Sharp lcd lc-37SB24U The Power doesn't tuen on. It just blinks and the tv doesnt turn on and no picture and no sound. just the power button blinks green. Help Please
  • henry52521 Jun 01, 2010
    Sharp lcd lc-37SB24U sharp lcd lc-37SB24U The Power doesn't turn on. The green power led just blinks every 5 seconds or so and the tv doesnt turn on and no picture and no sound.I have tried to restore to factory default and lamp test but tv doesnt respond. Just power led blinks.
  • henry52521 Jun 02, 2010
    my sharp lc-37sb24u power light just blinks every 5 seconds and the tv wont turn on. it used to blink for a little while like that and then eventually turn on but now it wont come on at all. I have opened the tv up and nothing seems burnt out on the boards or anything. What part sounds like it needs replacing from this situation?
  • 12,061 Answers
Static.compusa.com/.../Sharp_LC37SB24U_LC32SB24U_Manual.pdf - United States - user manual, for programming www.managemylife.com/mmh/lis_pdf/OWNM/L0806215.pdf service manual and below is a training manual http://elektrotanya.com/sharp_lc-32ht2u.pdf/download.html below is a tutorial LCD manual, how to repair TV's www.scribd.com/doc/.../LG-Training-Manual-LCD-TV-42LG70
OK, I have found you some training manuals and your user and service manuals, Please download these and perform the troubleshooting steps, and you will soon isolate your issue, and you can then attempt repair.
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of only a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Posted on Jun 02, 2010
    Just in curiosity what do you think the problem is?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Blinking light means that the power is getting to the unit however, as its not working which means that the power board should be checked. To start with open the back of the unit and then check the power supply board for any bad (bulged/swollen) capacitors. Power supply board is the board where all the power cords/plugs goes into. After you have checked that also check the main board and if you can use a multimeter to test the components on these boards. All this should only be done if you have knowledge of internal circuitry of the unit as the components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 01, 2010
    ok so how do I check? Can you send me some pictures of where I am to place the voltage meter and what setting I am to put the voltage meter. I need a complete how to. I just ordered a new power supply board because I was told this was the problem but another person told me it is the inverter board, and now you are telling me it might be the main board. Can you please tell me how to check to see which one it is before I order more parts.
    Thank You
  • 10,594 Answers
Unplug tv from wall socket for minute to get it reset, replug back in and turn it On.
If problem still not solved then let me know how old is this tv?
Thanks.
  • 5 more comments
    model is lc37sb24u it is about a year and half old i think.
    right when I plug it in it ust keeps flashing the green led power light.
  • Shahid Electronics
    Shahid Electronics Jun 01, 2010
    Thanks for model info.
    Blinking green light shows problem with either power supply board or back light inverter board.
    I'm not sure about your expertise about tv repair, however power supply output volts should be checked by DVM to narrow down problem and of course its job of qualified tv technician.
    Thanks.
    so theres nothing I can do personally?
    It is hardware issue in tv, if your are handy with electronics stuff repair and can replace parts in tv circuit board with proper tools then you should attempt to repair tv.
    It is not some kind of operational problem.
    so what test do I have to perform to see if it is the power supply or the back light invertor
    Test was already mentioned, check output volts of power supply board at its connectors.
    Or swap that board if its possible.
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Our sharp tv model # LC-42D72U power light flashes green but there is no sound or picture. Looking for your expert opinion on what could be wrong so we can get the part ordered. The board with the power...
Green on light is blinking, but no picture - Television - iFixit
https://www.ifixit.com/.../Green+on+light+is+blinking,+but+no+pict..
iFixitOct 3, 2014 - The Sharp LCD TV LC37SB24U set worked until off button on remote ...The green light is blinking any time power cord is plugged into the wall outlet. ... It does sound like either a bad inverter board or a bad power supply. .... On the clad sidethere is no connections or ribbons that indicate hard current draw ...
Oct 20, 2015 | Sharp LC-42D72U 42 Flat Panel 1080p...
The power light blinks and the tv doesn't turn on
you should perform the initialization to factory defaults.
May 24, 2010 | Sharp LC-32SB23U 32 in. LCD TV
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
Sharp lc 37sb24u both power and ocp are blinking. power power power and ocp power and ocp power and ocp repeat forever.
I have the same problem. I can get the video by pushing the power button on top of the TV after using the remote and getting the power and ocp light dance.
Nov 16, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Two light are blinkin' in from panel. and tv
This seems to be a common problem. I have the same issue. Repair man says its a power supply (he thinks). When the lights start blinking, press the power button on top of the tv (not the remote) and most of the time it will come on and work. I am going to try to replace my power supply and see if that fixes the issue. If so, I will update this post.
Aug 28, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp LC-37SB24U will not turn on
I can tell you 100% that the problem that you are having will be a service issue. I can also tell you that your limited warranty covers in home service from sharp. Give them a call 1-87-SEE AQUOS(the advantage line that will get you through much quicker). or the 1-800-BE-SHARP and let them set you up for service, sharp will take care of that as long as the purchase date of your tv was within 1 year. If you dont want to go through that, I suggest taking the tv back to where you got it from if they will accept it because unfortunately, this problem can ONLY be resolved through service. good luck & keep me posted
Feb 17, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Power light blinking green,nopicture lc-32sb24u lc-37sb24u
This same thing happened to me, but not until I fiddled with all of my remotes, trying to see if it was an input issue, battery issue, etc. I finally unplugged the tv from the wall and plugged it back in. Nothing. Then I went to take 5 minute ****. When I finished, the Power & OPC lights were blinking, and out of sync. I pressed the power button at the top of my TV and got a picture.
Word.
Dec 31, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Electro Med Services...
