Question about Strait-Line Strait Line 6041706 Stud Finder 150' w/Tape
Strait-line how do i read the lights to know when i'm at mid point of the stud, is it when all the red lights are lite ? grn-bulb red-bulb red-bulb red-bulb
  • 333 Answers
Yes. The lights represents the stud. As you move it over each light lights up.
Posted on May 30, 2010
Red light doesn't go off on stanley studfinder
Hi Laurie,
I think you might have confused the calibration set up in the first step of the directions. This must be done each time the unit is powered on, placed on a different wall, or whenever it is providing ambiguous indications. For you convenience, I have pasted the operation manual below. You should download and review the entire manual - free of charge here.
1) Hold the Stud Sensor 50 flat against the surface making firm contact.
2) Press in and hold the activation button. The green
and red LED's will light. When the red LED goes off,
the unit is calibrated
. Keep holding the activation button
during all of the following procedures.
Note: While calibrating, the Stud Sensor 50 must not
be placed directly over a stud, dense material such as
metal, or over a wet or newly painted area, or it will not
properly calibrate. If the Red LED stays lit, move to
a different location and try again.
2) Slide the Stud Sensor 50 slowly across the surface
in a straight line. As it detects a stud edge, the red LED
will go on.
Use the handy pencil notch located at the top of the
unit to mark the stud edge.
3) Repeat the above steps from the other side of
the stud. Coming from the opposite direction, mark
the other edge of the stud. The midpoint of the two
marks indicates the stud center.
Cautions on Operating
The proximity of electrical wiring or pipes to the surface
of the wall may cause the Stud Sensor 50 to detect
them as studs. You should always use caution when
nailing, cutting or drilling in walls, ceilings and floors
that may contain these items. Always remember that
studs or joists are normally spaced 16 inches or 24
inches apart and are 1-1/2 inches in width. To avoid
surprises be aware that anything closer together or of a different width may not be a stud.
I hope this helps & good luck!
Aug 18, 2012 | Stanley 77-050 Stud Sensor 50
How replace battery in stud finder
It is very easy. Open battery compartment at the back and remove old battery and put new one in.
If you get stuck you can download manual from here:
http://www.irwin.com/support-services/product-manuals
Jul 01, 2012 | Strait-Line Intersect Laser Level With...
Performance Tool Digital Tape Measure W5746
http://www.irwin.com/uploads/documents/30_intersect_laser_level.pdf
If that is not the correct one, check here:
Jan 29, 2012 | Strait-Line Intersect Laser Level With...
I can't find my user guide, What settings do I use for stud finder?
Hello. The instructions can vary from model to model. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
If this answer has helped, please rate it a four-thumbs up. Thank You.
Mar 27, 2011 | Strait-Line Intersect Laser Level With...
I have a 9-volt Strait-Line Stud Finder with 3 red LEDs and 1 green LED at the top end to mark the Stud Edge. I would appreciate it if I could receive step-by-step instructions on how to use the stud...
I suspect there are several models but I have one model. 1) Turn on the unit (if the green light is blinking replace the battery). 2) Calibrate the unit by holding it flat against the wall for 5 seconds until the red light goes off and the beep stops. Make sure you do not move the unit during the calibration or position the unit over a stud (try a spot 6-12" away from the corner of the wall - most studs are on 16" or 24" centers and the wood/metal stud is 1 1/2" thick). If the unit keeps beeping or the red light doesn't go off during the calibration, move the unit sideways 5-8" in case you are above a water pipe or other reason for "too deep a surface" for the unit.
3) Do not lift the unit off the wall or you will need to recalibrate it. Slide the unit across the wall. When the upper red light comes on and the beeping starts, that marks one edge of the object in the wall (stud). Continue until the red light goes off and the beeping stops. Mark the other edge of the stud by moving the stud finder in the opposite direction and marking when the red light comes on and the beeping starts. The center of the two marks is the center of the stud for securing anything to the wall.
If the beep persists over a 6" range, I'd check if you have any old cast-iron pipes or a door/window that was relocated in that wall. Repeating the test in a few places vertically along that spot of the wall will tell you there is a consistent large object in that location. Neither a filled in window or door will run the entire length of the wall but you could be finding the headers (the vertical framing of the opening would probably be ~4-6" wide (double or triple stud depening on the needs of the house design)).
I hope this helps.
(on another stud-finder that I borrow, you press the buttons on the right and left side to turn it on. Calibrate by holding it to the wall for a short while and then slide it across the wall. Note when the top red led lights and the beep starts. Repeat in reverse to find the other side of the stud.)
Sep 17, 2010 | Garden
How do i find a stud with the stud finder
Aug 18, 2010 | Strait-Line Intersect Laser Level With...
How do you know when the strait line laser level and stud finder is on a stud
Hello. The instructions can vary from model to model, but most have a green indicator light that lights up when the unit detects a stud. There is a section in the manual (for most models) that will show/inform of the unit's individual method. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
Jun 18, 2010 | Strait-Line Intersect Laser Level With...
How do I know when i am on the stud
These usually need to be calibrated in a stud-less section of the wall so that the LED just goes out. Slide the finder over the wall slowly until the light turns on--that is the first edge. Continue moving and the LED should go out--that is the second edge. These two points should be marked lightly with a pencil and the midpoint between the marks locates the center of the stud. Note that these tools will respond to wiring in the wall the same way. Hope this helps!
May 07, 2010 | Strait-Line Strait Line 6041706 Stud...
Strait-Line Strait Line 6041706  Stud Finder 150' w/Tape Logo
566 people viewed this question
Top Strait-Line Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Strait-Line Measuring Tool and Sensor Expert? Answer questions, earn points and help others
