Question about Dewalt DC925B Heavy Duty Xrp 18V Cordless Hammerdrill/Drill/Driver Bare Tool
Remove existing phillips no chuck avalible in this model
I have a DeWalt DW953K-2 currently it has a phillips in it and I need to get it out for a drill bit .. without any chuck or key how do I open it to remove the current tool bit ?
  • 333 Answers
Take a phillips screw driver and stick it into one of the key holes. Then take a flat head screwdriver and stick in one of the slots. And prise against the phillips.
Or you can wrap a belt or strap around the chuck hold it tight, then put the drill in reverse and unscrew it.
Posted on May 30, 2010
How do I remove chuck on a dewalt right angle drill dw960?
Open the jaws and look inside. You'll see a fastener. Some have Phillips head or an allen wrench. Use the proper tool to turn the fastener counter clockwise to remove the fastener. You may have to help the chuck off the spindle if it sticks.
Feb 24, 2015 | Dewalt Drills
How do I get the chuck off of my DeWalt DW 117 1/2" VSR Drill Serial #1229?
Open the chuck jaws and look down inside the chuck. You will see a screw head that is holding the chuck to the drill. Once you remove the screw, the chuck should pull off easily.
Jul 31, 2014 | Dewalt Drills
Dewalt dcd950 chuck
Its is about a 2 years modified the XRP chucks In Netherlands the model 950 is not QS made for europe but all the XRP machines have had a special solide looking Chuck For the original Chuck there was a special tool to remove the chuck the gearbox must be open to and a special N119912 a complete unit of repair tools to remove the chuck and replace , BUT the new modificated repair is by get a normal standard keyless chuck , asked them for about the modification because of the older repair tools and chuck http://www.2helpu.com/world/map.aspx it's about much more cheaper to choose for modification the N119912 is possible renumbered thats possible the right same tool because of the model DCD 950 is not selled in Netherlands . the DCD945 instead of but it means the same kind of modification .
May 29, 2014 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
A dewalt dcd970 18v xrp and when i try to unscrew anything the bit comes loose. Can't figure out why?
check the inside of the chuck at the bottom(open the chuck to max). There should be small screw there with either a hex or a Phillips head. It is a left hand screw that locks the chuck in place and will not let it unscrew when you are removing parts.. If it is not there then you will have to get one from an old drill that is junk unless you can get one from an electrical appliance shop the repairs drills.
Oct 24, 2011 | Dewalt Air Tools & Compressors
Removing centre screw from chuck
Drill a hole in the top of the phillips head screw with a 3/16 th's bit. Don't drill the head of the screw off, just drill deep enough for a torx bit to hold. Take a T-30 torx bit and tap in into the hole you have drilled. Then turn the screw clockwise and it should come out fairly easily.
Mar 26, 2010 | Dewalt Drills
Chuck is locked open
you have three jaws in your chuck, one of them will probably have a small burr on it causing it to stick.
try this...
tap the chuck with a small hammer then try to use the chuck key gently in the opposite key hole to the hammer blows. turn chuck though 120degrees and repeat.
if this does not work chucks are fairly universal and easily replaced (i would recommend a keyless jacobs). you can get the old one off by removing the ph2 (phillips) machine screw inside the centre of the chuck... be careful!! this screw is usually soft and counter threaded... when screw removed bash off the chuck with a hammer and cold chisel...
good luck
Oct 23, 2009 | Dewalt 1/2 Hammer Drill DW511
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
Removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Feb 16, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Keyless chuck question
this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
i prefer metal sleeve.
Aug 18, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DC925B Heavy Duty Xrp 18V Cordless Hammerdrill/Drill/Driver Bare Tool Logo
130 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
