see the post you mention. I have a good all round clean from the outside with a compressor on very low pressure just in case yet it is still the same. The casette player runs for about 8 seconds of !click!click!click!click! before cutting out.
    Here are a couple of pics of the inside of the tape mechanism for you to see - the head is extended for the photo - perhaps they will help.
    http://i83.photobucket.com/albums/j302/t...
    I have ordered a service manual from Canada to help me out on this, yet to arrive.
    Regards,
    tru2form
  • Miha Jan 25, 2013
    Hi, tru2form. I hope you see this. I have the same exact problem as you do with my Yamaha mt8x. Did you find a solution. Please send me your answer. Thanks!
  • Alan B
    Alan B Sep 06, 2013
    I have found the solution to this issue. My friend has the same model and it does the same thing. He found that the motor and belt that run the tape head assembly (not the capstan motor) was slipping. When it slips, the heads never fully extend, and the take up reel skip. to fix this, simply replace the small belt, or use regrip to recondition it so that it does not slip- alan.bradesku@gmail.com
  • Miha Feb 22, 2014
    Alan B, I have just saw this message today and repaired my Yamaha MT8X in 20 minutes. Thank you very much!!!
    Sergeant:
    Champion:
  • 319 Answers
I believe this unit employs an optical sensor to detect tape end.
Clean this off to. It looks like a transparent post positioned along the tape path. Reset the counter to zero and fast forward tape to end. Rewind, and try to play tape as normal
Posted on Apr 23, 2008
  • Van Lake Apr 25, 2008
    Judging from the pix you provided, the take-up reel is rotating. However, the (left) supply reel may not have sufficient back tension to keep tape from sagging, thus, activating the shut off sensor. Adjusting the back-tension can be tricky -- too little the tape will cintinue shut-off, too much and it will slow the tape speed
How do I dub casette to casette? I lost the manual.
There should be a DUB button. After you push the DUB button, you will have another button that will allow you to select Dub form 1-2 or 2-1. If not there will only be one deck that will play while the other records and plays. Put the tape to be coppied in the play deck and the blank tape in the record deck push record and it should work.
Dec 11, 2009 | Denon DRW-585 Single Cassette Deck
You can press play and pause, but then you can't press down rec. help.
Is the erasure prevention tab missing from a commercial or previously recorded cassette? It would leave a little (about 1/8" square) hole in the spine edge of the cassette shell. That tab is there to prevent accidental erasure by allowing a small sensor lever to drop in and mechanically disable the recording mechanism. Compare a commercial cassette with a brand new blank one. You can place a piece of adhesive tape on the casette to allow recording, but take care to NOT cover more than the first 1/8" of the opening if it is larger as the recorder also senses tape type by the length of the hole molded into the cassette.
Word to the wise - don't scrimp on the tape if the recording matters to you. Spend a bit extra for better tapes. Store the tapes 'played', avoid fast forwarding and rewinding unless you'll be playing them through to wrap the tape uniformly before storing it INSIDE its tape box. Read the other warnings that come with the media. No heat, moisture, dust, blah-blah.
Jul 08, 2009 | ION Audio TAPE2PC Single Cassette Deck
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Jan 10, 2009 | Tascam Starter Pack for 4-Track Cassette...
Mini cassette tape is wrapped around one spool inside the casette
1). Remove the five screws from top half of cassette shell. If the cassette shell halves are glued together, very carefully split the shell with a Phillips-head screwdriver. Maneuver the screwdriver around the shell to break its seal. Avoid getting cut or damaging internal components of cassette.
2).Carefully lift off the top half of the cassette shell.
3). Pull the head if the tape from the left reel.
4). cut-off the damaged edge, and attached a peice of sctoth tape to the shining side of the tape, and leave about 1/2 inches of scotch tape beyond the head of the recording tape.
5). trim the sctoch tape using single edge of the sctoch tape razor or X-Acto knife to the same width as the recording tape.
6). carefully insert and tape the head of the recording tape to the right reel. and manually wind the tape till the recoding tape is flat to the front of the recoding pad.
7). carefully close the top shell, make sure not to pinch the tape. use your finguer trun the right reel, make sure the tape winds freely.
8). secured the top with screws.
Nov 24, 2008 | Maxell 179030 Microcassette 3-Pack (60...
Sony dual casette player/recorder
Unit may have slipping drive due to defective belt or tape may have wrapped around captsan. Have serviced
Jul 28, 2008 | Sony Dual-Deck Cassette Player/Recorder...
Tascam 488 mk II recording problems
Have you taken a look at the edge of the tape? tracks 1 and 2 on a cassette are usually next to the edge and you may have a bad batch of tapes that have the edge damaged. Another possible but not a likley problem might be the tape is out of spec. for the width, and your heads MAY have a little wear from use, and are trying to act like tape guides. If the tape is slightly wider than the grove worn in the head, the tape would be lifted at the edge and not make contact to the head. It is not electronic as you have diagnosed this with other tapes. Give it a try and see!
Aug 05, 2007 | Maxell 109069 Audio Cassette (Type 1)...
677 people viewed this question
 Grubhead
Grubhead
