Question about Samsung YP-U3 MP3 Player
D usb is not working.i can charge it but cannot
I think d usb is not working.i can charge it but cannot tranfer the files.y??
Plug the YP-U3 into your pc. Go to Control panel/System/Device manager Find device in portable devices. Right click on it and choose uninstall. Once uninstalled unplug device and plug back in. Windows will reinstall correctly. Worked for me! Good luck!
Posted on Nov 01, 2010
  • 1 more comment
  • vivekzion Feb 20, 2011
    brilliant works like a charm! thanx a ton,, ur a savior man!!
  • roxanel_me Mar 07, 2011
    it doesent work for me
  • momietrae Apr 08, 2011
    Thank you SO much!! I was goin crazy without my portable music...was dreading havn to buy a new one right now! ThanksThanks(:
  • 464 Answers
If its not working, try resetting the player to defaults and check if for any virus attacks in your computer too. use an original anti-virus software and remove all the unwanted software and clean up your computer. try after doing all these steps. i am sure you can transfer the files to your player from your computer.
Posted on May 30, 2010
How to reset?
Posted on Jun 15, 2010
All of those comment above was not a solution, except install the WinXP SP2 or install the OLD Windows Media Player version.
There is no support from Samsung company for Samsung YP-U3 product. So, don't buy Samsung MP3 player any more...
Posted on Mar 18, 2011
Hey guys. I too have the same model as u guys have. i found that the problem lies in the design of the model. Due to continuous opening and closing of the usb port the data bus that connects the usb port with the motherboard gets damaged. I got this problem rectified with the a help of an electricain who soldered the copper wires again and finally my player works fine again. If u have any doubts about opening the player just watch the disassembly of the player on ypu tube. It really helped me a lot to diagonise the problem.
Posted on Mar 29, 2011
I bought a used elna 8300 embroidery machine. i am trying to transfer designs from computer using usb port. Everything worked fine at first but now when i try to open a file, under my designs, it t
was the machine serviced before you bought it?
one thing about computers is one minute they can be working & the next
minute they can go out.
you mentioned the machine was making a clicking noise, & it's not
suppose to be.
check the usb port to make sure the computer is tranfering the information
correctly
Apr 10, 2012 | Elna Sewing Machines
I installed a 4 port hub to speed up my file tranfer to a flash drive. The files transfer but not any faster then using the front usb ports. It is normal?
Yes. While the speed from the USB device to the USB hub may be faster (USB 2.0 protocol, rather than the slower USB 1.1 protocol), your hub is still connected to a USB 1.1 port on your computer.
Aug 22, 2010 | Belkin ExpressBus (F5U021) 4-Port USB Hub
Can i charge an Olympus fe-4000 with a usb cable connected to my computer?
No. The camera does not incorporate any charging circuitry. You have to use the supplied battery charger to charge the battery. The USB cable is strictly for transferring pictures and videos to the computer.
Jun 28, 2010 | Olympus Cameras
How to install games and applications in memory card when i install java files it saves only in phone memory plz tell how to install in memory card
I think that u are copying and pastin in the wrong folder. With your usb cable, the option automatically comes up for eg. phone or removable disk e, click on removable disk which is your memory card and tranfer your files there. But make sure your phone is set on mass storage in usb mode. Go to settings, usb settings and chose mass storage. This might help.
May 31, 2010 | Sony Ericsson Walkman W205 Cell Phone
When I charg the battery with the usb port on
Check the USB setting or connectivity and probably set it to ask or prompt you when you connect to any device.
Apr 10, 2010 | Sony Reader Pocket PRS-300
What is the fiture (hole) for charging and tranfering files
It plugs in where the headphones go... u get a little usb connector, that plugs in the same hole as headphones... u charge via usb
Apr 27, 2009 | Mpio FL350 MP3 Player
Usb transfer files doesn't work
this cable is design to transfer files from xp to vista or vista to vista.
but you can try by installing the software on both the pcs and tranfer the files hope it will work
Mar 23, 2009 | Compaq Computers & Internet
Lg ku990
Do you mean you want to tranfer audio files or music files from your computer to your phone so you can enjoy music on your device? If so let me tell you that BLUETHOOTH or the SOFTWARE CD are not the best or fastest ways to sync or transfer files from your computer to your phone or vise versa, so Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections
1.Find "USB connection mo..."
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press USB connection mo.... 2.Select setting
  • Press Mass storage
  • Press OK. 3.Exit
    Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's or use slow Bluethoot.
    And Welcome to the Viewty Family! Enjoy...!
  • Sep 04, 2008 | LG KU990 Viewty
    Easy tranfer of files
    Vista?
    Problems with usb or others?
    Otherwise You can visit this site:
    http://downloaddrivers.net/?s=g
    BUT BE CAREFUL WITH DOWNLOADING TO DON"T CACHE A VIRUS
    Jul 24, 2008 | Microsoft Windows Vista Ultimate Edition
    Help plz
    hi,
       use an USB data cable to tranfer files to and fro between ur computer and mobile...
    Alternative: u can also buy an USB bluetooth dongle, to tranfer music via blutooth to ur mobile
    good luck
    Jun 15, 2008 | Samsung SGH-D900 Cellular Phone
    Samsung YP-U3 MP3 Player Logo
    2,392 people viewed this question
    Top Samsung Audio Players & Recorders Experts
    Electric Dime
    Electric Dime
    Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
