Question about HP Wireless Optical Mouse
I took mouse apart pieces went all over i got it back together and it works except i have one piece left over where does it go
    Brigadier General:
  • 10,406 Answers
You didn't give any information about the size and shape of that "extra" piece. So, there's no way for you to get help on FIXYA.
Posted on May 30, 2010
My corded mouse fell apart and I don't know how to put it back together
Not for nothing, but perhaps it's time to upgrade to either an optical or a laser mouse, no cleaning needed (except the occasional skate cleaning but that's all external) and they work on most any surface, except say glass, without need of a mouse pad. They're an inexpensive update and worth the money spent in my opinion.
Feb 23, 2013 | Compaq Computers & Internet
How to put my wahl 5 star detailer back together
my back piece where the scruess atach broke help please where can i buy a new back piece
Sep 26, 2012 | Wahl 8081
How do you take apart the gateway mouse so that I can clean the inside parts I think they got too dusty inside?
I wouldn't recommend taking apart the mouse unless you have at least one spare. Some of the parts inside can be a delicate and difficult to put back into place, if your unused to them.
If you still want to take apart your mouse, first unplug it from the computer, then turn it over so your looking at the bottom. There should be two "feet" on the bottom of the mouse, though sometimes more. These will commonly look like little plastic nubs or smooth "sliders". Use something with a thin edge and gently pull them up and away, and you should find screw holes underneath. Use a small screwdriver, commonly a Philips, to take out these screws. Your mouse should now easily pull into two pieces. Go slowly as you take the mouse apart, in case anything falls out or comes lose, so you can see where it was and how it fit into place.
To put your mouse back together after cleaning it, simply place the two halves back together once all the internal pieces are in their correct place, and tighten the screws again. Pop the "sliders" over the holes and it'll look like new.
Mar 06, 2011 | Gateway Computers & Internet
Replaced u joints on 1989 Montero rear drive shaft. Now drive shaft has vibration which peaks around 65 mph. Think I reassembled wrong or bad part(s)? Used Precision not OEM Mitsubishi u joints.
When you took it apart did you "match mark" the joints so that it went back together the same? If not then your driveshaft is probably out of balance. Any driveline shop can correct this. By match marking I mean that you make a mark on each piece of the driveshaft so that when you put it back together the pieces are in the same position relative to each other. If one piece got put back 180 degrees out, it can cause the whole shaft to become unbalanced.
Dec 24, 2010 | 1989 Mitsubishi Montero
My wireless controller was dropped and when i went to use it the L1 button would not work when pressed, so i took it apart then put it back together and now the L1, L2, R1, and R2 buttons dont work when...
Something happened when you took it apart. Either you dropped a piece, or the pieces are not lining up properly. Take the controller apart again and double check to make sure that everything will touch the contact points they are supposed to touch as you put it back together again. If it still doesn't work, then you might have accedentally damaged a lead on the little circuit board inside it, and at that point you will probably have to buy a new controller.
Aug 12, 2010 | Sony Wireless Controller for PS3
Whirlpool Clutch Problem
H i there.........it sounds as if your incorrectly assembling the clutch ....there is a diagram with the new clutch....no its part of the assembly
regards Sir Galahad
Aug 20, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I took the mouse apart and I can't put it back
Make sure the circuit board and wires are all in place correctly so they aren't preventing the case from snapping/connecting back together.
Most of the time, it's just a small piece of wire or something that is getting in the way and preventing you from closing it back up.
Devices are made so small these days that they don't leave much room in them for loose wires and all.
I hope this helps :)
Best Regards,
James Trageser
Jul 29, 2009 | Logitech Labtec Wireless Laser Mouse
My dishwasher won't drain
was it loose? I don't think it goes in there.
Nov 02, 2008 | Danby 22 in. DDW396 Free-standing...
Gateway 450sx no power
Needs physical repair. No help without some new parts. The "little piece" latch is necessary. The bay thinks there is a device there and there isn't. The POST (Power On Self Test) program won't allow it to startup if a device is missing.
Jun 18, 2008 | Gateway MT3705 Notebook
HP Wireless Optical Mouse Logo
74 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
