Question about Sony Cyber-Shot DSC-F717 Digital Camera
Have a sony dsc-w50 display flashers E:91:01 all the time what does it mean Have not used camera for a while. Flash seems to not work
  • 1,170 Answers
The problem is with one of the capacitors, Sony can replace it for you at a cost of $80. This error can come, if we click photos continuosly, the capacitor may get heated up. We need to give a gap of 3 to 4 seconds. Time to be given for the flash to get recharged after a click.
Just give a call at Sony help line. 800.222.SONY, they will replace the capacitor.
If its worth the cost, go for the repair, or you can use the device without flash by disabling the flash. At setup just disable the flash and this error wont show up again.
Posted on May 30, 2010
I have a camera sony cybershot DSC-W350 and flash is not working. And I receive an error message E:91 01. What do I do?
Hi. Thanks for your question.
To get your camera back in working order you need to reset it to factory settings. Please click on the link below for a video from Sony website on how to perform reset.
http://esupport.sony.com/perl/tutorial-display.pl?tut_id=374&mdl=DSCW50
Thank You for using FixYa.
Jan 14, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Sony DSC-W50 camera Error msg E:91:01
Please follow the instructions given below
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Second step:
1)at setup do a initialize.
2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again )
by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cyber-shot dsc-w50 problem
Hi!
It's a flash error. Could be flash fuse or flash board. If you have a multimeter and you're ready to open it, contact me at toms.safranovs@gmail.com or contact your local Sony service center.
I work in a Sony service center.
Tom
Jul 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
E:91:01
I've had my dsc w50 for about 2.5yrs and its just started the same milarky! Go to menu, set up 1 and re-initialise, it cleared for me then came back again. Went through the same process just now and error has gone for time being, although I think the flash is on its way to heaven. Some pictures are dark and others completely white out!!
Taking it in to the sony shop tomorrow to see if they can lend any advice - I hope it doesn't mean a new camera as I've not over used it....
Let me know how you get on
Dec 03, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
After reseting the dsc w50, becouse of e .91.01., flash is not working
hi worked for me , remove battery take apart, discarge the capistor i think 320 volt DO NOT SHORT THE CAP !!!when dead voltage on cap ,turn on reset all camera and try good luck
Aug 31, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony dsc-w50 flash going off before or after shutter has opened and closed
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and
Jan 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Flash is inconsistent
I have the same issue. One picture the flash is perfect the next there seems to be a "half" powered flash and the pic is dark
Dec 09, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 issues
hi there
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
Oct 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony DSC-W50 Flash Error code-E:91:01
I have a method to stop the E:91:01 error flashing on the screen.it were not solve the flash function but atleast you can use the camera without flash. 1)at setup do a initialize. 2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again ) by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.hope it help.
Jul 25, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
110 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
