Question about Panasonic TH-50PX60U 50 in. Plasma HDTV
4 blinking lights
Panasonic TC-32XL70 will not power up,just blinking red light 4 times over and over.Any idea?-Thanks
  • 1 more comment
  • da_sellars Oct 07, 2008
    I have the same problem, only my television is a 50" Plasma Magnavox.
    50MF231D/37. After the TV sits for a few days, sometimes it will come on for a few hours, then go out. I am leaning on replacing the power supply assy.(costly). any suggestions would be greatly appreciated.
  • Anonymous Oct 17, 2008
    I have the same problem on my Panasonic TH-42PA50A (Aussie version 42" SD Plasmma). From what I'm reading it requires replacement of the 'P' board (Part No. TNPA3570) but they are about AUS$400. Pretty expensive if that doesn't fix it (I plan on doing it myself to save on the technician costs). Would appreciate it if someone can tell me if they've had success in applying this fix in the past?
  • Anonymous Mar 31, 2014
    blinking red light
I fixed it myself!
I bit the bullet and ordered a replacement Power Board for AUS$290 and swapped it out myself.
Only took ten minutes, most of that time was removing and replacing the 101 screws holding the back panel on!
Working fine again now.
I did sit the two boards side by side and noticed the new one had moved some of the micro components from the back of the board to the front plus some other small component changes.
If your handy with a screw driver and have some technical knowhow I recommend having a go at fixing it yourself as it wasn't hard and probably saved $200 in service charges (all this assuming you are out of warranty!)
Posted on Oct 27, 2008
SOURCE:
Panasonic plasma tv led blinks 12
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 24, 2016 | Panasonic TC-P46G15 Plasma TV
I have a Panasonic TC-P65ST50 which recently began shutting down and displaying 7 blinking lights and 8 blinking lights. Most of the time 7 blinking lights are displayed.
http://electro-medical.blogspot.com/
Feb 25, 2016 | Panasonic TC P65ST50 - 65" Class 64.7"...
Panasonic TC-P55ST30 red light blinks 7 times next to the on/off switch please diagnose, no power
These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link
Dec 06, 2013 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Tc-p50g20 4 blinks
My panasonic TC-P50G20 does not power on, just I have 4 blinks on my powericon1.png indicator light. What error does that mean?
Jul 24, 2013 | Panasonic Tc-p50g20 Viera G20 Series 50"...
TC-L26x1 No picture at all
you must count the red light blinks. This will indicate where the trouble is located.
Apr 23, 2013 | Panasonic TC-L26X1 26 in. HDTV LCD
I have a Panasonic Viera TC-P50x1 HDTV. When I turn the power on the red light blinks 10 times. What is my problem?
Unfortunately the set will need serviced. I would contact Panasonic or whoever you purchased it from for warranty information.
Jan 22, 2013 | Panasonic Tc-P50x1 50inch Class Viera X1...
Panasonic TC-32LX50 blinking red light
Could be an open internal fuse or power supply failure
Jul 31, 2017 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Panasonic TH-50PX60U 50 in. Plasma HDTV Logo
748 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
